Like Tree89Likes
Serpent F110 SF4
Old 08-20-2018, 12:21 PM
  #16
fathead's Avatar
Rear wing doesn't appear to be attached to the pod
fathead is offline
Old 08-20-2018, 12:35 PM
  #17
sbd
Originally Posted by DavidNERODease View Post
I can't see the centre pivot design however and the screw pattern for the centre pivot looks quite different than what I would expect. It could be that centre pivot does not constrain fore/aft movement in which case the slots would have to be perfect. I was pretty sure an IF11 was in my future but this new Serpent is super exciting.
I think the center pivot is similar to the VBC f18 design which does not constrain fore/aft. If it was designed to constrain f/h then the side bearings would not be necessary (apart from holding the car altogether upon impact). In such design though, assuming its on bearings, the rear roll center would be too high, I guess.
As for IF11 - to be honest I don't see any technical innovation in it. Just a more complicated front end and a TC type of steering. Also split plate which is controversial for me. Just the same music in different tone....
iTz Nicholas72 likes this.
sbd is offline
Old 08-20-2018, 12:37 PM
  #18
Default Wing
Correct. A very good thing in my opinion. The two vertical rails that run under the diff hubs are part of the chassis and do not move (although they look to be adjustable). The wing on the S4 won't be part of the unsprung weight. I always hated seeing the wings on F1's tilting back and forth under acceleration/braking, bouncing, vibrating - yuk. So many awesome improvements on this car. The battery is slung lower (potentially depending on the trap door thickness - old Team Losi/Team CRC style). I love the way servo is mounted.
DavidNERODease is offline
Old 08-21-2018, 01:17 AM
  #19
Roelof's Avatar
I love the idea and it has proven in the past with the Impact where first the rear body mount was directly pushing on the upright and later it was fixed to the chassis to give more rear traction. I will expect a huge improvement on the traction but only the 2 small bars holding the wing will be very fragile with crashes.
Roelof is offline
Old 08-21-2018, 02:11 AM
  #20
sbd
Actually from downforce application perspective it is better to apply the force to the unsprung mass directly as the force does not go through the center spring. In PRO10 many times you need to use harder than you would like center spring to prevent rear of the plate ground contact in high speed. The question is how large is the downforce from our Formula rear wings.
On the positive site is the fact that the serpent design significantly, by about 10%, reduces the unsprung mass (Montech rear wing is 30g) which should be beneficial for handling.
Nerobro and G-rem like this.
sbd is offline
Old 08-21-2018, 07:38 AM
  #21
I just hope this beauty is available by the fall. The RSD conversion for the X1 will likely be the only F1 with a chance to pull me away from the Serpent.
Old 08-23-2018, 08:43 AM
  #22
Easier viewing here:
http://site.petitrc.com/reglages/ser...kom2018081618/
Old 10-19-2018, 05:53 AM
  #23
Hello
Do you know the release date of the SF4?
pennesw is offline
Old 10-19-2018, 06:08 AM
  #24
Billy Kelly's Avatar
Originally Posted by pennesw View Post
Hello
We are all waiting to hear anything.
Billy Kelly is offline
Old 10-19-2018, 06:13 AM
  #25
I do not want to buy now the SF3 maybe in a few weeks comes the SF4
Billy Kelly likes this.
pennesw is offline
Old 12-10-2018, 04:20 PM
  #26
I have it from a good source that SF4 will be available in 4;8 weeks time.
dman18t is offline
Old 12-10-2018, 05:03 PM
  #27
So at least February for us in the States most likely?
Old 12-11-2018, 08:51 PM
  #28
January
dman18t is offline
Old 12-11-2018, 09:56 PM
  #29
1/8 IC Fan's Avatar
Trader Rating: 91 (100%+)
We used to run wings mounted to the rear pod years ago, with no such problem.
1/8 IC Fan is offline
Old 12-17-2018, 01:41 AM
  #30
All details are online on the serpent website now. The kits are on their way to the distributors around the world.
sailfish likes this.
David_E is offline
