Old 02-18-2006, 03:06 AM   #1
Default TC3 gearing
I have 2 new pinions to go on my TC3, my question is how do you fit them? do I need to match the size of the spur pinion? The biggerpinion does not give enough room for the spur???? (sorry for the noobness)
oakesy2001uk is offline   Reply With Quote
Old 02-18-2006, 05:51 AM   #2
Trader Rating: 35 (100%+)
Send a message via AIM to Sean R
Here are some things that may be wrong:
  1. Are you using the same pitched pinion as the spur? (48 pitch spur meshed to 48 pitch pinion)
  2. Just to get it out of the way, you are loosening up the motor mount right?
  3. usually with a 72 tooth spur, you can't really run any smaller than a 21 tooth pinion. (that is probably your problem)
  4. Put the grub screw in the pinion and tighten on the flat "key" on the motor shaft and you should be ready.
  5. set the mesh at first until you get used to it with a piece of typing paper to get the perfect mesh.
You may have to switch to a smaller spur to fit in a "larger pinion"
Hope this helps...
Sean R is offline   Reply With Quote
Old 02-18-2006, 10:07 AM   #3
Frank N. Furter's Avatar
The biggest I can fit is a 33 pinion with a 69 spur.
If you have a 72 spur then a smaller pinion with less teeth will be needed.
Going from a 72 spur to a 69 spur is roughly the same as going up one tooth on the pinion.
What motor and track are you running?
Frank N. Furter is offline   Reply With Quote
Old 02-18-2006, 01:52 PM   #4
running an orion v2 element and stock tc3 gearing seems a bit short. the 30 and 31 pinion which I was told to use do not fit, so look like I need to have a re-think. what spur pinion should I use (that will fit)for general car park racing and drifting?
Old 02-18-2006, 02:39 PM   #5
Ali Graham's Avatar
Send a message via MSN to Ali Graham Send a message via Yahoo to Ali Graham
70T spur
Mirage Racing | Team Xray | Nosram | Atsushi Hara Racing Products | Team Orion | Hudy | Apex Models | Much More Racing | Exit13 | NinjaGraffix | ali303.8.dtiblog.com
Ali Graham is offline   Reply With Quote
Old 02-18-2006, 04:36 PM   #6
so what pinion with a 70 spur???, I have a 22, 30 and 31 pinon and a 72 spur, so what spur do I need for the 30 and 31 pinions to fit
Old 02-18-2006, 05:18 PM   #7
I think 30 and 31 would be over-geared pretty bad wouldn't it? You should try the 22 if it fits or maybe buy a 23 or 24.
Old 02-18-2006, 05:24 PM   #8
PaZ
PaZ's Avatar
when i ran a V2 in me TC3 in carparks a 29 was the biggest i could fit ( with the 72 spur) if your just messin about in carparks then i think a 27 would be fine you would have enough top end and less chance off cooking it
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
PaZ is offline   Reply With Quote
Old 02-19-2006, 10:24 AM   #9
will order a 27 then, thanks guys.
Gearing lickashotblaow Electric On-Road 0 07-29-2007 05:47 PM
NeeD Help with gearing please daver1 Electric On-Road 4 07-20-2007 09:12 AM
Gearing for TT-01 tl-01-jhb Rookie Zone 0 11-10-2004 05:35 AM
Need help gearing a TC3 fasda1 Electric On-Road 10 11-06-2004 11:51 AM
Gearing??? mike m Monster Trucks 3 01-24-2004 07:54 PM
