Team Associated TC7.2 Factory Team
#76
Mine arrived on Thursday and others are starting to receive theirs as well.
I believe standard distribution channels should have them in hand and you should be seeing more out in the wild soon!
I was able to race mine this weekend and I was happy with the first outing to be sure. There is alot to test with the new motor mount, and i feel like there's a lot of new potential in the 7.2!
#77
The real problem with 64p is that it will not stay efficient long enough to be beneficial vs 48p. From crashes, hot motor pinion temps, spur hub bearing play, motor torque, etc, there is no way to stay efficient without some of those teeth bending out of shape way before stripping. I was really amazed to see other racer's motor temps soar, while I was running way cool with my 48p gears....
#78
how does the gear pitch affect the temperature?
#82
I would say it doesn't. Im sure you can get deep into the weeds and argue that based on efficiency it could affect it but....When you can have 2 cars setup and geared identical, give them to 2 different drivers you end up with 2 different temp readings based upon driving styles.
#85
I always zip tie an antenna tube to the upper deck so that it lays flat. When you have to remove the upper deck - just slide out the antenna wire.
#86
use the Futaba RF204g-E Receivers. No Antenna
#88
Its' very discrete as you can barely see in this photo.
https://photos.app.goo.gl/UyAnmyh5ygGLNAa69
#89
This forum doesn’t give the option for a poll. Trying to decide on what combo of motor and esc for USGT. I was leaning toward mclan but heard great things about R1 and Trinity. I’m being a flounder
