Team Associated TC7.2 Factory Team >
Like Tree259Likes
Old 05-24-2019, 04:46 PM
  #376
Originally Posted by proliteandsc View Post
What servo do you guys recommend, or specks should I be looking for?
i use the power HD B7, used by Marc Rheinhard. Really good value for money, basically anything under around 0.07secs, torque doesnt matter as much with TC. Anything over 10kg is good. Just my opinion. http://www.rcmart.com/high-voltage-digital-brushless-servo-black-steel-gears-13kg47g-p-80709.html?cPath=1099_1025
Hasselhoff is offline
Old 05-24-2019, 11:01 PM
  #377
Trader Rating: 31 (100%+)
Do all servos need the inside lower ear to be cut off or are there servos out there that don’t need this done? All my servos have full aluminum cases including the mounting ears so I really don’t want to shave an Aluminium ear off.
riceball777 is offline
Old 05-25-2019, 05:10 AM
  #378
Originally Posted by riceball777 View Post
Do all servos need the inside lower ear to be cut off or are there servos out there that donít need this done? All my servos have full aluminum cases including the mounting ears so I really donít want to shave an Aluminium ear off.
Yes it needs to be cut off for the tc7.2
Old 05-25-2019, 06:58 AM
  #379
Trader Rating: 15 (100%+)
I am using a Sanwa servo and did not cut off the ear to clear the belt. The belt just fits into the hole and I have not noticed any wear of the belt or the ear on the servo after many hours of running the car. Not to say anyone else will not have a problem. Just saying so far I have not.
davidl is offline
Old 06-16-2019, 06:51 PM
  #380
Does anyone run a diff in the front? Or does every one run a spool up front. Why is this?
Old 06-16-2019, 08:10 PM
  #381
Diff wont fit. Belt is not in the middle.
91blackbird is offline
Old 06-21-2019, 08:16 PM
  #382
I just got a tc7.2 to replace my tc7.1 and my pinion does not fit. I run 48pitch The biggest pinion I can fit is a 37tooth. What do all stock guys do about this? Are there different top plates that allow for bigger pinions.
Old 06-21-2019, 11:01 PM
  #383
Trader Rating: 14 (100%+)
Use a smaller spur gear. I use the Associated 48 pitch 69 tooth spur which allows me to use 33 to 40 tooth pinions.
glennhl is offline
Old 06-21-2019, 11:35 PM
  #384
the chart in the manual will have what pinion sizes will work with what spurs
Old 06-25-2019, 01:18 AM
  #385
for 48pitch a 37tooth is the bigger pinion I can fit before the pinion hits the top plate. I just installed a 69tooth spur and I’m running the 37tooth pinion. It’s it’s a 3.72 final drive. Should be ok I think for my reddy m3 21.5t motor.
Old 06-25-2019, 04:50 AM
  #386
bshookup's Avatar
Trader Rating: 19 (100%+)
Like others have mentioned, changing the spur is likely the best most cost effective answer. Shimming the top deck up .5mm can get you an extra tooth in a pinch, and although I haven't tried it, this top deck looks to give you all the clearance you need: RSD TC7.1 Vertical Top Deck Kit Installed
bshookup is offline
Old 07-06-2019, 06:45 AM
  #387
Lone Drifter's Avatar
Is the TC8 on the drawing board, there to fix all the problems in the 7.2 design, maybe something that can be a center motor design.
Lone Drifter is offline
Old 07-06-2019, 09:19 AM
  #388
TurnNBurn's Avatar
I kind of wonder the same - been looking to get back in the game, and Iíve been considering either this, or a Serpent 4x Pro. Iím leaning towards the latter, due to itís radical, low CG design and the fact that I live in Serpent Americaís backyard, despite the fact that AR cars have always been close to my heart... Change my mind, AE!
TurnNBurn is offline
Old 07-07-2019, 05:13 PM
  #389
what is wrong with the design ?
this gen of the car is the best its ever been (IMO)
center mount is a fad, if it worked then Tamiya with the ta-05/trf 415 back in 2008 would still be using it.
Edwin Pibal is offline
Old 07-07-2019, 06:52 PM
  #390
Tc8? The tc7.2 just came out less than a year ago. Doesn’t associated keep the cars for a few years?
