Team Associated TC7.2 Factory Team >
Like Tree259Likes
Old 02-12-2019, 07:25 AM
  #316
tbrymer's Avatar
Originally Posted by JC3 View Post
I don't have a 7.2 (yet) but I do have two 7.1's. Last week I was working with a guy that had just bought a new 7.2. He was struggling with getting a larger pinion on his motor. The size of the pinion is limited by the top deck! Fortunately for him, I had a RSD VTD for sale and that solved his problem. Does AE have any plans to address this limitation posed by the new motor/top deck arrangement? I'd hate to think that the VTD is the only option.
Just out of curiosity, what size spur was he using and do you think if he put a bigger spur on he could use a smaller pinion to get the desired ratio?
tbrymer is offline
Old 02-12-2019, 07:37 AM
  #317
RobS's Avatar
I know some people have shimmed the top deck up slightly to help with pinion clearance. Otherwise you'll have to go the smaller spur/pinion route.
RobS is offline
Old 02-12-2019, 08:27 AM
  #318
JC3
JC3's Avatar
He was using a very small spur, less than 90. He was adamant about using it otherwise, yes, he could have just gone bigger to get his ratio.
He was already using 1mm shims under the top deck but that still wasn't enough.
JC3 is offline
Old 02-12-2019, 08:29 AM
  #319
Trader Rating: 14 (100%+)
I run a smaller spur. I run a 48 pitch 69 tooth spur. It will allow me to easily get ratios down to 3.1 without the pinion hitting the top deck.
glennhl is offline
Old 02-12-2019, 09:52 AM
  #320
JC3
JC3's Avatar
You mentioned earlier that you were using 48p gears. So, you can do a 44t pinion max. No clearance problems there.
JC3 is offline
Old 02-12-2019, 10:12 AM
  #321
Well, I'm glad you made me go check, I was COMPLETELY WRONG! Right now I'm running a 69 tooth spur and a 39 tooth pinion and it works great. That gives a 3.54 FDR. That's what I run for my VTA 25.5 car. But a 40 tooth pinion won't fit, it will barely hit the top deck. So if I need to run below 3.5, then I need to put on the 66 tooth spur gear. I'm not positive, but pretty sure I could move the motor back enough to get the 39 tooth pinion to mesh properly. That would give 3.38 FDR. Not sure if it's in the cards to get below that unless you run even a smaller spur and then slot the motor mount holes so you can move the motor back more.
JC3 likes this.
glennhl is offline
Old 02-12-2019, 11:12 AM
  #322
JC3
JC3's Avatar
Thanks for looking. I checked with the young man I helped. He was running a 88/56 with 64p gears. I think the largest pinion that he could fit with kit deck was around a 50. If he doesn't want to run the VTD anymore he will have to live with a larger spur. Thanks for helping me to clarify this!
JC3 is offline
Old 02-12-2019, 02:05 PM
  #323
DARKSIDE's Avatar
VTD?
DARKSIDE is offline
Old 02-12-2019, 02:08 PM
  #324
DARKSIDE's Avatar
page 27
https://www.teamassociated.com/pdf/c...C7.2-30122.pdf
DARKSIDE is offline
Old 02-12-2019, 02:11 PM
  #325
JC3
JC3's Avatar
Originally Posted by DARKSIDE View Post
VTD?
RSD's VTD (vertical top deck.) Previously for the 7.1 now a 7.2 item.
JC3 is offline
Old 02-12-2019, 02:13 PM
  #326
DARKSIDE's Avatar
oh...
DARKSIDE is offline
Old 02-12-2019, 02:17 PM
  #327
JC3
JC3's Avatar
How come you didn't come to QCRC for round two of the Tri-State series?
JC3 is offline
Old 02-12-2019, 02:20 PM
  #328
DARKSIDE's Avatar
real life
DARKSIDE is offline
Old 02-15-2019, 04:58 AM
  #329
JC3
JC3's Avatar
Do the AE x-ring shock seals (Part #91493) need to be soaked or treated in any way prior to use? I'm reading that some of the x-ring seals do and some don't. AE doesn't say one way or the other.
JC3 is offline
Old 02-15-2019, 04:30 PM
  #330
I use the green slime on any o-ring including the x-rings. It's a habit I got from work in Aerospace manufacturing.
LonnyJ1950 and JC3 like this.
glennhl is offline
