Team Associated TC7.2 Factory Team >
Like Tree259Likes
Old 12-29-2018, 07:47 PM
  #286
Trader Rating: 164 (100%+)
For now a tuned Maclan MMR Team Edition V2 with with aluminum screw kit.
jpcopeland1 is offline
Old 12-29-2018, 10:37 PM
  #287
Trader Rating: 23 (100%+)
Sorry, Iím not familiar with that motor however, I usually start a new 17.5 around 5.0 then slowly gear up while watching temperature, assuming youíve found the ideal timing.
pcar951 is offline
Old 12-30-2018, 02:07 AM
  #288
Trader Rating: 14 (100%+)
Maclan V2 17.5 with aluminum screw set coupled with the option Orange rotor will make some serious torque and hp.
trigger is offline
Old 12-30-2018, 05:04 PM
  #289
It has the optional rotor. So for 64 pitch according to TQ racings site, the T7.2 has a 2.00 internal ratio, and having a 96 tooth spur means I would need a 38 tooth pinion. Sound about right?
Old 12-30-2018, 11:31 PM
  #290
Yep, thatíll get you to 5.
pcar951 is offline
Old 12-31-2018, 06:17 PM
  #291
This would give you a FDR of 5.05. Seems a bit short to me. I've always had good luck running a 4.00 or lower FDR with a 17.5 motor. If I were you, I'd start with a 48 tooth pinion. That will give you a 4.00 FDR when using the 96 tooth spur. Good luck.
glennhl is offline
Old 12-31-2018, 09:33 PM
  #292
DBM
17.5t motors from 3 years ago liked 4.0ish fdr, but many of the new crop of motors like closer to 5.0fdr. Better to start at 5.0 and work from there than to start at 4.0 and potentially overheat.
i actually had this happen to me a couple of years ago. I bought a new 17.5t motor and was told to set the timing to 45 degrees and use a 4.0 fdr. After 3 minutes, it came off at 221F. Turns out the motor wanted 4.73 fdr and 35 degrees timing.
davidl likes this.
DBM is offline
Old 01-01-2019, 03:12 AM
  #293
Unlike motors like the MC2 which are very torquey and R1 which like to rev out, The Maclan V2 is a great compromise for torque and RPM. Small tracks (ie: tq raceway, cal raceway) I like 4.2 to 3.9 at 48deg.
tbrymer and glennhl like this.
trigger is offline
Old 01-01-2019, 08:25 AM
  #294
tbrymer's Avatar
I agree with trigger, I like 4.00 to 4.20 for 17.5 blinky around 48 to 50 degrees. I don't mind my motors coming off around 160-170 temp. I seem run my fastest laps at those temps, with no more fade at the end than anyone else.
glennhl likes this.
tbrymer is offline
Old 01-07-2019, 03:15 PM
  #295
None of the setup sheets I've seen mention this, but are people still drilling a small hole in the top of the shock to reduce rebound?
Kevin Marcy is offline
Old 01-07-2019, 03:26 PM
  #296
Trader Rating: 15 (100%+)
Default Shock Rebound
Hi Kevin. Take a look at the setup sheets for this car on the Associated website. Look for the sheet from Eric Epp at the 2018 race in Vegas, He has that noted as a mod to the shock cap.
davidl is offline
Old 01-10-2019, 06:19 AM
  #297
I just finished my TC7.2 built and found a strange ball cup issue. Scrolling through this thread I haven't seen this issue in other build reports mentioned before.
The ball cups that come with the kit look like the weak ones, I know from my TC6.2, but the material seems to be different. When snapping the ball cups on the ball studs, they are sitting so tight that is causes a binding like I haven't seen before.
The manual speaks about squeezing the ball cup in case of a binding, but no matter how much I sqeeze or massage the cups, the binding still locks every free movement of the suspension and steering.
I ordered an new set of ball cups, but I'm curious, if my ball cups are just outliers.
Fantuzzi is offline
Old 01-10-2019, 08:03 AM
  #298
YBSLOW's Avatar
The yokomo BD7 ones work well, but the ones from xenon are even better
YBSLOW is offline
Old 01-10-2019, 08:08 AM
  #299
RobS's Avatar
Part # for the Xenon ones??
RobS is offline
Old 01-10-2019, 11:05 AM
  #300
YBSLOW's Avatar
I got mine at apexrc.com
not sure what the pn is off the top of my head, but I think it is RDE-0043
YBSLOW is offline
