Team Associated TC7.2 Factory Team >
Like Tree206Likes
Old 09-17-2018, 08:19 AM
  #136
Rick Hohwart's Avatar
On the subject of servos, I highly recommend using AE #27128 servo washers (seen in the post above). These lock the servo down very well, especially when using only three screws to mount it.
https://www.teamassociated.com/parts...lack_aluminum/
ASM, Fastfreddy74, Serzoni and 6 others like this.
Rick Hohwart is offline
Old 09-19-2018, 09:43 PM
  #137
Final question: Car is put together but it seems alot more noisy than other models. At first I thought that perhaps I got some ca in some of the cogs in the front spool causing it to slip; I gently milled out what I thought was wrong and that helped but until I switched the spool around so that the grove around the cup is pointing to the right, then it got a little quieter, The belt seems it liked to jump in the front but it doesn't do that really now.
But it still noisier than it should be; any thoughts?
I'm running low cam, position 6 in the front and position 7 i believe in the rear; belts too tight?
irvinew is offline
Old 09-20-2018, 08:30 PM
  #138
can only recommend posting a video so we can hear the noise here or on the facebook group
ed
Edwin Pibal is offline
Old 09-22-2018, 09:00 AM
  #139
Lone Drifter's Avatar
Will there be a front Diff option for the Tc7.2 or will it only have a spool .
Lone Drifter is offline
Old 09-22-2018, 10:22 AM
  #140
So Iím thinking of getting back into onroad after racing off-road for the last 12 years. Iím leaning towards this car and running 17.5. Whatís everyoneís opinion on a good 17.5 motor for onroad?
FPMX772 is offline
Old 09-22-2018, 10:45 AM
  #141
tbrymer's Avatar
R1 wurks!
glennhl likes this.
tbrymer is offline
Old 09-22-2018, 09:56 PM
  #142
i think there will be
looking at the pics of the diff, it would really only be a matter of shimming it 2mm towards the centre for it to line up
ed
Old 09-23-2018, 03:36 AM
  #143
SuperRC's Avatar
Hey guys, I'm new to onroad What gearing would you recommend for TC7.2 running a 13.5T motor? What FDR would you recommend?
Thinking of getting Trinity monster or R1 motor.
Also, are there any spurs I can purchase for TC7.2 that are less that 80T and will fit straight on?
SuperRC is offline
Old 09-23-2018, 04:07 AM
  #144
wtcc's Avatar
Xray 305772 will fit (48dp 72 theeth) for example.
SuperRC likes this.
wtcc is offline
Old 09-23-2018, 08:37 PM
  #145
What are you guys using to set the bulkheads? I've seen bulkhead tools online but I've never actually built my cars with bulkhead alignment tools. Is there one available for AE chassis?
bdw11 is offline
Old 09-23-2018, 09:27 PM
  #146
Super Moderator
1/8 IC Fan's Avatar
Trader Rating: 79 (100%+)
?? Calipers, work just fine!
1/8 IC Fan is offline
Old 09-26-2018, 10:51 AM
  #147
This video from Randy Caster @ 1UP is really helpful. The carbon is very precise and allows everything to self center if you do it correctly.
Edwin Pibal likes this.
Brian Bosley is offline
Old 09-28-2018, 03:27 PM
  #148
Airwave's Avatar
Centering a part with two countersunk holes... lol
glennhl, gigaplex and JC3 like this.
Airwave is offline
Old 09-29-2018, 02:22 AM
  #149
Bar
Is the bulkhead spacing 21mm, need T-Works to do a bulkhead alignment tool?
Bar is offline
Old 09-30-2018, 05:53 AM
  #150
anybody run this car on gray carpet yet looking for spring suggestions or are the kit springs alright thanks in advance
ScottZ is offline
