3RACING Sakura Advance 2K18 EVO >
Like Tree190Likes
Old 01-28-2019, 08:42 AM
  #271
tomcat125's Avatar
My type-s body did the same thing. I have maybe 3 races on it now and it's junk.
tomcat125 is offline
Old 01-28-2019, 12:17 PM
  #272
LzREngineering's Avatar
Originally Posted by moparSRT View Post
Painted a new Protoform D9 body which tore on the wheel wheel during a light hit during the first run, very disappointed in PF quality
Saw this happen the other week at the local club, not good! Fortunately my D9 has had a few bumps and no damage yet but not expecting it to last a long time.
LzREngineering is offline
Old 02-01-2019, 01:39 AM
  #273
Has anyone got a good setup for grey carpet TC yet that they would be willing to share?
Last week my car was all over the place but I suspect it was mostly down to bad tyres. I had also switched to 2k diff, way too loose. For tonight I've switched back to the 7k diff but rebuilt it with less oil and the gears/outer case sanded down a bit more. Feels much smoother already.
Texas Postman likes this.
Old 02-09-2019, 07:03 AM
  #274
This thread’s been a bit quiet lately, hope everyone has had some good racing with their Advance EVOs!
I discovered the other day that the FR and RF suspension blocks don’t necessarily line up right (they are one of the few parts without an alignment pin) to solve, simply put a straight edge across each pair of mounts whilst tightening. I now have completely slop free, bind free suspension!
another problem: 2 of the metal down stop shims had come adrift form the chassis. Make sure you key these with some rough sandpaper when you glue them!
Old 02-09-2019, 11:53 PM
  #275
Razathorn's Avatar
Any resolution on the front arm material issue besides running the previous generation arms? As mentioned, arms are cheap, DNFs blow.
Razathorn is offline
Old 02-10-2019, 01:25 AM
  #276
My kit is from the 2nd or 3rd batch (got it in December after they had been out of stock for a bit). I've had some pretty big crashes involving the front suspension and so far nothing had broken. Maybe they already tweaked the formula for the plastic?
Old 02-14-2019, 07:56 AM
  #277
gabc's Avatar
Trader Rating: 15 (100%+)
Hi guys, any idea if this fits the 2k18:
for Sakura FF Ultimate XI XI Sport #SAK-U309/V2/BK, ,(SAK-U309/V2/BK) by 3Racing 7075 Aluminum RR Suspension Mount 2.5 Degree Black
and what's the difference between this and the stock RR block? Thanks!
Gab
gabc is offline
Old 02-14-2019, 08:21 AM
  #278
Gab
3RACING
That's a link to all the compatible RR blocks (also work as FF blocks). Not sure if the older version is a different height or just cosmetically different?
Old 02-14-2019, 10:47 AM
  #279
Razathorn's Avatar
Two things:
Is the kit front c-hubs are aluminum or composite? They look like composite, but they list the aluminum under spares. I see both composite graphite and alu available. I'm assuming composite because the manual calls out the rears specifically as aluminum.
Additionally... where on earth does one find the 5.8mm 10.2mm ball cap/end for the shocks? Are people buying the longer ones and cutting them down?
Old 02-14-2019, 11:39 AM
  #280
theproffesor's Avatar
Trader Rating: 63 (100%+)
Stock is composit. I bought and used the aluminum ones on the one I am selling
theproffesor is offline
Old 02-14-2019, 12:06 PM
  #281
Razathorn's Avatar
Any idea where to get this car and parts? RcMart doesn't use HTTPS and I'm not about to create an account on a site without https.
Old 02-14-2019, 12:08 PM
  #282
Super Moderator
Marcos.J's Avatar
Trader Rating: 221 (100%+)
RaceVTA
Marcos.J is offline
Old 02-14-2019, 12:11 PM
  #283
Razathorn's Avatar
Originally Posted by Marcos.J View Post
I realize that's MoparSRT's site, and I'd love to support active racers, but it doesn't appear to use https either. Kinda a deal breaker.
Old 02-14-2019, 12:35 PM
  #284
3Racing have an ebay shop which is secure.
Old 02-14-2019, 01:08 PM
  #285
You can get the car and most parts from e bay
s14_tat is offline
