Like Tree34Likes
XRAY X12 19
Old 11-14-2018, 05:07 AM
  #31
So whats the overall impression on this? Seems positive I know Xray 1/12 of past did excellent at my local track
Rckstar759 is offline
Old 11-14-2018, 06:16 AM
  #32
big_ads's Avatar
Trader Rating: 88 (100%+)
Originally Posted by trilerian View Post
Hey Robbie, are you still flipping the front arm mounts for spec class black carpet? Also, have you tried the shorter wheel base on the rear pod yet? I am wondering if it is worth it to convert my 18.
If you are running spec classes on black carpet you are definitely going to want the shorter rear pod. I converted my 18 for 13.5 and it was definitely worth it.
trilerian likes this.
big_ads is offline
Old 11-14-2018, 01:27 PM
  #33
R Dodge's Avatar
Sorry guys, been busy and missed all of this. Adam and Korey nailed the responses perfect.
I am still flipping the arms and running short wheelbase front and rear.
R Dodge is offline
Old 11-14-2018, 04:38 PM
  #34
Trader Rating: 37 (100%+)
Adam, what all was involved on that swap? Just rear bulkheads and eccentrics?
chensleyrc1 is offline
Old 11-15-2018, 09:09 AM
  #35
Trader Rating: 30 (100%+)
Another question... How about running in the inline configuration on black carpet with solid axle. I keep wanting to try this out, but it is a pretty big change in configuration, and I don't generally have much time to work on my car from practice day to race day.
I think you need the new bearing hubs too.
trilerian is offline
Old 11-15-2018, 09:52 AM
  #36
big_ads's Avatar
You need the new left and right bulkheads and the eccentric bushings. The eccentrics do not require the plastic inserts that the stock 19 holders use.
Part Numbers needed:
1 x 373016
1 x 373026
2 x 373042
chensleyrc1 likes this.
big_ads is offline
Old 11-20-2018, 04:01 PM
  #37
Car is ready to test the inline config tomorrow.
JeffofSpace likes this.
Old 11-24-2018, 05:28 AM
  #38
EDWARD2003's Avatar
This video should help you understand how to flip the caster block mounts for CRC black carpet conditions.
EDWARD2003 is offline
Old 11-25-2018, 08:41 PM
  #39
JeffofSpace's Avatar
Thanks!
JeffofSpace is offline
Old 11-27-2018, 06:53 PM
  #40
cobrajet's Avatar
Has anyone tried the new gear diff?
cobrajet is offline
Old 11-29-2018, 09:00 PM
  #41
Trader Rating: 25 (100%+)
The gear diff works great in low-medium bite surfaces. Makes the car more consistent and you do not have to rebuild the diff near as much as a ball diff!
Low grip surfaces you should start with 10k
Higher grip you should start with 30k
Max K is offline
Old 11-30-2018, 01:37 AM
  #42
Skiddins's Avatar
Those figures are far too high.
Stock with medium bite should be in the 700-1000 range.
Mod should start around 1000
Skiddins is offline
Old 11-30-2018, 07:49 AM
  #43
Hi guys,
is it normal that instead of breaking a front lower arm the chassis splits the carbon fiber layers apart from the mounting screws to the front??
bought a new 2017 last year and within 10 batteries the chassis broke (1 decent hit...).
If this is normal I wont be buying a new one...
Quante is offline
Old 11-30-2018, 07:56 AM
  #44
big_ads's Avatar
Originally Posted by Quante View Post
Hi guys,
That is not really normal. Did you glue the chassis before installing? Most of the time glue will help prevent the chassis from delaminating.
big_ads is offline
Old 11-30-2018, 08:11 AM
  #45
big_ads's Avatar
Are you talking black carpet or something else? Max's numbers are a great ball park on black carpet. Your numbers look to be inline with grey carpet or asphalt.
big_ads is offline
