Like Tree34Likes
XRAY X12 Ď19
Old 08-15-2018, 01:36 AM
  #16
Shop Owner
nnick's Avatar
will the new upper clamps be fitted to x12'18 and/or x10'18?
nnick is offline
Old 08-15-2018, 03:19 AM
  #17
R Dodge's Avatar
It does not appear that they will. The bulkheads on the 2019 have new part numbers.
R Dodge is offline
Old 08-16-2018, 07:31 PM
  #18
Car Breaker's Avatar
I guess the new clamps are bigger to accommodate the plastic insert so the new motor mount must have bigger cut off for mount the clamps, it is just my guess
Car Breaker is offline
Old 09-17-2018, 05:52 AM
  #19
JEFFs SC10's Avatar
Trader Rating: 15 (100%+)
subscribing/
JEFFs SC10 is offline
Old 09-24-2018, 12:08 PM
  #20
mauromj's Avatar
Trader Rating: 21 (100%+)
Can anyone confirm if the new rear spring plate (with incorporated battery holder/o-ring "tabs") will fit a '17/'18 chassis? I would love to convert to it.
mauromj is offline
Old 09-24-2018, 01:31 PM
  #21
R Dodge's Avatar
yes
Yes
R Dodge is offline
Old 09-24-2018, 08:02 PM
  #22
JeffofSpace's Avatar
Ok, I donít think this changes on the Ď19 model. (And I may have asked this in one of the other x12 threads but donít remember.) Was the same on Ď17 and Ď18. Why is part 373120 used here...why such wide bore spacers/shims on the rear of the front bulkheads?
JeffofSpace is offline
Old 09-25-2018, 04:41 AM
  #23
R Dodge's Avatar
The original lower suspension arm had material there that the shim would go around, obviously that was removed years ago as you pointed out. The point of it now is to hit more surface on the reactive castor block (372021). I personally do not use these shims though. Xray used to make some shims for the old T2/T3/early T4 suspension that I prefer.
XRA303134-K - ALU shim for lower susp. holder 3x7.5x1.5 Black (10)
You could probably also use these shims in order to have some adjustability:
XRA372291 - ALU shim 3.1x8x0.5 (4)
R Dodge is offline
Old 09-25-2018, 08:06 PM
  #24
Ah, ok...thatís right, and you may have answered this for me previously on one of the other threads. So really lots of possible solutions here. I just remembered the part during the preseason rebuild and saw how awkward they are compared to the rest of the precision parts.
Old 09-26-2018, 06:43 PM
  #25
GT CRUSING's Avatar
Does anyone who has bought the kit, does it come with the gear diff included for the US edittion?
GT CRUSING is offline
Old 09-28-2018, 06:21 AM
  #26
R Dodge's Avatar
No, both kits come with the ball diff. The gear diff is a separate option.
R Dodge is offline
Old 11-10-2018, 09:15 PM
  #27
Trader Rating: 30 (100%+)
Hey Robbie, are you still flipping the front arm mounts for spec class black carpet? Also, have you tried the shorter wheel base on the rear pod yet? I am wondering if it is worth it to convert my 18.
trilerian is offline
Old 11-11-2018, 08:05 PM
  #28
Iíve seen the flipped arms. What is the purpose? What parts needed?
Old 11-11-2018, 11:39 PM
  #29
Korey Harbke's Avatar
Reduced camber gain and a different roll center. it raises the inner hinge pin a bit, and you can further increase the height by adding spacers under the aluminum caster block mount once its positioned on top of the arm. This is beneficial in really high bite conditions and smooths the car out a bit.
JeffofSpace likes this.
Korey Harbke is offline
Old 11-12-2018, 08:15 PM
  #30
Thanks, Korey.
