Like Tree233Likes
XRAY T4'19 SPEC
Old 05-03-2019, 05:28 AM
  #481
Originally Posted by R Dodge View Post
okay, that shouldnít be happening. Check to make sure there is nothing binding or interfering with the belt in any way. Iím not sure what else to tell you. The kit belts have been good consistently over the years. But this is for sure unusual.
For now I ordered a full set of black belts for spare and another front belt to fix the issue. I know during my initial assembly the belt wanted to twist a little around it's midsection when it was idle.
And before driving I had to trim the servo mount grommets as the rubber was sticking out where the belt was and it was pushing the belt out a little. I made sure to watch for interference across the belt when revving it off the ground and I did notice the belt just didn't seem smooth at high rpms, like there was a lot of belt vibration at the midsection of the belt, but I assumed that was due to low belt tension.
OT: it is amazing how easy maintenance is on the car. The only other hobby grade 1/10 on road car I've had was an HPI Nitro RS4 2 (fully upgraded, still have it) and it took no time at all to pull the diff and belt assembly off the T4, compared to the RS4 I would have to remove half the front of the car to get to the diff and front belt. I thought about running it again, but since parts as gone and Xray being well and alive I may just permanently retire it and get an NT1 for my onroad nitro fix if maintenance is going to be simple on that as well.
InTheZoneAC is offline
Old 05-03-2019, 06:35 AM
  #482
Trader Rating: 22 (100%+)
Be sure your front spool has the side piece on and secure. This is assembled when building the kit.
Also, check to be sure that the top deck isn't cracked or that you have too much flex in the car. The only time I've had a front belt come off was the result of a hard hit that cracked the top deck allowing the car to flex front to rear too much.
mooby64 likes this.
Troy Carter is offline
Old 05-04-2019, 08:03 AM
  #483
-When you say side piece are you talking about the ring that attaches to the spool to give the belt two sidewalls to rest inside? The front spool has been properly assembled, the flat parts are facing the belt and the bulge of the ring is on the outside.
-The hubs are locked into the bulkhead supports otherwise I wouldn't be able to fit the spool down in place.
-The upper plate is fine, although one end seems flimsy since it's a split design, but that's normal.
There's still some servo mount material (the servo screw with rubber grommet) sticking out about .5mm-1mm from the aluminum brace. I already trimmed the rubber away since it was sticking out a lot more and was pressing against the belt initially, but are tolerances so tight around the belt that it would rub the aluminum servo mount even without a servo installed? I still am thinking the belt itself was one part of the issue since it didn't lay flat. There was always a part of it that wanted to twist. I know it's thin, but still.
Old 05-04-2019, 06:18 PM
  #484
Nobody uses the rubber grommets on the servo for electric cars. Not sure about nitro, but I doubt it.
belewis01 is offline
Old 05-06-2019, 03:03 AM
  #485
Suspended
Lonestar's Avatar
Xray introduced this at 2016 worlds. I donít think anyone else had it at the time, but it definitely has become a common tuning option these days. There are also now many other variations of it but it seems Xray feels the carbon brace is best and I agree it is very good. It reduces overall flex with the main benefit seeming to be increased forward traction. It does reduce the feel of steering mid corner which can improve corner speed, but definitely improves forward drive
Robby,
thanks for this. I'm still confused with this center brace... and I'm not good enough a driver to make sure I "feel" the change in a consistent manner.
For 13.5 boosted, on a low-medium grip fast asphalt track, what would you recommend as the "base" configuration for this center brace and/or shimming the top-deck?
Thank you
Paul
Lonestar is offline
Old 05-06-2019, 07:27 AM
  #486
R Dodge's Avatar
Originally Posted by Lonestar View Post
Robby,
Thank you
Paul
I would recommend going with 6mm shims under the carbon brace. That seems to be pretty common on the Euro asphalt setups. I never tried 6mm until last season when I copied Alex's pre-worlds setup and I liked it. I also ran the 2.0mm topdeck raised 1mm per Alex's setup.
Lonestar likes this.
R Dodge is offline
Old 05-06-2019, 09:01 AM
  #487
Suspended
Lonestar's Avatar
Thank you... will try this saturday raceday then
Lonestar is offline
Old 05-06-2019, 02:28 PM
  #488
Suspended
Lonestar's Avatar
Guys, what an I doing wrong?!? I used an older part which I had filed a bit... And even when it just doesn't fit... It rubs the belt
​​unambiguously...
Thanks!
paul
6mm shims
Lonestar is offline
Old 05-07-2019, 04:44 AM
  #489
R Dodge's Avatar
Hey Paul,
I am actually converting my car to asphalt now so I just went to 6mm under my center brace last night. I did not notice anything like this when I did this but I'll have to look at it when I get home tonight.
R Dodge is offline
Old 05-07-2019, 09:05 AM
  #490
daleburr's Avatar
The front belt rubs on the carbon brace, servo mount, lower servo ear, upper side of the top-deck, and underside of the steering ball-joints. All my cars are like that. Don't worry about it.
daleburr is offline
Old 05-08-2019, 07:36 AM
  #491
Suspended
Lonestar's Avatar
Hey Paul,
Thanks - curious to see if yours is any different... as the holes in the chassis are where they are, I can only think about the belt being installed more to the right side if yours clears it...
Thanks. Mine rubs on the lower center servo washer, very true - I had filed this too not on the steering ball joints, prob as I'm running the diffs low. I guess I will buy a spare belt just in case
Cheers both!
Paul
Lonestar is offline
Old 05-08-2019, 08:01 AM
  #492
R Dodge's Avatar
Ah, sorry I totally forgot to get that pic last night. I will do that today.
R Dodge is offline
Old 05-08-2019, 11:53 AM
  #493
Josh-n-ya's Avatar
Trader Rating: 95 (100%+)
Who has tried the Rcmaker floating electronics side plate? I got one and havenít tried it yet. I noticed it stiffened up center of chassis a bit when I mounted it. I wonder if I can get away with not using the center CF chassis stiffener. I will try Saturday. Weíll see
Josh-n-ya is offline
Old 05-08-2019, 02:14 PM
  #494
R Dodge's Avatar
Cheers both!
Paul
here is my belt at the center brace. Definitely looks like I have a little more clearance than you do but itís still gonna rub. I donít stress about it.
R Dodge is offline
Old 05-08-2019, 02:33 PM
  #495
R/C Tech Elite Member
JayL's Avatar
I know someone who RAN it....
JayL is offline
