Like Tree272Likes
XRAY T4'19 SPEC
Old 01-03-2019, 12:06 PM
  #256
Originally Posted by Skiddins
Shimming the motors out changes the balance of the cars slightly.
There's a reason they keep trying to move the motors inwards (though I think we've reached that limit)
It really depends on what battery you run. I'm still running older IP 6000mah 90c at about 290-295g. 2014 and 2016 chassis balance better with that battery, because they're from before the motor was moved in. My 2019 is just a touch heavy on the battery side from the motor being moved in back in 17(?). But with the newer graphene batteries that are down around 270g, or the LCG batteries that are even lighter, yeah, moving the motor in more is desirable.
Generally speaking, I'd rather move a component to get left/right balance, than add weight for it. And I haven't replaced my batteries, because I feel like it makes more sense to just have more battery, than more ballast.
grippgoat is offline
Old 01-08-2019, 08:22 PM
  #257
Hi. Could you tell me height of body post for Racer and Type-s bodyshell??
It seems rear is same all the time (35.3mm from bottom of theshock tower ) but all the bosyshells have different height for the front post
Thank you
accord12 is offline
Old 01-09-2019, 07:58 AM
  #258
JoeyE's Avatar
Trader Rating: 45 (100%+)
First Xray T4. Finish polishing (cleaning) up the ride after a couple races. Stock set up with a couple hop ups. Pretty easy to drive
mracer1 likes this.
JoeyE is offline
Old 01-09-2019, 06:14 PM
  #259
JEFFs SC10's Avatar
Trader Rating: 15 (100%+)
if anyone is selling a 19 roller/ (aluminum chassis) let me know, I want another one lol
JEFFs SC10 is offline
Old 01-10-2019, 03:20 PM
  #260
Suspended
Thank you
hi,
sorry for the delay in responding. Here are the measurements I use with the threaded body height adjusters:
TYPE S
Carpet
Front - 7 hole 10.5mm
Rear - 4 hole 12.6mm
D9
Carpet
Front - 7 hole 11.1mm
my rear post is 38.0mm from bottom.
nnick likes this.
R Dodge is offline
Old 01-10-2019, 04:46 PM
  #261
Originally Posted by R Dodge
hi,
TYPE S
Carpet
D9
Carpet
I really appreciate it great help. Cheers.
accord12 is offline
Old 01-10-2019, 05:10 PM
  #262
stupid question, i havent got my kit in yet but..... what holds the battery in place?
i see the front and rear "L"s and the center barricade, but what keeps it from coming out vertically?
STANG KILLA SS is offline
Old 01-10-2019, 05:13 PM
  #263
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
Tape?
chiefj48 likes this.
RKeasler is offline
Old 01-10-2019, 07:08 PM
  #264
Trader Rating: 22 (100%+)
Yup, tape. And personally I like it that way.
Troy Carter is offline
Old 01-11-2019, 08:58 AM
  #265
R/C Tech Elite Member
JayL's Avatar
Not just tape,
Hudy tape!
JayL is offline
Old 01-11-2019, 11:19 AM
  #266
Bassbuster's Avatar
How do you guys shorten your body posts. Just cut them with a dremel, saw, or just some wire cutters?
Bassbuster is offline
Old 01-11-2019, 12:01 PM
  #267
any one know of an older Xray (or other brand) battery strap/bar i could adopt to this? i know it will stiffen chassis flex. im ok with that for the convenience.
Old 01-11-2019, 12:35 PM
  #268
mrreet2001's Avatar
xray 306165 T4 Graphite Battery Strap for LiPo: https://www.teamxray.com/teamxray/pr...ria=0&catName=
Yeah Racing XR-T4-010 Aluminum Adjustable Velcro Lipo Battery Mount: T2/ T3 - Yeahracing - (#XR-T4-010OR) Aluminum Adjustable Velcro Lipo Battery Mount For XRAY T4 Orange
Also A long velcro strap will work, just route it the way the tape would go.
STANG KILLA SS likes this.
mrreet2001 is offline
Old 01-11-2019, 10:11 PM
  #269
I use a cut off wheel in a Dremel - real quick and neat.
belewis01 is offline
Old 01-12-2019, 05:59 AM
  #270
mracer1's Avatar
Hi, could someone please post the 19 part # for the steering rack with the pushed in brgs? Want to upgrade my 18.
thanks
Mike
mracer1 is offline
