XRAY T4'19 SPEC
#242
Hi there guys , does anyone know what's the item number for the plastic servo horns ? And yes I know the alu servo horns are better . I just want something that's a bit more responsive than the Xray servo saver but still got a bit more give than the alu servo horn in case the unexpected happens . Thanks guys
#243
yokomo one for BD9 is also right height. B9-204
#244
Suspended
#245
XRA356200 is the correct part number. This plastic option seems to be perfect for carpet racing where the boards can sometimes be unforgiving. Been using this for over a year now with no issues. Max K. tried one at Stock Wars and he said it was definitely more steering in the sweeper compared to the servo saver.
#246
Back from the offroad race... The T4 teardown has started...
- zero binding in suspension
- zero binding in transmission
- full symmetry everywhere it can be symmetric (obviously the motor is still on the left and the battery on the right)
- 9.1mm shock shaft exposed on all 4 ends, now bumped up to 9.3mm now. Balls could swivel nicely in the plastic
- shocks feels perfect, about zero rebound (had rebuilt them during raceday)
will keep progressing slowly as the holiday time is taking its toll on RC
#249
#250
Suspended
I also always prefer cutting the shaft of the rotor. I usually make sure to use painters tape or something to cover all the holes so no debris gets inside, and I go slow so the rotor doesn't get hot.
The battery backstop is definitely good to have. You may find that you don't need to grind much if at all once you install the backstop.
#253
None what so ever. I used a dremel disc to grind away the shaft and fine sand paper to finish. The rotor gave identical readings on my rotor gauss meter before and after.
#254
There's a reason they keep trying to move the motors inwards (though I think we've reached that limit)
#255
