Old 09-12-2008, 11:29 AM   #1276
sosidge's Avatar
Question for those breaking c-hubs - are you shimming them on the shaft?
There is a lot of play on there, I shim these parts as a matter of course, and I have never broken one. In my experience parts with a lot of free play tend to be the ones that break.
Old 09-12-2008, 12:31 PM   #1277
Rob Burns's Avatar
The car is shimmed, it's just that the boards at my track are extremely unforgiving.
here's a video from our track so you can see the boards. That track lay out was a bit of an anomoly as it did a sweeper at the end of the straight. Normally it's a 90 degree corner with a pole as the corner. I don't know how many cars have broken on that corner.
http://www.youtube.com/watch?v=jLU781C-YBs
Rob Burns is offline   Reply With Quote
Old 09-12-2008, 03:25 PM   #1278
chris moore's Avatar
Trader Rating: 88 (99%+)
Originally Posted by E.J. Evans View Post
Hey Chris, are you interested in the rubber or foam setup? I'll working on the setup sheet for rubber, and I'll have Josh post his foam. I've also got a pretty good foam setup that works well too.
I need the rubber tire setup E.J. I was going to ask Kyle but have'nt seen him since he came back from Vegas.
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 09-12-2008, 06:24 PM   #1279
E.J. Evans's Avatar
Send a message via Yahoo to E.J. Evans
Default Vegas Setup
Hey Guys, here is my Vegas rubber tire setup. I have not unpacked from Vegas yet, but when I do I'll take pictures of where I placed the weights.
Give it a try it's pretty good.
EJ
T.O.P. Racing | APEX Hobbies | R1 | Solaris | NorCal Hobbies |
Solaris Racing Products (SRP) Solaris Spec Tires!
www.solarisrp.com | www.apexhobbies.com | www.topracingusa.com
E.J. Evans is offline   Reply With Quote
Old 09-13-2008, 05:13 PM   #1280
Thanks EJ, I'll give it a try next time on the rug.
Sponsered by:
Old 09-17-2008, 08:56 PM   #1281
GeorgePravata's Avatar
Trader Rating: 108 (100%+)
EJ the foam cars is done and I must say very nice Now If I have time I'm off to built the rubber car. Just want to give props very nice TC..
Thanks for all the help
George P
TEAM ASSOCIATED,REEDY POWER, AKA, TQ WIRES, SILLYBOYZ PRODUCTS.
GeorgePravata is offline   Reply With Quote
Old 09-19-2008, 08:21 PM   #1282
CarlosG.'s Avatar
Send a message via Yahoo to CarlosG.
Selling my scythe, any takers can go to this link: http://www.rctech.net/forum/r-c-item...ythe-sale.html
I am just giving a heads up.
CarlosG. is offline   Reply With Quote
Old 09-20-2008, 04:26 AM   #1283
Hello, "Topracers" , a litle question here, Always use the rigid post, not lateral posts, but the post are under top deck?
In Euros, i donīt use it, and i make a more flex 2mm top deck, and work very well, the track are low grip, and more hot.
Greetings, Luis C.
## NOSRAM ## YOKOMO BD5W ## BMI DB12RR+ ##
luic is offline   Reply With Quote
Old 09-20-2008, 04:48 PM   #1284
Tpg racer's Avatar
Is the old scythe still worth getting???
Tpg racer is offline   Reply With Quote
Old 09-20-2008, 09:45 PM   #1285
All of them are great cars but like the TC5 it has evolved into two different versions optimised for the two different types of tyres we race on (foam and rubber). The original version with plastic bulkheads is very effective in low grip conditions and can be adapted to suit your needs.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 09-20-2008, 11:14 PM   #1286
Tpg racer's Avatar
So by getting the old scythe I wouldnt be a mile far behind the new ARP nor the 2008 Scythe, would I ???
Old 09-21-2008, 06:31 AM   #1287
Generally speaking it will have greater overall grip and will work better on low grip tracks like rubber/concret. It will have slightly less midcorner speed (than an alloy version) and comes with a oneway front diff which isn't used all that much these days.
You can easily change out the parts you want to suit your needs once you run it. My current chassis is the orignal but I have added bits a pieces over time to suit rubber tyre racing on asphalt and concret which is what I do. Also some of my additions are to suit mod which you may not need.
Moral: kit car is good.
Powered by Falco
Old 09-21-2008, 07:00 AM   #1288
razzor's Avatar
The standard kit is great for asphalt/parking lot racing and especially in the stock classes.
It works well with both rubber and foam tyres in these conditions and teh only changes needed would be a spool or diff up front if that suits your driving style other wise the oneway is fine.
Only other upgrades i recommend for the std kit is put teh ceramic diff balls.
My std kit with just a front spool and the ceramic diff balls runs comfortably with the Xrays/Serpents/TRF's etc... in fact i like it more than the option kit.
The option kit works great for mod and needs the extra strength for this class.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 09-22-2008, 12:02 PM   #1289
Tpg racer's Avatar
Just got a used TOP Scythe... where can I download the manual and setup sheets from???
Any good setup for rubber-tarmac racing???
Old 09-22-2008, 12:36 PM   #1290
Rob Burns's Avatar
Try here:
http://www.top-racing.jp/download.asp?lang=EN
***** SCYTHE red " IIC 2007" edition***** spy R/C Items: For Sale/Trade 5 12-01-2007 10:21 AM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 09:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
New TEAM ASSOCIATED RC10L3 "Touring" pan car for sale. "TEAM VERSION" Ron Meloni R/C Items: For Sale/Trade 0 06-24-2003 03:37 PM
