T.O.P. Racing "Scythe" 1/10 EP Touring Car >
Old 07-03-2008, 02:10 AM
  #1096
sand down the edges of the upper deck around the bulkheads, some of them are a little long and tweak the car once installed. I struggled for almost 2 yrs before i finally realised this. Took off a fair bit of material around the screws, and voila the car has transformed
dangles is offline
Old 07-07-2008, 04:32 PM
  #1097
mmgteam's Avatar
hi :
this is the new TOP SCYTHE
http://www.technicalrp.com/html/top/ARP-CFP.pdf
mmgteam is offline
Old 07-08-2008, 11:41 AM
  #1098
Thanks for all advices, i solve all the problems this weekend, i change the top deck, for a new 2.5 mm, sand the edges and take off a litle material for more flex. Checked all shocks, dismount it and mount, and cut the top bulkheads the third screw, front and rear, the car work very good, now i go to test the 2.5 US chassis, with flex top deck.
Hello Mauricio, i like the ideas of the new car.
Greetings, Luis C.
luic is offline
Old 07-10-2008, 07:20 AM
  #1099
Nova F1 Racer's Avatar
I want to put in the optional pulleys to bring the ratio down to 1.9 and which company makes this? Is this a Scythe part or does HPI/X-ray fit it also?
THX
Nova F1 Racer is offline
Old 07-10-2008, 07:46 AM
  #1100
sosidge's Avatar
The optional pulley/belt sets are TOP parts. 33T/17T is the one you want for 1.94, the part number for the full conversion is PO-SDT111.
sosidge is offline
Old 07-10-2008, 08:21 AM
  #1101
daveaustin5's Avatar
Do you guys know any good sites for Scythe setups? I know of the muchmore UK site but are there any others?
daveaustin5 is offline
Old 07-10-2008, 08:34 AM
  #1102
sosidge's Avatar
I think you may find some on the www.top-racing.jp site as well although they may also be duplicated on MMUK.
What kind of setup are you looking for?
sosidge is offline
Old 07-10-2008, 08:37 AM
  #1103
GreaseMonkey's Avatar
You can also try here:
http://www.petitrc.com/reglages/top/...sTOPScythe.htm
GreaseMonkey is offline
Old 07-10-2008, 11:03 AM
  #1104
razzor's Avatar
Noticed that teh new revised cars will have the 17t as standard for the center pulley and will have a 33t for carpet and 37t diff pulley for asphalt version.
razzor is offline
Old 07-11-2008, 02:24 AM
  #1105
losithrasher's Avatar
what arms and stuff switch in and out on this car?
losithrasher is offline
Old 07-11-2008, 02:42 AM
  #1106
razzor's Avatar
The Scythe uses HPI Pro4/HotBodies Cyclone suspension parts.
razzor is offline
Old 07-11-2008, 08:58 AM
  #1107
Originally Posted by GreaseMonkey View Post
Cheers guys.
I'm looking for a carpet ruber setup (small tight track). Thinking of trying out a spool but everyone seems to use a one-way.
Old 07-11-2008, 09:21 AM
  #1108
sosidge's Avatar
Cheers guys.
I was racing at a tight track rubber/carpet/19T last weekend, wasn't happy with the spool (see my spool shimmy thread), ran the diff instead and car was very good. Controversial TQ, and fastest single laps of any rubber car.
Setup basically kit springs, Rayspeed 3x1.2 pistons, #450 oil front, #400 oil rear, no bars, 1.5 front block, 2mm under front blocks, 1mm under rear blocks, ample droop.
sosidge is offline
Old 07-11-2008, 09:42 AM
  #1109
Old 07-11-2008, 11:37 AM
  #1110
somebody told me you could switch it out for xray arms and such.
