Old 06-16-2008, 05:29 PM   #1066
Another issue that i have seen is people running the TOP titanium screws in the bumper.
These screws have a smaller diameter, and therefore would be easier to pull through the chassis, as the screw head is supporting fewer laminations.
Though i do have to say when the graphite breaks, it is clearly evident that the laminations are significantly drier than other examples i have seen, like there is less epoxy in the mix.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 06-16-2008, 07:24 PM   #1067
yokemad's Avatar
Such a Great result Mark Young well deserve that after all that effort he spend to carry on racing as he is a family & business man also running a model car club...Danielle Young U16(his daughter) also finished Second on G final
Matt Mead finished first on G final who is very young talented guy (U16) and supported by Mark Young...
I don't know where you can find that energy but well done Mark
yokemad is offline   Reply With Quote
Old 06-18-2008, 04:26 AM   #1068
razzor's Avatar
Always great to see a underdog car get on teh podium only to loose those drivers after showing the ability to other high end brands.
The Scythe is definately a capable chassis and i love it
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 06-18-2008, 06:08 AM   #1069
yokemad's Avatar
Hi guys
Could you please tell me Which parts does top racing used on scythe
Like
suspension parts from cyclone
shocks&front&rear bumper from Yokomo
CVDs?
Diff&oneway pulley ?
diff rings?
diff balls? (or what size are they)
where do you usually buy your parts from?
Cheers
Old 06-18-2008, 07:28 AM   #1070
sosidge's Avatar
Originally Posted by yokemad View Post
Hi guys
Like
CVDs?
diff rings?
Cheers
Standard diffs are Yokomo (although TOP now have their own design available as an option), pulleys are TOP, CVDs are TOP but to a Yokomo design.
Parts in the UK are naturally available from any store with a dealer account with a company that is in your signature AND mine!
Old 06-19-2008, 05:42 PM   #1071
Send a message via AIM to ERTRACHTER
hey whats up guys reporting from the nats here in arkansas and it looks like josh kyle and myself should do allright are cars have been working pretty darn good so far i guess we will have to see after qualifying tomorrow ill try to reort more tomorrow
ASSOCIATED 12r5.1,REEDY MOTOR AND BATTERY, LRP SPEEDO,KIMBROUGH PRODUCTS,BIG DOG RACING,BELMONT R/C SPEEDSHOP, DENNIS LYMAN RACING, TEAM TOSO, TEAM FACTORY BITTER, SCHUUR SOLUTIONS, SIMMONS RACING, TEAM BOOZCRUZ
ERTRACHTER is offline   Reply With Quote
Old 06-19-2008, 07:31 PM   #1072
kirizutochan's Avatar
Goodluck! Represent my brother!
visit my page ---► http://kirizuto.wordpress.com/
║ HotBodies ║ NOSRAM ║ MuchMore ║ Futaba ║ Protoform ║ SpeedMind ║ Xenon ║ Sorex ║ REEDY ║
kirizutochan is offline   Reply With Quote
Old 06-20-2008, 02:23 AM   #1073
razzor's Avatar
Good luck !!
Casterracing ZX1.5R
Old 06-20-2008, 08:40 PM   #1074
tbeardmore's Avatar
Hey All - FYI!
The 4th Annual Midwest Carpet On-Road Championships has been announced!
Hope you can make it to "The Plex"...!
http://www.rctech.net/forum/attachme...9&d=1213690177
-Todd
BMI DB10R, Corally RDX PHi, BMI 12R..!!
Need a "real" car... contact me at:
www.beardmorechevy.com -or- www.beardmoresubaru.com
tbeardmore is offline   Reply With Quote
Old 06-25-2008, 02:26 PM   #1075
chris moore's Avatar
Trader Rating: 88 (99%+)
Ok I have a ? for you guys. I bought one of these cars and have a problem with my lipo fitting, I'm using the Orion 4800 lipo and it will not fit under the center layshaft mount/holder. Is anyone using this lipo and have a modification or is everyone just useing a different/thinner lipo?
Chris
chris moore is offline   Reply With Quote
Old 06-25-2008, 02:44 PM   #1076
razzor's Avatar
Chris
I have a 4800 Orion lipo fitted in my 27T Scythe without any hassles..
Its mounted with double sided tape and the carbon battery holder.
Only thing i did was to file flat edges on the battery holder posts.
I also have a 5300 Nosram softpack fitted in my mod car in the same way and no fouling or touching the motor mount brace.
Ill take a pic and post tomorrow.
Casterracing ZX1.5R
Old 06-25-2008, 02:51 PM   #1077
Thanks that would be very helpfull I can fit it under the top plate np but it hangs out over the edge of the chassie and I really do not like that. I do not have the battery holder on my car so that may be something I need to look into getting.
Old 06-25-2008, 04:13 PM   #1078
E.J. Evans's Avatar
Send a message via Yahoo to E.J. Evans
Hey Chris,
I run my SMC 5000 under the top deck also, and not under the right side of the motor mount. You just have to make sure it's secure (I use tape) and the car is balanced left to right.
EJ
T.O.P. Racing | APEX Hobbies | R1 | Solaris | NorCal Hobbies |
Solaris Racing Products (SRP) Solaris Spec Tires!
www.solarisrp.com | www.apexhobbies.com | www.topracingusa.com
E.J. Evans is offline   Reply With Quote
Old 06-25-2008, 04:28 PM   #1079
Thanks EJ I'm assuming that your running the tape through the triangle shaped holes(correct), thats what I was expecting to do but thought I'd see if anyone was doing it differently. I have also tried my 3200 lipo and it does fit down in the battery slots and under that right side brace/mount piece.
Old 06-26-2008, 10:37 AM   #1080
yokemad's Avatar
Hi Guys
I've got the red scythe as a second car next to my Mi3
I usually put the car on setup board to sort out Tweak, I've tried that with Scythe but m3 screw heads touches to setup board before the chassis because of that it plays left to right on setup board behaves like its tweaked ...
Have you guys have that type of problem?
what you suggest me to do?
Thanx in advance
***** SCYTHE red " IIC 2007" edition***** spy R/C Items: For Sale/Trade 5 12-01-2007 10:21 AM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 09:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
New TEAM ASSOCIATED RC10L3 "Touring" pan car for sale. "TEAM VERSION" Ron Meloni R/C Items: For Sale/Trade 0 06-24-2003 03:37 PM
