Old 04-17-2008, 07:10 PM   #991
chicmagnet's Avatar
Originally Posted by E.J. Evans View Post
Moving the servo forward will transfer more weight towards the front. From my experience more "nose" heavy cars will push on low bite asphalt (also harder on front tires), but on high bite surfaces like carpet it helps to stop traction rolling.
However, if the weight is biased towards the rear then the car can get loose mid corner.
This is just my experience.
Post your setup and maybe we can help get it better.
Front:
droop 5mm
camber 2
caster 4
ride height 5mm
shock oil 40wt
shock piston 2 without rebound foam
Rear:
droop 4mm
camber 2
ride height 5mm
shock oil 40wt
shock piston 3 without rebound foam
im running on an asphalt med to low traction track...
STRAIGHT LTD.
chicmagnet is offline   Reply With Quote
Old 04-18-2008, 12:22 AM   #992
E.J. Evans's Avatar
Send a message via Yahoo to E.J. Evans
Originally Posted by razzor View Post
That is one thing i am needing to do.
Notice that the shock length is limiting how much droop i have so need to either fit longer ball cups on the shafts or take out the spacer inside the shock.
Razzor, you can cut 2mm off the cylindar piece inside, this will give you more arm hang to play with. I also run it with the trianle piece down.
There is also the lowered shock towers you can use which should help.
T.O.P. Racing | APEX Hobbies | R1 | Solaris | NorCal Hobbies |
Solaris Racing Products (SRP) Solaris Spec Tires!
www.solarisrp.com | www.apexhobbies.com | www.topracingusa.com
E.J. Evans is offline   Reply With Quote
Old 04-18-2008, 12:36 AM   #993
STLNLST's Avatar
Trader Rating: 21 (100%+)
It's on this weekend.
STLNLST is offline   Reply With Quote
Old 04-18-2008, 03:41 AM   #994
razzor's Avatar
Have regoinal champs this Sunday and a practice day on Saturday.
Think ill try the lower towers out.
Thanks EJ.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 04-18-2008, 04:30 AM   #995
Hi all,
I have a question about the TOP 2008 version.
Has annyone driven him jet?
And is there a difrends in the handeling with the first one?
I have now all allu parts on it.
What is the difrens betwaen the new and the old akerman?
Does it has les understear the 2008 version?
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 04-20-2008, 11:19 PM   #996
STLNLST's Avatar
E.J.- Good run this weekend. Thanks for the set up help. I think we will both benefit from testing since our cars are so simular. Also going from your post about the servo being moved forward causing a low speed push is probably why my car pushed. Scotty moved my servo up quite a bit when he installed my electronics. I plan on using the stock servo mounts when I switch over the new chassis.
Old 04-21-2008, 08:08 AM   #997
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
Car is real close... Now some questions... Will/are the HPI Pro4 Aluminum suspension blocks the same as the Scythe? They look almost the same...
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 04-21-2008, 08:17 AM   #998
razzor's Avatar
They will fit.
The Tamiya and Yokomo fit as well.
Not sure on there measurements/values being the same though.
Have helped out Serpent and Tamiya guys with my spare Scythe blocks.
Casterracing ZX1.5R
Old 04-21-2008, 10:24 AM   #999
E.J. Evans's Avatar
Thanks Clint, your car was working good too.
Old 04-21-2008, 10:26 AM   #1000
E.J. Evans's Avatar
The Scythe currently uses HPI suspension parts, which is the same as the Pro4 and Cyclone.
Old 04-21-2008, 01:27 PM   #1001
GreaseMonkey's Avatar
I'm not a huge fan of the HPI suspension. I'm hoping TOP has their own design coming out soon.
We had a new racer with a brand new Cyclone WCE turn up to race last Wednesday. He didn't know anything about set up. We went through the basics with him and put his car on a set up board. Checked rear toe and found it had 3 degrees of toe in on one side and 1 degree of toe in on the other. This was a little disconcerting so I threw my Scythe on the set up board and found i had 2 degrees rear toe in on the left and 3 degrees toe in on the right.
I'm not a grown man playing with toys. I'm a hobbyist.
GreaseMonkey is offline   Reply With Quote
Old 04-21-2008, 04:03 PM   #1002
on the birds show www.rctvlive.com mentioned Josh running the schythe car. will it ever be on? i wanted to see more about it and watch it running? do you have a link of some video as well? thanks
microcrazy24 is offline   Reply With Quote
Old 04-23-2008, 12:43 AM   #1003
Jamesalex's Avatar
Questions??
Can any one help
I put the new ration (1.94) set into my car the other nite and took it racing however now the backend is all over the place not planted as before, the car setup is the same.
Any ideas to help sort this out or info on how to get around this.
regards
james
Jamesalex is offline   Reply With Quote
Old 04-23-2008, 07:10 AM   #1004
they will give the same toe values, but the hpi ones are 1mm lower, so your roll centre will be different
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 04-24-2008, 12:09 AM   #1005
bulldog2's Avatar
Grease monkey ...
yest thats the problem that all the top car has 3 and 2 degrees on each different rear wheel so what we do over here is loosen and re adjust the 2 suspension block opposing each other and you should be able to get 2.5 on each side
hope that would help.
woof
bulldog2 is offline   Reply With Quote
***** SCYTHE red " IIC 2007" edition***** spy R/C Items: For Sale/Trade 5 12-01-2007 10:21 AM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 09:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
New TEAM ASSOCIATED RC10L3 "Touring" pan car for sale. "TEAM VERSION" Ron Meloni R/C Items: For Sale/Trade 0 06-24-2003 03:37 PM
