T.O.P. Racing "Scythe" 1/10 EP Touring Car
#916
Great job Josh, EJ, and Jason...pretty darn good results, way to lay it down
EJ, call me when you get a chance.
Holla!
Holla!
#918
#919
allright guys heres my setup pretty close to what i ran at the snowbirds
front end:
tamiya shocks
steel spool
xray oil 350
hpi gold springs
no swaybar
blocks used in the front were 1.5in the rear of the front and 1.5 in the front for no arm sweep
wheel base 2.5mm shims in rear and 1 mm shim in front
ackerman plate mounted in middle hole
1 mm shim under steering post
1 mm shims under ballstuds on bell crank
.5 shim under ballstud on c-hub
3.5 mm shims under front camber link inside to make camber link flat
droop 6 on guage
rear end
0 block in front of rear
3 block in rear
tamiya shocks
xray oil 300
hpi springs silver
no swaybar
2 mm shim under inner ball stud on camber link
droop 6 on guage
wheelbase 1.5mm shim in front of the arm
post under topdeck in front removed
chassis 3.5 mm us spec
topdeck 3.5 mm us spec
ko propo servo
spectrum pro reciever
losi speed control
hacker 13.5 105 spur 45 pinion
optional 1.9 pulley set
if i forgot anything just hit me up im still pretty tired car drove great and was pretty fast in the mains basically on my wheel base guys i set it up so the cvds are straight with no angle for less bind
front end:
tamiya shocks
steel spool
xray oil 350
hpi gold springs
no swaybar
droop 6 on guage
rear end
3 block in rear
tamiya shocks
xray oil 300
hpi springs silver
no swaybar
droop 6 on guage
ko propo servo
losi speed control
#920
maxsp97 you have a pm
#921
guys i forgot my shock positions in the front i ran the middle hole on the tower and all the way out on the arm in the rear i used the middle hole on the arm and the furthest hole out on the tower
#922
Jason - What about the roll center shims under the 1.5 front blocks and 0/3mm rear blocks.
#923
#928
Great job at the race guys JOSH, E-MAN, and EJ...
Glad to see Josh and Jason doing so well with the change of cars...
#929
Hey Guys,
A couple of quick questions for you, and i apologise for picking your brains excessively, but theres a couple of things i really cant get my head around in regards to set-up.
Can anyone explain to me the effects of raising the lower toe blocks???... eg going from 0.5mm all around to 1.0mm all around or vice versa.
I understand kick-up and anti-dive/squat and all that... but in terms of just raising or lowering the whole lot im still confused.
And aswell as that... i dont get shimming the steering links or ackerman links... eg: adding 1mm under the ball studs etc.
Again i apologise for asking such an involved question but whilst my scythe just keeps getting better and better... i feel there is a lot still to be unlocked in the car that i just dont understand...I've been doing a few testing days just to try things but im making slow progress.
Cheers, all help is greatly appreciated
Robbie
Robbie
#930
