T.O.P. Racing "Scythe" 1/10 EP Touring Car >
Old 03-06-2008, 09:50 AM
  #871
razzor's Avatar
HPI Pro4 and Cyclone arms and uprights etc... work and work well.
razzor is offline
Old 03-06-2008, 10:16 AM
  #872
daveaustin5's Avatar
They do work well, the only reason Josh used the xray parts was because he thought they were more reliable than the HPI parts.
daveaustin5 is offline
Old 03-06-2008, 12:02 PM
  #873
Turbonium's Avatar
Trader Rating: 27 (100%+)
i would think they are... i have not had good luck with HPI steering blocks in the past.
although, i havent had the same problems on the TOP car. only breakage i have had on it was the rear hub, but nothing out of the ordinary.
i think he used the Xray parts because he was comfortable with their geometry and probably work better with the foam tires...
Turbonium is offline
Old 03-06-2008, 12:43 PM
  #874
GreaseMonkey's Avatar
Actually, if you read Josh's post in here he said he was faster with the HPI parts.
GreaseMonkey is offline
Old 03-06-2008, 03:52 PM
  #875
Turbonium's Avatar
could be... i didnt remember reading his post. the HPI setup has been good inb the past for me on rubber tires, tho. i dont run foam much at all...
im thinking there might be a TOP designed suspension on the horizon tho... im sticking with the std set till then, personally.
Old 03-06-2008, 04:04 PM
  #876
I've run both rubber and foam with the HPI set-up. I can't complain at all. If TOP come out with their own suspension, I'll be more than happy to use it.
Of note, the Xray T2 steering knuckles fit on the HPI suspension. In my experience, they are weaker.
Old 03-06-2008, 10:15 PM
  #877
razzor's Avatar
Ive been running 2 chassis and lately 3 and in over a year i have only broken the plastic upper bulk head bracket that holds the shock tower.
evrything else holds up well to the punishment it takes.
We run 6 cell, outdoors on asphalt.
razzor is offline
Old 03-11-2008, 12:40 AM
  #878
Jamesalex's Avatar
Default Springs?
hey, does anyone know where I can find a spring lb's chart for the top springs or just the standard ones that come in the box?
Jamesalex is offline
Old 03-11-2008, 02:18 AM
  #879
zacabrandy's Avatar
Try Rod at RC Shop.
www.rcshop.com.au
zacabrandy is offline
Old 03-11-2008, 04:14 AM
  #880
sosidge's Avatar
http://www.top-racing.jp/showProduct...&ProductID=135
sosidge is offline
Old 03-11-2008, 05:12 AM
  #881
Sorry but can't be bothered goin and gettin my sheet out of the garage at the moment but I do remember that kits springs are 15.2lbs rear (more coils) and 15.8lbs front (less coils). Also it should be noted that the spring rates are not in order of the springs as confirmed by my spring dyno. I'll post the rates both converted and actual when I get a chance.
As it stands I have changed springs away from kit springs 2 times since I have had this chassis. I wouldn't bother with option springs unless you race on low grip. Just tune with the swaybars. I run between 1.2-1.6mm with kit springs and always have plenty of speed.
Dragonfire is offline
Old 03-11-2008, 05:31 AM
  #882
razzor's Avatar
Here is the list of option and kit springs:
PS-S14500 Racing Spring 1.4x5.00 22.5mm 332gf/mm
PS-S14525 Racing Spring 1.4x5.25 22.5mm 308gf/mm
PS-S14550 Racing Spring 1.4x5.50 22.5mm 288gf/mm possible std kit spring
PS-S14575 Racing Spring 1.4x5.75 22.5mm 270gf/mm
PS-S14600 Racing Spring 1.4x6.00 22.5mm 254gf/mm
PS-S14625 Racing Spring 1.4x6.25 22.5mm 240gf/mm
PS-S15525 Racing Spring 1.5x5.25 22.5mm 437gf/mm
PS-S15550 Racing Spring 1.5x5.50 22.5mm 406gf/mm
PS-S15575 Racing Spring 1.5x5.75 22.5mm 379gf/mm
PS-S15600 Racing Spring 1.5x6.00 22.5mm 348gf/mm
PS-S15625 Racing Spring 1.5x6.25 22.5mm 341gf/mm
PS-S15650 Racing Spring 1.5x6.50 22.5mm 316gf/mm
PS-S14450 Racing Spring 1.4x4.50 22.5mm 392gf/mm
PS-S14475 Racing Spring 1.4x4.75 22.5mm 359gf/mm possible std kit spring
Kit spring p/n
P950-475 4.75 windings
P950-550 5.5 windings
razzor is offline
Old 03-11-2008, 06:40 AM
  #883
Jamesalex's Avatar
Thanks for the info guys, on another note how much flex,twist,tweak what ever you call it do you get in the chassis I have a carpet flex and standard 2mm chassis an they seem to twist very easy unlike the xray use too any ideas on this?
Old 03-11-2008, 01:54 PM
  #884
Kit spring p/n
I used this spring converter to convert all of the spring rates to imperial:
http://www.hraefn.net/projects/spring_rates.php
Old 03-12-2008, 12:05 AM
  #885
Ok guys... Here is the spring list with both converted and "actual" rates
1.4x4.75 22.5mm 359gf/mm = ??.?lbs / 15.8lbs
1.4x5.00 22.5mm 332gf/mm = 18.6lbs / 17.1lbs
1.4x5.25 22.5mm 308gf/mm = 17.2lbs / 15.7lbs
1.4x5.50 22.5mm 288gf/mm = 16.1lbs / 16.0lbs
1.4x5.75 22.5mm 270gf/mm = 15.1lbs / 15.0lbs
1.4x6.00 22.5mm 254gf/mm = 14.2lbs / 14.4lbs
1.4x6.25 22.5mm 240gf/mm = 13.4lbs / 12.1lbs
1.5x5.25 22.5mm 437gf/mm = 24.5lbs / 19.9lbs
1.5x5.50 22.5mm 406gf/mm = 22.7lbs / 17.2lbs
1.5x5.75 22.5mm 379gf/mm = 21.2lbs / 18.4lbs
1.5x6.00 22.5mm 348gf/mm = 19.4lbs / 17.9lbs
1.5x6.25 22.5mm 341gf/mm = 19.1lbs / 16.5lbs
1.5x6.50 22.5mm 316gf/mm = 17.7lbs / 16.2lbs
All the actual rates where done on an integy spring dyno using an empty tamiya shock to mount and tested over 10mm of travel. The results I got where repeatable so the number are correct. Interestingly I got 15.2lbs actual reading from my kit springs which rate as 15lbs even from the spring kit. Must make sure I don't mix them up!
