T.O.P. Racing "Scythe" 1/10 EP Touring Car
#827
What is your guys routine for diff rebuilds especially for mod ??
I have changed to ally diff halfs and ceramic balls but they seem to wear out teh diff rings rather quick.
I usually rebuild after every club meet.
#829
Ill be doing that this weekend for the nats.
The last rebuild i used Losi MIP rings that i had to dremel out a bit.
#830
Tamiya rings work well and fit perfectly... They last a while too....
Try the new black ceramics they work the best of those that I have used.... Also try and chanmge the thrust bearing to a one piece ceramic. That will improve diff life quite a bit but you should rebuild between meets anyway to get best performance.
#831
I am using teh black ceramic diff balls and the tamiya 1 piece thrust bearing.
#833
I got the rolling chassis done and I like the way it looks. I want to put on a motor guard and looking at the chassis I'll have to drill out a couple of holes to install on like on the X-ray T2.....
#834
I gave mine it's first run-out last night. Was impressed. It was my first time using a one-way and I was as quick as I was with my old car. My setup needs a bit of a tweak as it tends to 'hook' a bit in corners. Nothing some firmer strings wont fix.
#835
Tech Legend
Trader Rating: 51 (100%+)
#838
It will have online shopping soon apparently. I think it's run by EJ Evans so PM him or email ([email protected])and I'm sure he'll be able to sort you out.
As for parts, most of the breakable parts (suspension arms, hubs etc...) are all Cyclone/PRO4 parts so you can order them from most model shops.
#839
Tech Legend
Well not sure what hours I work next weekend for the Buildershow. It is the last weekend for me. If I work early I might stop down but I don't know my schedule yet.
