T.O.P. Racing "Scythe" 1/10 EP Touring Car >
Old 02-13-2008, 12:36 PM
  #796
daveaustin5's Avatar
Originally Posted by RCSpeeder View Post
The car comes with a 64P size but we are running on 48P and try 76 or 75 size and it should allow you to run from stock to modified final ratio.
Thanks again. I will be running 48p (all my pinions are 48p!) so was hoping it wasn't 64p. Nevermind, I'm guessing it's easy enough to change the spur gear?
Hopefully I'll be able to race it this weekend.
daveaustin5 is offline
Old 02-13-2008, 12:50 PM
  #797
razzor's Avatar
What is the reasoning behind running 48 pitch ??? is just for reliability in mod ??
razzor is offline
Old 02-13-2008, 06:25 PM
  #798
48 pitch the gear mesh is a lot less critical, and if you are running on a dirty track you will have far less issues with damaged gears. On our shitty tracks, 64 pitch can pick up anything as small as sand and cause a lot of damage.
Most cars i have ran 48 pitch, but i am trying to use 64 pitch so far with the TOP, in an effort to get a smaller jump in rollout, as runtime is quite an issue with the change to 5 cell mod.
Besercoe is offline
Old 02-13-2008, 08:59 PM
  #799
RCSpeeder's Avatar
Well said. The life span of a 48p spur is good and less worries especially during a race. I believe every racer has a favorite spur no and for final adjustments,could be same spur or add/less 1 spur size.
Actually no point trying too many sizes when the space between center drive to the bottom deck spur opening is already fixed and therefor limit the size of spurs.As for run time,it will depend much on the driving style.
RCSpeeder is offline
Old 02-14-2008, 02:02 AM
  #800
bulldog2's Avatar
Originally Posted by thesaint View Post
Hi Besercoe,
I am from Malaysia and we have a team of top racers going to TITC next week. We will try to catch up with you and Vincent to understand a bit of the CP chassis on the car setup. Hope to see you then.
Cheers
Simon
Hi,
Besercoe, Like the saint mentioned there will be a bunch of top drivers from Malaysia and looking forward to catching up with you when the time comes part of us will arrive on the 19 th and the rest would be the 20 th. Cya then.
Woof woof
bulldog2 is offline
Old 02-14-2008, 02:23 AM
  #801
razzor's Avatar
Thought as much it was for reliability.
64 works for me as our tracks are prepped and sugared.
also smaller gearing adjustments is better and defiantely better for mod.
razzor is offline
Old 02-14-2008, 08:26 AM
  #802
Nova F1 Racer's Avatar
Originally Posted by E.J. Evans View Post
Sorry for the delay guys, here is my setup from the Snowbirds (Carpet Rubber).
I got the kit yesterday, went through everything and the build will commence tonight......
Nova F1 Racer is offline
Old 02-14-2008, 05:57 PM
  #803
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
And hammering at the track tommorrow.
wyd is offline
Old 02-14-2008, 06:04 PM
  #804
Oh no... I am taking sweet time building it... Not for 2 weeks dude....
Old 02-14-2008, 06:14 PM
  #805
wyd
Tech Legend
wyd's Avatar
Nice. Where did you order it from? Don't forget to post some pics of it when it does and has the new Red Bull paint on it to.
wyd is offline
Old 02-14-2008, 06:43 PM
  #806
Shoot me an email at [email protected], I can address some of your concerns and questions.
WYD, see above email address...
Old 02-15-2008, 10:33 AM
  #807
Jamesalex's Avatar
Questions??
What screws do you guys use on this car as I found that when I built my chassis the flat heads didnt sit flush as if the holes are not big enough for them to sit in.
And what seems to be the best between high traction arms and carbon arms, I only ask as I dont have time to go testing before my next big race?
Any help will be great
Cheers
James
Jamesalex is offline
Old 02-15-2008, 11:04 AM
  #808
RCSpeeder's Avatar
Cheers
James
I never had this problem.Make sure you got all the screws length correct and add a drop of CA for plastic and Locktip for alloy if you wanna be safe.
We use 60% titanium and the rest is metal.
Cheers
Old 02-15-2008, 11:16 AM
  #809
GreaseMonkey's Avatar
I just checked my chassis and I can see what you mean. The screws are not perfectly flush with the chassis. It's never affected the way the car drives and the bumpers are lower than the chassis as it is.
GreaseMonkey is offline
Old 02-15-2008, 11:22 AM
  #810
razzor's Avatar
The screw edges are rounded so there is not a large flat area clamping down like other screws.
Dont worry they tight enough though
I am using titanium screws all on the top of the car and steel underneath.
razzor is offline
