Old 02-11-2008, 06:07 PM   #781
Originally Posted by Dragonfire View Post
Have had this on my chassis for the last two big meets I have been too, and won both (+TQ). I converted from a mostly plastic kit to this and it seems to have much more speed through the turns and resists slowing down. Not much else seems to be different. You can soften it up quite a bit by removing the two center screws in the upper deck. I never run the post as I can't pick the difference with it in or out, so it is just extra weight....
Just added another win to the collection with my scythe at the 1st round of the club challenge in Lithgow, Australia. Also ran the NO Mark tyres which held up quite well, if fact produced their fastest lap on their 4th run!
Just saw the results, our tie was split by less than 1 second.
I really should not have backed off those last few laps
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 02-11-2008, 10:56 PM   #782
Originally Posted by Besercoe View Post
Ran the Tip Top fella for the first time in Mod against Dragonfire above on the weekend, after some awesome results at a different track in stock the previous 2 weeks, Mod was a bit difficult, the car just has way too much steering.
But it was good to see some potential with very good corner speed, a few tweaks and it should be good. I just have to get Cyclone setups out of my head, as i didnt realise the TOP toe blocks are 1mm raised over the HPI ones, so had some crazy roll centres. Overall a Tie for 1st place so reasonably happy with its first run in Mod.
Are there any TOP racers on here attending the TITC next week? If so come look for the tall, fat white guy with the funny accent in glasses
Looking forward to catching up with Vincent, and getting my dirty little mits on the CP Chassis, as the adjustable wheel base will solve many of the problems i was encounteringon the weekend.
Hi Besercoe,
I am from Malaysia and we have a team of top racers going to TITC next week. We will try to catch up with you and Vincent to understand a bit of the CP chassis on the car setup. Hope to see you then.
Cheers
Simon
thesaint is offline   Reply With Quote
Old 02-12-2008, 02:40 AM   #783
razzor's Avatar
Anyone have any good setups fopr rubber tyre on asphalt ???
Got my Scythe running rubbers and i have so much steering its mind blowing, im running on 40% steering throw. Car is great but just catches me out every other lap with the steering sensitivity.
Ill put up my setup a little later so maybe the guys in teh know can comment or recommend changes.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 02-12-2008, 04:13 AM   #784
R/C Tech Charter Subscriber
Default Asphalt set-up
Hi Razzor,
There's some asphalt set-ups here that worked really well for drivers in the UK/Europe.
Good luck!
Keith.
keithander is offline   Reply With Quote
Old 02-12-2008, 05:17 AM   #785
razzor's Avatar
Locally teh guys are running faom tyres on Asphalt for 27T stock class but i found thecar to be so much more consistent on rubber.
I just need to learn more about setup so i can get it dialled.
Will be doing the first round of the 2008 national series in 2 weeks time.
Have 3 cars to setup for Johnson stoc, 27T superstock and Mod.
Really looking forward to it with the Scythes.
Casterracing ZX1.5R
Old 02-12-2008, 02:13 PM   #786
Jamesalex's Avatar
How has the chassis been running, you been running the flex kit top deck, what sort of set up have you been running on this car?
Jamesalex is offline   Reply With Quote
Old 02-12-2008, 04:33 PM   #787
P2
P2's Avatar
Trader Rating: 15 (100%+)
N-E-1 put an Orion 3600 lipo in their ride? and does it fit?
Thx - Paul
TopRacingUSA | Team EPIC | Thunder Power | OD Racing
P2 is offline   Reply With Quote
Old 02-12-2008, 04:39 PM   #788
GreaseMonkey's Avatar
I've run the 3200 and it's snug against the layshaft retainer. I believe the 3600 is taller so you might have to dremel the layshaft retainer a small amount. Not enough to affect the integrity, just to remove some of the curvatures that go around the Nimh cells. I also found the battery has to be mounted as far to the outside as possible or it rubs against the belt. I hope that helps.
I'm not a grown man playing with toys. I'm a hobbyist.
GreaseMonkey is offline   Reply With Quote
Old 02-13-2008, 01:22 AM   #789
razzor's Avatar
Thanks to Arno for this link :
http://www.petitrc.com/reglages/top/...sTOPScythe.htm
Found some Foam /asphalt setups
Casterracing ZX1.5R
Old 02-13-2008, 10:17 AM   #790
E.J. Evans's Avatar
Send a message via Yahoo to E.J. Evans
Default Snowbirds Setup
Sorry for the delay guys, here is my setup from the Snowbirds (Carpet Rubber).
T.O.P. Racing | APEX Hobbies | R1 | Solaris | NorCal Hobbies |
Solaris Racing Products (SRP) Solaris Spec Tires!
www.solarisrp.com | www.apexhobbies.com | www.topracingusa.com
E.J. Evans is offline   Reply With Quote
Old 02-13-2008, 10:21 AM   #791
RCSpeeder's Avatar
Hi to all Top Racing friends,
Just pop in and read all the comments from you guys and the general conclusion from all is that the car is great ! I couldn't agree more.
While using other brands in the local and national races, we managed to finish
middle of A main (Asphalt/Rubber/23t) most of the times but ever since switching to Top Scythe end of last year, on the first race in 2008, we TQ and Won ! Just wanna share with you guys that the car is easy to setup and dialed for any tracks and the rest is depending of the driver.
Looking forward to see some of you at TITC Thailand next week.
Wishing All Top Racing friends,many podiums finish !
Stephen
The Mechanic
RCSpeeder is offline   Reply With Quote
Old 02-13-2008, 11:21 AM   #792
daveaustin5's Avatar
Just purchased a 2nd hand Sythe from Ebay. Can't wait to run it! It's the original gold version, how does this differ to the newer versions? Is it easy to uprgade it to the 2008 spec?
I race carpet rubber, any tips for the car?
daveaustin5 is offline   Reply With Quote
Old 02-13-2008, 11:34 AM   #793
RCSpeeder's Avatar
Congrats of your purchase ! I suggest you service it and run it original spec and then upgrade when necessary. This way, you can appreciate the original setup before changes.
Can't help you on carpet but perhaps others will.
The new version is more of alloy parts on the central drive and you can easily add them on.
Cheers
Old 02-13-2008, 11:44 AM   #794
Cheers
Thanks,
The car was only run twice and looks brand new so hopefully it shoudn't need much of a service. What pitch gears does the Scythe run?
Old 02-13-2008, 12:05 PM   #795
RCSpeeder's Avatar
Thanks,
The car comes with a 64P size but we are running on 48P and try 76 or 75 size and it should allow you to run from stock to modified final ratio.
***** SCYTHE red " IIC 2007" edition***** spy R/C Items: For Sale/Trade 5 12-01-2007 10:21 AM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 09:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
New TEAM ASSOCIATED RC10L3 "Touring" pan car for sale. "TEAM VERSION" Ron Meloni R/C Items: For Sale/Trade 0 06-24-2003 03:37 PM
