Old 01-03-2008, 03:48 AM   #646
xray racer's Avatar
Trader Rating: 22 (100%+)
Thanks sosidge,
Whereabouts can i buy those pistons from???... they fit the yokomo shocks then i assume.
In a race a while back i was struggling for grip entirely, once the car handled well it just didnt seem to go anywhere, through the corners it still skated and just didnt get power down, and i struggled to overcome it. Any ideas there???...
Perhaps my droop was out... as you say?
This has been running a spool however. with 5.25 springs all around from memory.
Cheers, thankyou for your help once again.
Robbie
Robbie Lloyd
Yokomo * HobbyWing * Sanwa
xray racer is offline   Reply With Quote
Old 01-03-2008, 03:56 AM   #647
razzor's Avatar
For the shock we jst drill out teh pistons to 1.2mm or 1.3mm and use 35wt - 45wt oil and it feels great.
Unusual for you have lack of steering, with teh oneway it turns on a dime with the spool you get initial understeer but great steering out of corners.
I actually run my dual rate down to 45%.
Like Sosidge mentioned check droop or ride height.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 01-03-2008, 04:11 AM   #648
xray racer's Avatar
Thanks guys.
How are your chassis' setup: Kit with alloy upper bulkheads???... or all alloy???
Are either of you using a Cut or Split top deck???
Cheers, i'll keep you informed of my progress.
Robbie
Robbie Lloyd
Old 01-03-2008, 05:12 AM   #649
sosidge's Avatar
My car is plastic bulkheads, full deck.
Old 01-03-2008, 05:45 AM   #650
razzor's Avatar
My 27T kit is stock car with plastic bulkheads and full deck with a front steel spool.
Prefer its handling over the full option ally kit for use on asphalt with rubber tyres.
Casterracing ZX1.5R
Old 01-03-2008, 10:33 AM   #651
Send a message via AIM to ERTRACHTER
im running the full alloy car with full top deck kit shocks with kit large 2 hole pistons ive raised all the suspension mounts 1 mil. but ive also shortened all my camber links to the shortest setting to make the car turn and react the way i like it my droop is also at 5f 4r and traction is not even cose to becoming a problem
ASSOCIATED 12r5.1,REEDY MOTOR AND BATTERY, LRP SPEEDO,KIMBROUGH PRODUCTS,BIG DOG RACING,BELMONT R/C SPEEDSHOP, DENNIS LYMAN RACING, TEAM TOSO, TEAM FACTORY BITTER, SCHUUR SOLUTIONS, SIMMONS RACING, TEAM BOOZCRUZ
ERTRACHTER is offline   Reply With Quote
Old 01-07-2008, 09:09 PM   #652
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
hey Jason... is that on asphalt or carpet? just curious. need to get mine up to speed on the rug with rubber tires.
Wes
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 01-07-2008, 09:52 PM   #653
Wes
hey wes that is on asphalt yesterday was my first time on the rug it wasnt bad but not great either our track doesnt get real high bite ill be on the rug again on the 20th and then the birds once i find that money set up ill share with you guys
Old 01-12-2008, 01:56 AM   #654
Jamesalex's Avatar
Post Spurs
Need help on this what spurs fit this car 48dp or 64dp as i tried to fit a 48dp 84t spur in it yesterday and it would not go/?
Any ideas
Jamesalex is offline   Reply With Quote
Old 01-12-2008, 02:07 AM   #655
Jamesalex's Avatar
Default Spurs
If you run 64 dp spurs and pinions what range would you advice to carry?
Old 01-12-2008, 03:58 AM   #656
sosidge's Avatar
78t/48dp is what I run, I think you could fit a slightly larger one, maybe 1 or 2 teeth bigger, but the 78T has plenty of adjustment, I can run big pinions (30+) for 19T and small pinions for revvy 27T or mod with no problem.
Equivalent 64dp would be 104t.
Make sure you get a spur with 4 holes in the right place for it to fit. Kawada is what I use, as supplied by Much-More UK, and they are perfect.
Old 01-12-2008, 05:28 AM   #657
Kenny L's Avatar
Trader Rating: 16 (100%+)
What kind of upgrades are people doing for rubber tire carpet. Should be getting 08 kit in early next week.
Team Tekin, Ko Propo America
Kenny L is offline   Reply With Quote
Old 01-12-2008, 07:44 AM   #658
sosidge's Avatar
Car is great for rubber tyres out of the box. The only significant parts that I am using that are not in the box are some Rayspeed shock pistons with bigger holes and the optional steel spool.
I would run the car plastic and without bars unless the grip is high.
Apart from that just build the car and run it!
Old 01-12-2008, 08:10 AM   #659
Kenny L's Avatar
Thanks sosidge.
I will be running it next weekend at a Snow Birds warm up. Then its off to Snow Birds. How many Team Drivers are going to Snow Birds?
Old 01-12-2008, 11:49 AM   #660
i think there will be 4 of us pitting trackside if you need any help at the birds just come find me my name is jason
***** SCYTHE red " IIC 2007" edition***** spy R/C Items: For Sale/Trade 5 12-01-2007 10:21 AM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 09:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
New TEAM ASSOCIATED RC10L3 "Touring" pan car for sale. "TEAM VERSION" Ron Meloni R/C Items: For Sale/Trade 0 06-24-2003 03:37 PM
