Old 03-18-2007, 04:31 PM   #331
GreaseMonkey's Avatar
Thanks for the tips. I'll try them.
I had the car out today but for some stupid reason, one of the boards was left loose, I came a little wide around the corner and the edge of the board caught my right rear wheel. Managed to rip the hub out of the control arm and snap the pin that goes through the hub. Of course I didn't have any spare pins so my day was done after about 5 laps. I did decide to spend the rest of the day trying to see if my T2 suspension will fit in. Sadly, it manages to move the whole suspension back about 5-10mm so it's not going to work. Pity.
I'm not a grown man playing with toys. I'm a hobbyist.
GreaseMonkey is offline   Reply With Quote
Old 03-21-2007, 07:36 AM   #332
Default Shock Building
Be carefull building the shocks, make sure you install the Triangle shaped spacer, but then check to see if it operates smoothly. There is some internal machining on the stock shocks which can cause the pistons to catch on the lip, its worse if you dont use or shorten the tri spacers. Hot mod is to install the Tamiya PTFE pistons.
Tweaky is offline   Reply With Quote
Old 03-21-2007, 08:40 PM   #333
DZ
Do they fit with out any mods???
DZ is offline   Reply With Quote
Old 03-22-2007, 06:17 AM   #334
MadBrushRacing's Avatar
They should be a straight fit. I have heard that the UK Yokomo team also use the Tamiya kit diaphragm as it is a bit harder.
MadBrushRacing is offline   Reply With Quote
Old 03-22-2007, 01:59 PM   #335
Ali Graham's Avatar
Send a message via MSN to Ali Graham Send a message via Yahoo to Ali Graham
Tamiya diaphragms and pistons fit without any trouble
Mirage Racing | Team Xray | Nosram | Atsushi Hara Racing Products | Team Orion | Hudy | Apex Models | Much More Racing | Exit13 | NinjaGraffix | ali303.8.dtiblog.com
Ali Graham is offline   Reply With Quote
Old 03-24-2007, 03:51 PM   #336
Ali Graham's Avatar
Hi guys,
Today I went testing at the Halifax track again, this time in much better conditions and also running a brushless system. The car was awesome and ballistic!
Short video here: http://www.youtube.com/watch?v=1XFU3W7S3Bw
Old 03-24-2007, 04:37 PM   #337
I got my car running quite nicely now after an evening of racing on wednesday. It still needs little fine tuning but it's quite good right now.
I have found one issue that I'm having trouble with. The holes in the chassis for the servo are just a little too far apart and I can't fit my servo without the ears bending and weird angles on the mounts.
Anyone else have this issue?
Old 03-24-2007, 04:54 PM   #338
luke humphrey's Avatar
wow!, lookin good ali, was it a 3.5 brushless???
luke humphrey is offline   Reply With Quote
Old 03-24-2007, 05:03 PM   #339
Ali Graham's Avatar
GreaseMonkey, if it's just the plastic servo supports you're having trouble with, then there's no problem running them at a slight angle. Mine are slightly bent and there doesn't seem to be an issue.
Luke, certainly was!!!! Sure beats 27t
Old 03-24-2007, 06:05 PM   #340
Thanks, it just seems a little weird. If I run a servo that has open ears, the servo will pull out of the mounts.
Old 03-25-2007, 03:47 AM   #341
If you look closely at the servo supports, you can see that they can be positioned in two different ways, for narrow and wider servo's. I also had this issue with my Hitec servo, wich is narrower than most servo's.
Stevenkoiter is offline   Reply With Quote
Old 03-25-2007, 03:57 PM   #342
Phil C's Avatar
Looks slow Ali
| Team XRAY UK | HUDY | RC DisCo| LRP | Sanwa | SMD | Moorespeed | MB Models | Gingapaint | McLaren Racing |
Phil C is offline   Reply With Quote
Old 03-25-2007, 03:57 PM   #343
I found that out today at the track when I put in a new servo. I'm really happy with how fast this car is after a little bit more fine tuning. Picked up 2 laps and there's more in the car.
Old 03-26-2007, 10:17 AM   #344
Ali Graham's Avatar
Originally Posted by Phil C
Looks slow Ali
Openly giving a negative comment on products you're supposed to be promoting
Old 03-26-2007, 02:14 PM   #345
tbeardmore's Avatar
I don't think he was knocking the Car, or the Motor.... (I think he was talking about the DRIVER)...??? Hmmmm
BMI DB10R, Corally RDX PHi, BMI 12R..!!
Need a "real" car... contact me at:
www.beardmorechevy.com -or- www.beardmoresubaru.com
tbeardmore is offline   Reply With Quote
***** SCYTHE red " IIC 2007" edition***** spy R/C Items: For Sale/Trade 5 12-01-2007 10:21 AM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 09:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
New TEAM ASSOCIATED RC10L3 "Touring" pan car for sale. "TEAM VERSION" Ron Meloni R/C Items: For Sale/Trade 0 06-24-2003 03:37 PM
