Old 03-10-2007, 02:58 AM   #316
Ali Graham's Avatar
Send a message via MSN to Ali Graham Send a message via Yahoo to Ali Graham
Originally Posted by Dan415ms
Looking good Ali! She'll go well at Stonehaven (another huge track for electric)!
Can you post your setup from the video?
T.O.P. Racing "Scythe" 1/10 EP Touring Car-halifax-testing-dry-setup.jpg
Mirage Racing | Team Xray | Nosram | Atsushi Hara Racing Products | Team Orion | Hudy | Apex Models | Much More Racing | Exit13 | NinjaGraffix | ali303.8.dtiblog.com
Ali Graham is offline   Reply With Quote
Old 03-12-2007, 06:33 AM   #317
MadBrushRacing's Avatar
Well had another good meeting at Carpetwars yesterday. Didn't make the A but ended 5th in the B (missed it by 6 seconds ).
Once agian the car was good all day.
Roll on the SLCC in April, back outside again.
MadBrushRacing is offline   Reply With Quote
Old 03-12-2007, 11:40 AM   #318
Ali Graham's Avatar
I gave the Scythe some more outdoor running yesterday at the popular Bedworth outdoor track. The layout is quite challenging and some parts are uphill, others are downhill, and there are quite a few nasty bumps as well!
The car seemed to hold up to the rigours of 5 cell modified well, and by the end of the day the car was almost perfect for my liking.
Here is a good video showing the good, close racing between myself (purple/white car) and Phil Chambers (white/blue/black) running a HB Cyclone (he certainly pulled some good manouvers!). The video is compiled of various clips taken at different times of the day, so you will see both cars' handling alter slightly throughout: video
Old 03-12-2007, 11:46 AM   #319
Dan415ms's Avatar
Where's the video link mate?
Dan415ms is offline   Reply With Quote
Old 03-12-2007, 11:52 AM   #320
Dan415ms's Avatar
Guess this is it Ali:
http://www.youtube.com/watch?v=HOIpXJfg34k
Old 03-12-2007, 12:05 PM   #321
Ali Graham's Avatar
oops! post adgusted
Old 03-12-2007, 12:41 PM   #322
Dan415ms's Avatar
Your car looked dialled there mate
Send me the setup as I'm supporting Gareth Hunt with his Scythe at the Juniors @ Bedworth in July!
Old 03-12-2007, 01:42 PM   #323
Patrick (HLR)'s Avatar
This weekend will be my first outdoor experience with the scythe. Even this year my first modifed year. It will be a clubrace at our home track :
http://www.amcaracing.nl
And in April the dutch naionals will start too
Hang Loose Racing
TOP Photon - GM 120 - BL motors (10,5 -13,5) - KO Servo - 3pk + Spektrum
Patrick (HLR) is offline   Reply With Quote
Old 03-13-2007, 03:27 AM   #324
MSB
MSB's Avatar
Send a message via Yahoo to MSB
Default Spring rate
Sorry Guys,
It is probably in a old post, but do you know what kind of springs Scythe have in standard box (in lbs)?
cheers
Miguel S. Braga
MSB is offline   Reply With Quote
Old 03-13-2007, 04:37 AM   #325
Victor A's Avatar
Click here for some pictures and tekst of the building proces of the TOP Scythe.
Greetings Victor
www.RcTouring.EU
Victor A is offline   Reply With Quote
Old 03-17-2007, 03:42 PM   #326
GreaseMonkey's Avatar
I just picked up a Scythe while I was in Hong Kong and I finally got to build it yesterday. The kit went together really smoothly considering I forgot to print out the instruction manual so I was just going off the parts diagram thing they include.
However, I do have a couple of issues. The first is more of a complaint but not really a big issue. The spur gear installation is a pain in the ass. I'm sure if I ever need to change the spur, more than a few foul words will be muttered. However, it's not a big issue and I'll live with it.
The other issue also isn't a huge issue but a little more frustrating. I can't get the front ride height above 5mm. With the shocks screwed all the way to the bottom, I'm at 4.5mm to the chassis and 4mm to the front bumper. Why the bumper is lower than the chassis, I don't know but I do know that it's a Yokomo bumper and it's the same on Yokomos. Now, I did use the short lower ball caps on the shocks. Changing to the longer ones should fix the problem.
Apart from that, I put the car on the track with no tuning and no body and was surprised at how well it drove. Initial turn in was amazing but coming out of the corner, the car tried to swing the back end around. I think this car has a lot of potential.
I'm not a grown man playing with toys. I'm a hobbyist.
GreaseMonkey is offline   Reply With Quote
Old 03-18-2007, 11:25 AM   #327
My first outdoor race with the Styhte was cancelled due to lots of rain overhere . Hopefully within two weeks we can try again .... hopefully on a dry track
@ Grease Monkey : take a look at some earlier posts , i had also some issues with the dampers too but after the tips my problem was gone.
Hang Loose Racing
Old 03-18-2007, 01:17 PM   #328
Ericjooopuntnl's Avatar
The first problem you will get used to, i changed my spur today three times and i get quicker each time
The ridehight-problem could come by the bushes in the dampers. i cut mine short so you can get the rideheight and the droop. For the bumpers there is a part which levels the bumpers to the chassis: Front & Rear Bumper Height Spacer Set, prt# PO-SCH010
Regards,
Eric
Ericjooopuntnl is offline   Reply With Quote
Old 03-18-2007, 02:28 PM   #329
sosidge's Avatar
I think everyone has a different method of getting the required length from the Yokomo dampers!
What I do is unthread the shock bottom a few mm. Then if possible I put an o-ring or low-friction spacer on the shaft so the exposed threads don't risk damaging the seal (making sure uptravel is not affected).
I leave the internal triangle-shaped spacer intact. My opinion is that it supports the shock shaft and keeps everything lined up.
I think I was built all 4 shocks to 62mm for the Scythe. I did put a post up earlier in the thread wth my build tips.
For the bumpers, I just trimmed the extra mm with a sharp knife. I didn't know about the parts mentioned above to space it, maybe they would be a neater solution.
Last edited by sosidge; 03-18-2007 at 02:29 PM. Reason: My typing is getting really dodgy
Old 03-18-2007, 03:02 PM   #330
Ali Graham's Avatar
The easiest way to solve the first problem is by using the perfect screwdriver! I orignally thought the same thing...but managed to find a small Philips head screwdriver that fits perfectly and makes changing spur a breeze.
As for the shock lengths/ride height...try using a 2mm spacer inside the shock body instead of the triangle piece
The low bumper plate can be solved with some 1mm shims underneath the plate, or you could buy the part mentioned by Eric.
***** SCYTHE red " IIC 2007" edition***** spy R/C Items: For Sale/Trade 5 12-01-2007 10:21 AM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 09:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
New TEAM ASSOCIATED RC10L3 "Touring" pan car for sale. "TEAM VERSION" Ron Meloni R/C Items: For Sale/Trade 0 06-24-2003 03:37 PM
