Old 02-04-2007, 11:23 PM   #256
Ericjooopuntnl's Avatar
Patrick/Ali,
I think the 2.5mm chassis, thicker topdeck and shocktowers will weight more than the 2.0mm Goldversion. For the looks i say, use the alloy. If you want to loose weight than make it a "black plastic edition".
I will perform the coming week my shakedown of the Red Edition.
greetz,
Eric
Ericjooopuntnl is offline   Reply With Quote
Old 02-04-2007, 11:55 PM   #257
@ Ali,
What is your opinion about the spool (you drive modified?), i like to put it in (it also weights less ) but i'm not sure if it works with 19T indoor.
Eric
Old 02-05-2007, 10:02 AM   #258
Ali Graham's Avatar
Send a message via MSN to Ali Graham Send a message via Yahoo to Ali Graham
@ Patrick, I'm not sure how my car was quite so light!
I ran:
Futaba 9550 servo (very small)
KO 301F receiver
KO vfs-1 speedo
Checkpoint based modified
Team Almighty 5 cell packs (4200)
I only ran a stabilizer on the front so that would help with the weight. I also used carbon fibre suspension arms, 2mm std chassis and titanium screws on the top of the car. To lose more weight, I would try the Hybrid front bumper (much smaller than standard).
With the heaviest shell I own (PF mazdaspeed 6), the car weighed just under 1400g, and with a lightweight type shell, this is dramatically reduced. I also had a very heavy steel spool in the car, so a lighter version would help. I think the areas of the car that could be lightened would be the use of Ti screws (easy change), the use of titanium driveshafts, and maybe using some plastic parts.
@ Eric, the car works great with a spool, especially in modified, and I feel it is pretty good in 19t, especially if the track is small and tight. On a more flowing track, I'd recomend sticking with the one-way.
Mirage Racing | Team Xray | Nosram | Atsushi Hara Racing Products | Team Orion | Hudy | Apex Models | Much More Racing | Exit13 | NinjaGraffix | ali303.8.dtiblog.com
Ali Graham is offline   Reply With Quote
Old 02-05-2007, 11:48 AM   #259
Patrick (HLR)'s Avatar
Ok Thx's a lot Ali
I know what to work on
are all parts Top Racing ?
Hang Loose Racing
TOP Photon - GM 120 - BL motors (10,5 -13,5) - KO Servo - 3pk + Spektrum
Patrick (HLR) is offline   Reply With Quote
Old 02-05-2007, 12:00 PM   #260
Send a message via AIM to Alex Lopez
Originally Posted by E.J. Evans
Made a short video of the Scythe.
http://www.youtube.com/watch?v=hUU7j59EMd8
Background music "Symphony No. 9"
EJ- thats a fast stock car. Reedy Race?!?!! LOPEZ RUNS MOD!!!!!!!!!!!
Alex Lopez is offline   Reply With Quote
Old 02-06-2007, 02:14 PM   #261
Ali Graham's Avatar
Originally Posted by Patrick (HLR)
Ok Thx's a lot Ali
The carbon fibre arms are HPI items (as are the standard ones)
The titanium screws are from Take Off
The small front bumper is from Hybrid
And the steel spool is from Speedtech.
HTH
Old 02-13-2007, 12:01 AM   #262
@ Ali,
How are your CVD's handling with Mod-motors? The Universal Pins seem a little fragile, we destroyed three already....
greetz,
Eric
Old 02-13-2007, 12:18 AM   #263
DZ
Originally Posted by Ericjooopuntnl
@ Ali,
greetz,
Eric
Eric,
The pins get destroyed when thay come loose, try a bit of loctite to secure the grub screw in place
Cheers
Damien
DZ is offline   Reply With Quote
Old 02-13-2007, 01:22 AM   #264
zacabrandy's Avatar
Hi guy's,
Im a little lost and hoping someone can help me out.
On the Top Racing Scythe Set Up sheets, there is a setting on the Rear Suspension section for an "UPRIGHT SPACER". What is this and where do I find it on the car. Also what does changing it do?
It's probably very obvious but in the info and build guide there is nothing there that mentions it and I can't seem to find any parts listed for changing this setting.
Cheers
Aaron
zacabrandy is offline   Reply With Quote
Old 02-13-2007, 01:42 AM   #265
its the gold or red shims which go in front znd befhind the rear hub , this can be adjusted to lengthen or shorten the wheelbase
thanks jimmy
jimmy..maddison is offline   Reply With Quote
Old 02-13-2007, 02:32 AM   #266
thanks jimmy
Hi Jimmy are you all pumped about running at the TITC. It will be a ton of fun, there are half a dozen of us coming over. Last year was a ball with more mates around it can only get better.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 02-13-2007, 03:53 AM   #267
im sure its gonna be awesome fun, make sure theres plenty of nite action
when do you fly out??
jimmy
Old 02-13-2007, 09:47 AM   #268
Ali Graham's Avatar
@ Ali,
greetz,
Eric
They tend to come loose if you don't check them after every few runs, when running in the modified class I tend to check them as often as possible (every 1-2 runs). This problem may be magnified outdoors in the mod class, as this is where the std Yokomo versions (basically the same as the Scythe's) were very very bad.
Old 02-13-2007, 11:18 AM   #269
Damien & Ali,
Thanks.....but Loc-Tite was alread used.....maybe i have to try some after-market CVD's for a Vector 4.5.....otherwise there will be some more joints killed
Greetz,
Eric
Old 02-13-2007, 03:57 PM   #270
DZ
jimmy
yes there will be lots of fun
You have Pm Jimmy
Cheers
Dz
***** SCYTHE red " IIC 2007" edition***** spy R/C Items: For Sale/Trade 5 12-01-2007 10:21 AM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 09:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
New TEAM ASSOCIATED RC10L3 "Touring" pan car for sale. "TEAM VERSION" Ron Meloni R/C Items: For Sale/Trade 0 06-24-2003 03:37 PM
