T.O.P. Racing "Scythe" 1/10 EP Touring Car >
Old 01-14-2007, 10:04 PM
  #196
rckenon.com has the car and red option parts in stock.or rc11.net has a red kit listed not sure it has all the red bling in posted picture on this forum.
lance is offline
Old 01-14-2007, 11:34 PM
  #197
Rod M's Avatar
Originally Posted by wallstreet
who sells the red version of the car ?
I believe all importers/retailers of the scythe will be able to order in the red version
Rod M is offline
Old 01-14-2007, 11:42 PM
  #198
Rod did u get my email?
jamie814340 is offline
Old 01-15-2007, 12:37 AM
  #199
Nice looking TC guys. I have one question about the Motor Coolers I have seen on some of your cars. Are those put on after you run or do you run those when on the track? They look HUGE and Heavy!
Just curious because I don't race TC.
ApexPredator is offline
Old 01-15-2007, 01:57 AM
  #200
AngryAsian's Avatar
The motor coolers chill the motors before a race or in between heats..
They're not actually run IN the car during a race!
Actually - they run of an external 12V PSU... cold enough to have ice forming all over the motor and the peltier unit.
AngryAsian is offline
Old 01-15-2007, 05:57 AM
  #201
MadBrushRacing's Avatar
Ran the car yesterday for the first time on carpet and was very impressed, managed to get up a final which always helps!
Ran it as kit and had to put 90grams on to get to the weight limit! May have to think about 5 cell mod this year.
MadBrushRacing is offline
Old 01-15-2007, 06:06 AM
  #202
i tqd and won yesterday at the british indoor winter series with my ''team almighty'' powered scythe
jimmy
jimmy..maddison is offline
Old 01-15-2007, 11:34 AM
  #203
Ericjooopuntnl's Avatar
And the results are coming in....sounds good guys
greetz,
Eric
Ericjooopuntnl is offline
Old 01-16-2007, 02:13 PM
  #204
Default Springs
Hi Jimmy
What springs do you use on your car?
Old 01-16-2007, 03:18 PM
  #205
JRXS_chris's Avatar
Originally Posted by Ali Graham
Hi Eric
As I understand things, 100 limited edition kits were sold in the UK in the red colour instead of gold, and these have now sold out. I don't know if T.O.P are going to change the colour and chassis of the standard car as of yet, but I'm sure it would be in response to various drivers' opinions, ie red looks much cooler The 2.5 chassis will give less grip, which would also lower the need for the alloy bulkheads, but if they use the USA spec 2.5 chassis, this allows for wheelbase adjustments on the suspension arms, a very useful tuning tool the std car doesn't have.
If this change is supposedly for a 2007 model, I'm sure it will be released soon, and I'm also sure we will see many interesting things on the car at the TITC coming up in a month and a bits time.
blah, blah, blah
It would have been rubbish at the endurance race!
JRXS_chris is offline
Old 01-17-2007, 09:39 AM
  #206
Ali Graham's Avatar
Originally Posted by JRXS_chris
blah, blah, blah
Ssssh Lousy boy
Ali Graham is offline
Old 01-17-2007, 04:22 PM
  #207
DZ
Originally Posted by Ericjooopuntnl
@Damien.....
How went things today?
greetz,
Eric
So I ran the car on the weekend on foams ashphalt at our Summer nationals warm up, car handled beautifully, I set TQ and the faster lap of the day in Stock
Here is my set up
2.5 US SPec chassis
FRONT
-Tamyia Shocks 3 hole 45 weight oil (used tamiya shocks so I could take advantage of longer xray springs
- Xray purple Springs 30 LB
-Shock postion standard
-2mm on uppper link longest link,
-1mm below blocks
-NO front arm sweep 0 degree bblock
-3mm in front of arms and 3mm behind arms
-No sway bars
-5mm ride height 2mm droop
-Akerman block all the way back
REAR
-Tamiya shocks 3 hole 45 weight
-Dark blue xray springs 25 LB
-Shock position one lower then standard
-.5mm on upper link longest link,
-1.5mm below blocks
-3 degree rear toe.
-2.5mm in front of arm
-2mm in front of rear hub
All alloy bits used.
mazda 6 body
40 rear foams all around
D/R 70 %
This set up is very agressive but holds so much corner speed.
Hope I get a good result this weekend at the actually event
Enjoy
Damien
DZ is offline
Old 01-17-2007, 06:35 PM
  #208
E.J. Evans's Avatar
Thumbs up Pics
Just sharing some pics of my car.
Attached Thumbnails T.O.P. Racing "Scythe" 1/10 EP Touring Car-img_0053.2.jpg
E.J. Evans is offline
Old 01-17-2007, 06:36 PM
  #209
E.J. Evans's Avatar
Thumbs up Pics
With the brushless.
Attached Thumbnails T.O.P. Racing "Scythe" 1/10 EP Touring Car-img_0280.2.jpg
Old 01-17-2007, 07:19 PM
  #210
Suspended
Nice clean ride buddy. I got one in pieces after a crash, but it was almost idential.
abusedrc is offline
