T.O.P. Racing "Scythe" 1/10 EP Touring Car
#1546
I got to see the car on the weekend and I imagine it would switch easily enough to a rubber car.
#1548
Does anyone know where I can get the Hybrid Front Spool for this car? I think the part number that I saw for it was PO-SDT113RD.
Also, could one of you guys that's running this spool please measure it for me? I need to know how far it is from bearing to bearing on the inside in mm. Trying to see if it will work on my Kyosho car.
Thanks,
Canyon
Thanks,
Canyon
#1549
mikky - Not yet....lol....
Keith - Thanks and yes, this one will make it to full production. I believe everything is in full production now with already some parts/pieces coming in and are ready, others were checked and then sent out for anodizing as they will be ready next week. From the e-mails I've recieved, the minor updates that we worked on after this first car that I've been running are coming along great and things are progressing to the finished product... Speaking of which, I have to get back to these instructions!!
Here's a little update from this past weekend Fastcat's Holiday Challenge: 2nd leg of the Northeast Grand Slam Series:
I arrived on Friday to get set-up and run some practice with my TC, 1/12 and try to finish building my WGT car. The Photon was decient from the start and I only did some tire testing to try and find which tires I entended to use all weekend (Jaco Pinks). The lap times were ok, and I knew the track would change a lot so I decided to work more with my 1/12 (it wasn't all that great) and finish building the WGT.
Satruday I practiced a little more and thought that I was on pace. The first qualifier showed though that Kevin Hebert definatly had a great set-up on his car now and he was definatly going to be tought to beat. I still managed 2nd but was quite off the pace. I worked a lot on the set-up the next few runs and while I was able to close the gap to 3 seconds, it was still no where near where I wanted to be and the car was actually generating too much traction which caused it to lift both front and rear tires depending on the corner (on/off throttle). Needless to say, a bunch of thrash practicing after qualifying and I was able to greatly improve the set-up with changes to the front shock position on the front a-arm, front spring, front and rear camber links, ackerman and I think some others as I was just changing a lot super fast...lol.. In the end, it was much more consistant with better lap times but still was missing just a little more. I left it for Sunday to see how it would fair in the final round of qualifying.
Sunday I was on pace that would have been very close if not beat Kevin's TQ by .5-1 second but a crash with a minute to go ended my chances for 3 TQ's. The car still needed a little more so I changed the front width and rear diff tension for the final. In the final the car wasn't faster but just that little bit better that I needed. I was able to put good pressure on Kevin and a small bobble put me up front. From there, I just protected myself for a few laps and then stretched out a few car lenght lead when he made a mistake that left me in the clear to take a clean sweep of all 3 classes.
The car was quite good in the end and it was a great confidence builder to beat one of the top TC racers on foam tires right now. Kevin has had great runs in the 10.5 class the last year and has been runner up at the last few mod races so I know that the car is definatly on pace. Scary to think though that I still don't have all the details ironed out and I feel the car still has so much more to offer!! Let alone the minor adjustments for production that I know will make the car even better... I am very confident now, that we have a top (no pun intended) contender and have the potential to raise the bar in the TC market.
#1550
Thanks,
Canyon
Thanks,
Canyon
#1551
#1552
hey all
Just picked up a used scythe.
I will be running 10.5 BL rubber on ashphalt.
Couple of questions I hope you can help with:
1. It needs a new spool .. is it a yokomo BD item .. what will fit?
2. It has both the std and the lower ratio drive train set .. what is the theory and merits of each one.
3. It looks like a hardcase lipo will not fit under the centre bulkhead which is shaped for cells .. whats the solution ... and dont say use cells!!
Any other tips gratefully recvd .. thanks guys.
#1553
hey all
#1554
hey all
2. Bigger pulleys give a smoother drivetrain with less belt skip. Only issue is that the different internal ratio might make it harder to gear some motors.
3. Never run a LiPo in it so can't comment.
#1555
Sounds like a fundamental lack of grip! Are the tyres right for the conditions?
The TOP has always had a lot of steering, I often have a problem with the tail stepping out when the grip is low, although I have never had a problem with on-power understeer at the same time.
The only thing that looks slightly unusual there is the camber link spacing and roll centrre shims, it all seems a mm or so below what I would run. I run 2mm spacers on the bulkeads and 2mm under the front blocks, 1mm under the rear.
I often find that if a car is erratic on low grip that a setup that limits roll (higher roll centre and/or stiffer springs, possibly a bar) helps as it stops the car moving around so much and keeps it more responsive. I find that super-soft settings on low grip make the car ponderous and harder to be consistent with.
Thats something i'm still coming to grips with after all this time with the scythe, is that in some circumstances the opposite to what you think actually works, well... to what I think anyway lol.
I'll be sure to try what you've suggested over the coming week or so.
What you've said about the car being ponderous and less consistent sounds alot like what is happening.
Another thought to the equation is my shock oil, perhaps it was too light???... i'm running xray 30wt.
Have you experimented with the front toe blocks also???... from what i recall reducing the stagger reduces the amount of initial bite... is that correct?... so, changing from the front 2.5 deg to a 2.0, or 1.5, would result in a less aggressive car???
Cheers
Robbie
#1556
Thanks for the Info Sosidge.
Cheers
Robbie
Cheers
Robbie
Front toe-blocks should make the steering less sharp as you decrease the sweep angle. I have the 1.5 on mine, the boxed ARP kits are shipping with 0.
#1557
I run the Much-More oils, typically #500 in the front and #450 in the rear with the Rayspeed "big hole" pistons. I found that the big hole pistons make the car a bit more settled and generate a shade more grip.
Interesting to see the change to the ARP kits.
#1558
hello
I have three questions:
which is the best No Mark tires for asphalt track low/med grip ??
And for Carpet track??
And the No Mark tires are better for CS tires and RP or not??
thanks in advance.
Best Regards.
Pedro Silva
thanks in advance.
Best Regards.
Pedro Silva
#1559
#1560
hey all
1. I believe the BD spool will fit. But we have a new spool for the Scythe/ARP that works great. You might be interested in this.
2. I use the 37/17 pulley set and run our white pulley in the rear. It uses 3mm diff balls spread further apart from center. It's smoother and last much longer.
3. I run a SMC lipo and it rests up against the two button head screws of the center bulkhead. It works fine, I ran it this way at the Reedy and so did Kevin Jelich who won open modified.
you can contact TOP Racing USA at [email protected]
EJ
