Old 02-15-2006, 08:29 PM   #1
RAD Dog Racing's Avatar
Default Much More Cell Master settings for IB3800
I have just purchased a Much More Cell Master and I need to know how to set it up for IB3800 batteries.
RAD Dog Racing is offline   Reply With Quote
Old 02-15-2006, 08:32 PM   #2
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
I've found excellent results with a 6 amp linear charge and 20 mV cutoff. If it's cold in the area you're at, use 22-23 mV, and around 17-18 for when it's hot.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 02-15-2006, 10:06 PM   #3
Send a message via AIM to g_bruin Send a message via Yahoo to g_bruin
Check out Nexus Racing
They have posted stepped charging profiles for various batteries and conditions.
g_bruin is offline   Reply With Quote
Old 02-15-2006, 10:09 PM   #4
BringItOn's Avatar
how hot do your packs come off? i thought it was recommended 5mv
BringItOn is offline   Reply With Quote
Old 02-15-2006, 10:12 PM   #5
Nexus Racing's Avatar
if you want to try linear charging, what Brian McGreevy posted is pretty good to start with. For mod racing, you may set delta peak at 03. if it's cold, you may try batt. warming tray. One of MuchMore drivers used it at the birds with really good result.
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 02-15-2006, 10:16 PM   #6
My packs come off between 125-130 degrees.
USVTA Member #211
Old 02-16-2006, 09:42 AM   #7
DaveW's Avatar
I have been experimenting with upping the amp rate instead of the cutoff rate. (cooler weather) Using the CTX mode i charge 8.5 amps for the first and third stage... .02 for the second. The cutoff is 10. The IB3800's always hit the cutoff peak, and never hit temp peak, they never go above 35-38C. Since i have been running stock and 19T, the runtime loss doesnt matter. The packs just plain rip though, average volts at a 10 amp cycle are over 7.6VDC. They were mid 7.2VDC when new. I store my cells with 700MAH weekly, using the capacity cutoff/linear charge on the CTX charger. Before use i discharge at 10 amps, and then put them on the ZERO-V tray to warm the cells, and then they are ready for charging. If i want a bit more rip for the first few laps, i add a 10W.2 OHM resistor across the tabs of the battery for 30 minutes AFTER i bring it off of the ZERO-V tray, and all the lights go out. The packs only have maybe 10 track cycles on them, so i have no long term info to report, but they sure do rip for now. Just thought i would share.
- DaveW
DaveW is offline   Reply With Quote
Old 02-16-2006, 08:12 PM   #8
Thanks for the input, this will give me something to start out with.
MUCH MORE CELL MASTER (2)/ MUCH MORE MOTOR MASTER Chris08527 R/C Items: For Sale/Trade 4 03-19-2008 09:20 PM
MUCH MORE MRE CELL MASTER / MOTOR MASTER m3ndo5a R/C Items: For Sale/Trade 11 08-15-2007 09:44 AM
MuchMore CTX Cell Master, Motor Master, CTX-D Discharger, Tire Warmers domo Australia For Sale/Trade 2 05-28-2007 04:14 AM
FS/FT: TEAM MUCH MORE Motor Master & Cell Master litespeed-dom R/C Items: For Sale/Trade 15 06-15-2006 08:44 PM
Team Much More Racing CTX Cell Master and CTX Motor Master letitroll R/C Items: For Sale/Trade 7 11-18-2005 11:25 AM
