Best traction compound >
Like Tree11Likes
Old 06-19-2018, 03:26 AM
crusty's Avatar
Default Best traction compound
Ok guys whats your thoughts on the best traction additive for a low grip large outdoor track using rush 36 tires
crusty is offline
Old 06-19-2018, 04:33 AM
Super Moderator
Marcos.J's Avatar
Trader Rating: 221 (100%+)
Clean the tires with brake cleaner then put wd-40 best combo here in Florida for asphalt
skater-deez1 likes this.
Marcos.J is offline
Old 06-19-2018, 04:41 AM
Mighty Gripper V3 works well for me.
rccartips is offline
Old 06-19-2018, 05:04 AM
crusty's Avatar
what color though?
crusty is offline
Old 06-19-2018, 05:06 AM
skater-deez1's Avatar
Trader Rating: 73 (100%+)
Thumbs up
This was my regiment before trying motiv's lg2 which works well but maybe too well as it slowed times by providing too much grip. Funny though since I had a guy say it doesn't work because "over time" the brake cleaner would "dry the oils" in the tires. Which i thought was funny because there's really no "over time" when racing asphalt since you're lucky if a set lasts more than a day on asphalt, But I digress, this has proven to work well where I race in Maryland(asphalt). On our indoor carpet track we use the petroleum based gojo which also seems to work well on asphalt too but not as well as wd40.
Marcos.J and dawgmeat like this.
skater-deez1 is offline
Old 06-19-2018, 05:27 AM
daleburr's Avatar
There is no 'best traction compound'. It varies with track surface and temperature.
In the UK we use a single control tyre for our nationals, but the additive used varies at each venue.
Best bet is to ask the fast racers at the circuit you're racing at. And hope they tell the truth...
daleburr is offline
Old 06-19-2018, 05:57 AM
ASM
ASM's Avatar
Trader Rating: 28 (100%+)
Originally Posted by crusty View Post
what color though?
Red....with warmers.
ASM is offline
Old 06-19-2018, 08:51 AM
KE4PJO's Avatar
Paragon...
KE4PJO is offline
Old 06-19-2018, 09:37 AM
DesertRat's Avatar
Sight unseen I would start with the original blue dot Trinity Buggy Grip.
Other options include Tire Tweak, Black Can Paragon, or even Liquid Wrench rust penetrant.
DesertRat is offline
Old 06-19-2018, 02:36 PM
Trader Rating: 22 (100%+)
I agree with LG2 for sure. Clean the tires with it on a cloth and leave just a very thin coating on the tire when done cleaning it. Let it air dry, 15-20 min should be enough, and they are ready to go. They should be dry but tacky when you put the car down. They will be sticky enough to put heat in the tires on the first lap or two and you'll be good from there. That's key for me, getting heat in the tires early.
Troy Carter is offline
Old 06-20-2018, 12:35 AM
Mighty Gripper Yellow or LRP Top Grip Carpet.
Old 06-20-2018, 04:35 PM
eR1c's Avatar
Ive always cleaned my tires w/ Simple Green, been doing that for years. You guys clean w/ break cleaner? ...anyone using Simple Green??
I like that SG is non toxic, ...It seems to work well to get all the crap off after a run/race. ...then I go over w/ Paragon for grip on asphalt.
eR1c is offline
Old 06-20-2018, 04:59 PM
fat500's Avatar
Trader Rating: 38 (100%+)
paragon white, black, trinity tire tweak all 3 work different on diff days here in south fl. hence i carry all three in my box . temp dictates which one i will use which varies throughout the day...sun, clouds, slight shower...back to sun.
get two or three that your locals run and see what works best for you. good luck...have fun
fat500 is offline
Old 06-21-2018, 12:28 AM
Did anyone try WD40?
PaulWa11 is offline
Old 06-21-2018, 07:07 AM
kevinatfms's Avatar
Belt Conditioner from the auto parts store.
kevinatfms is offline
