Old 02-15-2006, 10:32 AM   #1
Default Orion V2 element motor
I have just ordered one of these for my TC3.
I am new to this game so 2 questions (please explain in simply)
1. What gearing for dossing about in carparks, bit of drifting etc..., what do I need to buy to acheive it, I have been told to gear it to 6.0. what does this mean and what do I need to buy.
2. How do you run it in. Just drive slowly? if so for how long.
Sorry for the stupidity but I will learn!
oakesy2001uk is offline   Reply With Quote
Old 02-15-2006, 11:13 AM   #2
XrayFK's Avatar
Since you're not racing, I'm going to assume you want the comm and brushes to last as long as possible. Use the Enduro brushes with hard springs on bothe + and - side. Gearing to 6.0 is the final drive ratio (FDR) That means the spur/pinion*the internal ratio, which on the tc3 I think is 2.5. www.gearchart.com will help with all your gearing issues The Element really likes to be geared tall, but that is for racing. Start the gearing at 5.8 and see how hot the motor gets after 5 minutes or so. Just remember to let the motor cool since you don't want to burn up the motor.
Break-in: if you don't have a charger that can do a motor run function, you have 2 easy alternatives. You can hook up 2 cells to the motor (with no load on it, so don't run it in your car) and let it spin for about 5 minutes. Or, you can keep the motor mounted in the car, and detach the pinion so it can spin freely. Then plug in the batteries and turn on the esc and just turn the throttle trim up a little bit so that the motor is only receiving a small amount of voltage from the esc.
XrayFK is offline   Reply With Quote
Old 02-15-2006, 11:49 AM   #3
Check your spur gear, if it is 72t (stock gear TC3) then you will need a 30t pinion gear, if you have a 75t spur , use a 31t pinion.
caveman is offline   Reply With Quote
Old 02-15-2006, 11:57 AM   #4
I think the original brushes come with the motor are Enduro with soft springs(10 or 11coils, I'm not sure). Harder springs(8 or 9coils) will be better for racing, but for parking driving, the original springs are fine. Oh, make sure you have a very hot soldering iron. 60W or more
Old 02-15-2006, 12:20 PM   #5
XrayFK's Avatar
Even if you are not racing, I still recommend the hard brushes, as the brushes will bounce too much with the soft springs.
Old 02-15-2006, 12:47 PM   #6
OK , agree.
Old 02-15-2006, 04:18 PM   #7
I will have a look at the hard brushes, thanks guys!. Why do I need a really hot iron? I dont know what it is but its probly older than me! Should I buy a new one?
Old 02-15-2006, 04:36 PM   #8
yea I have a 72T spur, so I need a 30T pinion. So I need some Hard springs and a 30T pinion! Cool, thanks guys. Also I have 4 *3000 nimh batteries and a Ripmax pro peak ac/dc delta peak fast carger. Can I have biger batteries, and will I see better runtimes? so at the moment
I have a final drive ratio of 7.5 (if I counted the pinion right at 24) So I am shortening the ratio making accelaration better top speed worse right? Would that not burn out the motor faster? if 6.0 is the best one, I'm sure you guys know best, I'll go along with that.
Old 02-15-2006, 04:49 PM   #9
XrayFK's Avatar
Let me clarify the gearing for you If you "gear up" as in adding a pinion with more teeth, the actual number of the FDR will go lower. The higher the FDR, the more acceleration, and more top end with a lower FDR number. Of course, that's only true up to a certain optimal point. So in your case, 7.5 would have more acceleration than 6.0, but 6.0 would have more top end. You probably know that if you gear a motor too tall (too low of a FDR) then you will burn up the motor. Keep in mind that the same will happen if you gear too low, as the motor will be revving too high for the majority of the time.
The Element wants to push that taller gearing, so I would use a 31T pinion for best performance. Using a 30T pinion might give you a little longer runtime though.
Hope this helps.
Old 02-15-2006, 04:53 PM   #10
so 30T it is then, thanks mate big help. I'm clear on gearing now I think! I will get a 31. so its then geared at 5.8 right? Whats the top speed going to be on that gearing (roughly?)
Old 02-15-2006, 05:12 PM   #11
why need a hot iron?
noobie is offline   Reply With Quote
Old 02-15-2006, 05:26 PM   #12
Send a message via Yahoo to nomaak
all the material in the V2 endbell is designed to dissapate heat. a weaker iron would go cold quick. you need an iron that makes a lot of heat and KEEPS it.
nomaak is offline   Reply With Quote
Old 02-15-2006, 05:33 PM   #13
I have a 40w, it should do the trick right?
Old 02-15-2006, 05:46 PM   #14
A 60W will be better.
FYI, the solder on that motor contains silver, which makes it harder to melt so you definately need a 60W iron.
trf_racer is offline   Reply With Quote
Old 04-26-2006, 07:37 PM   #15
dynoman007's Avatar
Send a message via MSN to dynoman007 Send a message via Skype™ to dynoman007
Default ve springs trick??
whos has a link tothe trick to take out and reinstall the springs on the v2 .....
dynoman007 is offline   Reply With Quote
Orion / Peak V2 19 turn Motor Dynasty / Element Cain R/C Items: Wanted to Buy 0 04-25-2006 10:54 AM
would an orion element armature fit a orion core stock can? bionictony Electric On-Road 5 01-19-2006 10:32 AM
Trinity UltraBird Motor Pro 19T or Team Orion Element V2 19T Modified halayli Electric On-Road 4 12-26-2005 07:36 AM
Orion Element V2 19T micros_rock Electric On-Road 40 04-28-2005 09:15 PM
Orion 19T element Brian Miskolczi Electric Off-Road 4 02-17-2004 02:53 PM
