Old 02-14-2006, 05:26 PM   #1
anthony390's Avatar
Send a message via AIM to anthony390
Default set-up wheels
alright i was trying to get some alluminum set-up wheels and well they're just a bit hard on my pocket so i was wondering what can i use to subsitute it with or is ther i can make some...in another thread i saw a guy use plexie glass and cut it into a circle
maybe i should do that
anthony390 is offline   Reply With Quote
Old 02-14-2006, 09:57 PM   #2
anthony390's Avatar
anyone
Old 02-14-2006, 10:22 PM   #3
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
You could sand a set of whels down as flat as possible for something like what you're looking for I guess??
Old 02-14-2006, 10:24 PM   #4
anthony390's Avatar
i want somthing i know will be perfectly flat and striaght so i can see if my set-up is correct
Old 02-17-2006, 03:14 PM   #5
Many years back ... I made a set using Plexiglass.
Go down to the glass store. Buy a 1 foot square peice of plexiglass 1/8 thick.
Using a table saw cut four equal rectangles "about 2" by 4.5".
Use a drill press drill a hole "the same size as your axle" into the rectangles.
Tighten the rectangle plates onto your car as you would tires.
Now make your measurements using the plates.
I now have a setup station so don't use them anymore.
M2Racing is offline   Reply With Quote
Old 02-17-2006, 03:40 PM   #6
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
A set of wheels with no tires should work, especially the stiff dish type.
ClemsonTigers
USVTA # 224
ERC
RKeasler is offline   Reply With Quote
Old 02-17-2006, 04:00 PM   #7
anthony390's Avatar
thats the problem...there bent
Old 02-17-2006, 04:17 PM   #8
Xcal's Avatar
Send a message via ICQ to Xcal Send a message via AIM to Xcal Send a message via MSN to Xcal
The wheels are bent??? Buy some new ones then, they cant be that hard on your pockets?
Your not going to be able to use your car real good anyway if the wheels are f***ed.
Xcal is offline   Reply With Quote
Old 02-17-2006, 05:08 PM   #9
AM03GT's Avatar
if you're going to use setup wheels, get actual setup wheels...
if you make them they have to be PERFECT. the whole point is to have 4 equal setup wheels so that you can set all your suspension without worrying about having unbalanced wheel/tires.
By the time you fabricate 4 that will perform like a purchased set, it will probably cost more...
Associated // Reedy // Radiopost // Integy // Parma PSE
AM03GT is offline   Reply With Quote
Old 02-17-2006, 05:17 PM   #10
3racing has them for .. $20.. something like that... Then you know they are straight and equal
http://rc-mushroom.com/product_info....oducts_id=2595
hugovdb is offline   Reply With Quote
Old 02-17-2006, 06:56 PM   #11
Rick Worth's Avatar
You don't race the car with set-up wheels so just adjust it with the ones you will be racing with. R.W.
Rick Worth is offline   Reply With Quote
Old 02-17-2006, 08:11 PM   #12
Pat Clark's Avatar
Good point all that time setting camber, tweek, ride height with "perfect wheels" just to put on 4 tires,that one is .5 mill small than the rest. You can then through all that set-up time in the trash and a heat race
Associated, Reedy, Tekin, Tq Wire, Protoform, Veytrec Design Lab
Pat Clark is offline   Reply With Quote
WTB LARGE MT WHEELS TIRES & WHEELS 17MM + STIFF REVO SPRINGS jsm11 R/C Items: Wanted to Buy 5 07-18-2008 09:11 PM
5 sets of wheels/tires. slick, treaded, and drift. 4 dish wheels bionictony R/C Items: For Sale/Trade 2 07-12-2008 09:02 AM
Panther Pythons on Revo Wheels-Crimefighters on Buggy Wheels possom813 R/C Items: For Sale/Trade 17 05-07-2006 08:06 AM
Losi buggy/truck wheels, tourer bodies, bling wheels I'm_Serious Australia For Sale/Trade 0 02-05-2006 06:15 PM
Tamiya TRF Blue Dish Wheels Brand new in package 8 wheels F/S reflekt R/C Items: For Sale/Trade 1 12-15-2002 01:52 AM
