Old 02-13-2006, 08:24 PM   #1
Default traction? please help
hi i have a original hpi rs4 electric and when i got it someone had converted it to rear wheel drive . i dont know why but now im trying to get as much tracktion as i could out of it. im running really soft rear springs and medium springs in the front and my car is about 7mm of the ground im running 35 wt shock oil with neg 1 degree camber in rear and neg 2 degree camber in the front. im also running soft hpi x radial tires in the rear. what could i do the problem is my car gust spins out when i turn and when i accelerate too fast. and my my read diffs are locked. please help
pcr2nv is offline   Reply With Quote
Old 02-13-2006, 08:39 PM   #2
zipp's Avatar
you'd need to exercise better throttle control for rwd cars. be smooth on the throttle
try changing your tires? hpi tires never really grip well, much less their low-end ones.
cheers!
zipp
zipp is offline   Reply With Quote
Old 02-13-2006, 10:10 PM   #3
what tiers do you recomend that arent very expencive exept foam, and would roll bars help my handeling thanks
Old 02-13-2006, 10:12 PM   #4
Alexander's Avatar
you need to make it 4wd again, its not designed for 2wd
Alexander is offline   Reply With Quote
Old 02-13-2006, 10:14 PM   #5
i cant parts are discontinued
Old 02-14-2006, 02:50 AM   #6
sosidge's Avatar
You'll never get it to handle well as RWD, it just wasn't designed for it. The weight distribution andf geometry are all wrong. I'd give up now before you waste too much money on that old chassis, pick up a more recent chassis that hasn't been wrecked, and switch the electronics across.
Old 02-14-2006, 05:34 AM   #7
spidude's Avatar
cheers!
zipp
Really? Have you tried their ADVAN A038 Belted radials? Hold like glue to me.
spidude is offline   Reply With Quote
Old 02-14-2006, 08:35 AM   #8
zipp's Avatar
oh yeah! i've tried the carpet compound years ago with rather good results. but others like 33Rs and 35Rs can't hold a candle against the sorexes. i mean, even my tamiya B3s are slightly better!
Gearing for Traction/Slipper for Traction RCRat Electric Off-Road 2 08-27-2008 03:55 AM
High-traction & low-traction? bloodlust Malaysian R/C Racers 4 12-06-2007 09:17 AM
How to get traction tc3=speed Australian Racing 15 04-24-2006 08:53 PM
Traction dontfeelcold Australian Racing 6 04-07-2004 07:25 AM
Traction xray racer Australian Racing 2 02-11-2003 03:52 AM
