Like Tree1140Likes
Can-Am RC Series
    Hide Wikipost
Old 11-27-2018, 10:35 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Can-Am RC Series
Last edit by: Joe Kimble
Cheaters Suck.
MOTOR OF MONTH NO MORE!!!
3.5mm MALE bullet connectors are REQUIRED
at all CanAm races
CanAm Motor & Transmission Specs
USGT
ORCA------------4.40min FDR Indoors-------------169g
STOCK TC
TEAM POWERS------5.40 min FDR Indoors-----------------173g
SUPER STOCK TC
SCORPION-----6.20 min FDR Indoor--------------------170g
CanAm Stock 1/12th
TEAM SCREAM-------------OPEN-----------------------160g
CanAm Super Stock 1/12th
TEAM SCREAM-----------35T/88T-----------------------160g
CanAm F1
SCORPION-----------------28T/92T-----------------------170g
CanAm WGTR
ORCA---------------------36T/92T-----------------------169g
TC/USGT Likely Spur/Pinion Combinations
USGT
1.7 Internal
96/37 => 4.411 FDR
101/39 => 4.403 FDR
1.80 Internal
93/38 => 4.405 FDR
98/40 => 4.410 FDR
1.85 Internal
100/42 => 4.405 FDR
1.9 Internal
95/41 => 4.402 FDR
102/44 => 4.405 FDR
2.0 Internal
99/45 => 4.400 FDR
STOCK TC INDOOR
1.7 Internal
102/32 => 5.419 FDR
105/33 => 5.409 FDR
108/34 => 5.400 FDR
1.80 Internal
99/33 => 5.400FDR
102/34 => 5
.400 FDR
105/35 => 5
.400 FDR
108/36 => 5
.400 FDR
111/37 => 5
.400 FDR
1.85 Internal
108/37 => 5.400 FDR
111/38 => 5.404 FDR
114/39 => 5.408 FDR
1.9 Internal
108/38 => 5.400 FDR
111/39 => 5.408 FDR
2.0 Internal
92/34 => 5.412 FDR
100/37 => 5.405 FDR
108/40 => 5.400 FDR
SUPER STOCK TC INDOOR
1.7 Internal
106/29 => 6.214 FDR
110/30 => 6.233 FDR
1.80 Internal
100/29 => 6.207 FDR
107/31 => 6.213 FDR
114/33 => 6.218 FDR
1.85 Internal
104/31 => 6.206 FDR
114/34 => 6.203 FDR
1.9 Internal
98/30 => 6.207 FDR
108/33 => 6.218 FDR
111/34 => 6.203 FDR
2.0 Internal
112/36 => 6.222 FDR
NB: Serpent Project 4X was checked and due to the O.D. of the center pulley the internal is not exactly 2.000. Testing revealed it is closer to 2.005. For Serpent Cars ONLY, the drivers who wish to be as close as possible to the Minimum FDR can use the following spur/pinion combinations: SS TC => 99/32; Stock TC => 97/36; USGT => 101/46.
Print Wikipost
Old 09-01-2019, 08:34 PM
  #886
dave-man's Avatar
Trader Rating: 20 (100%+)
Not sure you need cooling holes? With the spec gearing, the motors never get hot.
hanulec and KUI like this.
dave-man is offline
Old 09-01-2019, 09:51 PM
  #887
westendorfy's Avatar
Well I ran the " Team Alibaba" motor and you all are correct. The motor is the perfect speed for spec TC. I am just being a idiot.
I ran with a few guys from X-Treme Carpet Raceway over the weekend and the laps times are exactly the same over a 5 minute heat with hardly any fade at all.
hanulec, KUI, tommysnow7 and 1 others like this.
westendorfy is offline
Old 09-02-2019, 07:25 AM
  #888
Trader Rating: 36 (100%+)
Glad we got you hooked back to carpet my friend!
westendorfy likes this.
tommysnow7 is offline
Old 09-05-2019, 06:54 AM
  #889
So is the new USGT spec motor from gravity / USVTA going to have any effect on the cam-am USGT spec motor by orca?
USGT
mrreet2001 is offline
Old 09-05-2019, 07:39 AM
  #890
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
USGT
its an interesting thing -- going into effect Spring 2020 for USGT rules. USGT "folks" didn't like the Can-Am motor (but racers did). I'd assume the Can-AM USGT motor would change/disappear for Season 3 of Can-Am starting August 2020
hanulec is offline
Old 09-05-2019, 08:47 AM
  #891
robk's Avatar
Trader Rating: 22 (100%+)
No, Usgt folks had no opinion about can am when it started and wanted to see how it would play out. Because we did not jump on your bandwagon immediately does not mean there was any ill will. I don't know who you talked to but I told people I hope it works out for you, but we have always chosen to be conservative and watch a bit before we jump into anything. Beyond that, I have always tried to maintain as much autonomy as possible for usvta classes. It just works better in my opinion.
Btw Novak motors were the usvta spec motor for years until they went belly up. This is nothing new.
robk is offline
Old 09-05-2019, 09:25 AM
  #892
hanulec's Avatar
Rob.. excluding races that leveraged Can-Am usgt from your point series / result set is the reason for my statement.
Fully aware of the Novak past...
Happy to see evolution in the wider community...
hanulec is offline
Old 09-05-2019, 03:22 PM
  #893
robk's Avatar
Unfortunately, the motor and gear rules are not USVTA rules. If someone had a race on Jacos instead of Gravity USGT tires, I would have to rule those results out too.
It doesn't mean I disagree with what you have done, or that I don't admire your success.
Cain and NutDriver like this.
robk is offline
Old 09-10-2019, 04:15 PM
  #894
Originally Posted by hanulec View Post
Please reach out to the manufacturer via the instructions here --
Manufacturers
Three price levels-
Rentals
Track/hobby story purchase
Retail purchase
Has Anyone had any luck on getting response from Team Powers???
Still no response from them...
wrutherf is offline
Old 09-10-2019, 05:02 PM
  #895
hanulec's Avatar
email canamrcseries at gmail
will put you into a convo w/ eric @ team powers
hanulec is offline
Old 09-12-2019, 12:48 AM
  #896
IMSupercar's Avatar
Nice, subscribed
IMSupercar is offline
