Can-Am RC Series
#496
There isn't a loophole in the sense that a fwd car, even geared up and with weight up front, stands 0 chance against a standard 4wd TC chassis. I don't think it even ever would be close.
I'm not am expert in racing but I believe that even in real life fwd cars get destroyed against 4wd cars.
The biggest factor I can think of is that the load and weight transfer during acceleration goes from front of the car to the rear. So the rear is where you need the drive on the wheels. This would explain why in real life certain Rwd cars are competitive. Like the German cars.
Even on 4wd cars the rear drive train wears much faster than front. This is most noticeable in nitro GT8.
#497
#498
im not gunna say we have been working on it, but..
#500
That person is me, this time.
Or, look at it this way. If you think 4wd is the way to go, more power to you. Me messing with a FWD chassis in the way USVTA is clearly wanting someone to do, isn't hurting you at all.
#501
So we don't want Can-Am races to count towards the series points, but we want Can-Am FWD gearing concessions based on a clause in the USGT rule set?
#502
*shrugs* Can-Am, to me, appears to be a solid, good, set of motor rules that exists on top of other rulesets. They have put a lot of effort into making sure those racing classes (and rulesets) retain their essential ~class-ness~. This is good in my book. Much as lots of places just go "It's gotta be ROAR approved" regardless if it's a ROAR race or not.
I have no (public) opinion over weather or not Can-Am races should be parts of the point series to other groups.
#503
Thanks to Hanulec for getting the CanAm series together. We had the first race at Apex using the format this weekend and everyone absolutely loved it! We had guys turn the motors in each night and get new ones the next day and everyone said they could tell zero difference. Everyone was extremely happy and ready to do it again!
EA
EA
#504
I'd say the first race using the CanAm format was extremely successful. I ran different motors each day and couldn't tell the difference. The process was easy - sign a motor out at the beginning of the day, return it after racing the same day. Tech had a device to determine final drive ratio within seconds, and everyone I know of was close to the 6.20 min. FDR for Super Stock TC. Easy, well run process.
#505
My only complaint is that I wish all the classes at the race would have run them. I know that is all up to the promoter though. It was a pain for me travelling from out of town with a limited set of motors that were off the shelf and wouldn't pass tech. These weren't even those 1% team motors either, they were basic motors. This would have eliminated that, motor tech altogether and saved a lot of time for everyone. I think this is something promoters should take note of for future events.
#506
#507
#508
only a couple things that I noticed on the canam classes.
First make sure that you have a few extra rear belts as TC with the timing and gear that are speced is going to rip out a few belts if you don't tighten them up. Think mod toque and 21.5 straights noticed 1 or 2 this weekend toasted
Also make sure you tighten your motor right with the issue of putting the motor back in each race day. saw a couple gear fails in TC
as I ran 12th scale I also saw couple gear fails on that also.
prepare to go through tires more than normal. again low timing high rollout is just shredding tires.
for 12th scale not sure on the MPRL (mm per run loss) but one day I'll have one of the motors to figure that out for club racing.
13.5 on green CRC compound I can run 4 rounds on black carpet with a 13.5 starting at 41.5mm and finish at 39.7 about .45 MPRL
last don't listen to a thing they say about it "drive like a wind".... For the mortals out here the 12th scale SS (10.5) felt like driving a Mod car for the first 5 feet out of every corner. it took a different driving style for me vs 13.5 to not bang it off the wall or diff out. even the 2 pros were having trouble. As I was a little busy announcing I didn't get to try anything setup wise so it was drive it as is. but one thing I might try would be torque control on the ESC. again think MOD out of the corner. you can roll off a little but I had to remember not to slap it back when I rounded the corner. so if you want to run the SS class you better be able to drive Mod for 5 feet if you want to drive fast. Throttle control.
I'll find out at the Halloween classic how stock is. sure wise I had a motor to get a feel for how it drives.
never worried about being slow. never did before with roar either the fast guys were fast and the slow guys were slow. BUT the fast guys might of been a little closer and the slower guys might of been a little closer to each other. but than again might of been the same with roar 13.5 and a high gear ratio. the gearing allows you to miss the line and if the grip is there jump back in it if it holds and not lose as much time.
also cheaper? if birds and one other race I'm going to goes canam I'll spend over 250+ from now to January and only have but the memories of a motor rental, and $130 for probably 2 paper weights. $380 on canam motors that I can't use or maybe I can. not sure yet still trying to figure that out. good thing I'm not going to vegas or the 6 or 8 legal roar motors that I have would get worn out so I'll have them for the roar nats next year.
of course I'm the guy that made the A main at the 2012 carpet nats with a Duo1 that I had run since 2009 carpet nats. Still have the motor. 9 years old still runs.
now with all that said the racers seemed to think they didn't have to worry about motor or gearing and only adjust setup and just drive. which is good. I just drove. finished 3rd
