HELP - HPI RS4 SPORT 3 DRIFT PROBLEMS >
Old 05-01-2018, 11:52 AM
Danielfoster's Avatar
Default HELP - HPI RS4 SPORT 3 DRIFT PROBLEMS
Hi all,
so so today I received my £500+ order from rc geeks and part of the order was a HPI RS4 Sport 3 drift RC Car I inboxed it and put the battery on charge immediately to give it a full charge before first use. I put it on and no sooner than 20 minutes after putting it on it was fully charged.
Hey ho I put the car all together and took it for itís first spin! LOVED IT.
however the car stopped all of a sudden made a quiet beep noise but he steering was still responding completely Fine. 10-15 second later after me walking over to the car it started working again I thought I dunno maybe the Ariel needs to be sticking out the top of the car, so I stuck the Ariel out the top and it happened again so far itís happened 3 times ? Can anyone help me please the car is off the rc geeks website and can be found easily
please help
Danielfoster is offline
Old 05-01-2018, 12:44 PM
The ESC could be getting hot and going into Thermal protection. If it happens again, check to see if the ESC is very hot. If so, you may need to put a fan on it (if there isn't one already) or make sure you are getting adequate cooling to the ESC.
0010 is offline
Old 05-01-2018, 12:57 PM
Roelof's Avatar
I think the battery needs some charge. The manual says 6 hours and you just did 20 minutes. A NiMh battery normally comes about half charged so I think the battery is not full. Beside thad, the battery needs some charge/discharge cycles before it will perform om max capacity.
Roelof is offline
Old 05-01-2018, 01:12 PM
Billy Kelly's Avatar
Check the esc settings. There usually is s lipo mode and a nimh mode. Hpi is notorious for including a nimh battery, but esc comes set in lipo mode. I’ve had it was 3 different Hpi vehicles over the years.
Billy Kelly is offline
