Old 02-13-2006, 10:33 AM   #1
Default 15 turn motor
i am kind of in a delima, i recently purchased a 9 turn epic shock motor and later found out that it wasn't legal where i race at. the turn limit for our track is a 15 turn both stock and modified. our track is classifies as small to medium with not very long straight aways. i currently have a Factory Team TC4 with and unlimited turn ESC i was wanting some suggestion from people that would know which kinda of 15 turn motor would be best for me. i am a beginner and don't want something that i can't handle.
TIA
andy_b22 is offline   Reply With Quote
Old 02-13-2006, 11:12 AM   #2
ottoman's Avatar
R/C Tech Charter Subscriber
Beginner.... 9 turn... short track... TC4 The 15 turn will suite you much better Just buy a 15 turn arm for your shock and your all set
ottoman is offline   Reply With Quote
Old 02-13-2006, 11:17 AM   #3
xlgraphicspro's Avatar
You should probably try to start a 19 turn class, that sounds like the perfect class, for your size track.
Then you could try just about any motor, Orion v-2 based, Integy Atlas, Trinity Chameleon 2, Komodo Dragon( not out yet), Check point 19 TURN.
The choices go on! But If you think about it a 19 turn might actually allow you to go faster, since alot of guys spin their wheels and slide out of the groove because they have so much horse power!
TeamXray RCAmerica Hudy Xlgraphicspro Paint/ Impulse-Rc Clutch shoes.
Xray XB 808 O.S. Speed Or Ninja JX
xlgraphicspro is offline   Reply With Quote
Old 02-13-2006, 02:27 PM   #4
Cool
alright thanks!since my motor wasn't legal, one guy let me use his Trinity Chameleon (I am not sure if it is just the 1st one or the second) which he said he would sell for 25 dollars brand new! i currently have a 15,22,23 t pinion. the 23 was in when i was racing but i was peeling out and couldn't get traction very well but i also was running rubber not foam. so i am in the market for some foam tires from what i have been told i want to get 42 jaco foams. is this correct suggestion for my track conditions?
Old 02-13-2006, 03:23 PM   #5
What type of carpet are you running on? My carpet track typically uses Plaid fronts, purple rears. That is in either jaco, parma,trc.
Old 02-13-2006, 03:25 PM   #6
xrayaustin's Avatar
Trader Rating: 12 (93%+)
Send a message via AIM to xrayaustin
were u running slicks? if you werent That could have been the problem but also, your diff might be too loose.
xrayaustin is offline   Reply With Quote
Old 02-13-2006, 06:38 PM   #7
no i wan't using slicks, and i am not sure what carpet we run on, it is grey is all i know, sorry still learning
Old 02-13-2006, 06:41 PM   #8
why jump right into mod
stick with a stock 27t motor and go from there
if you dont have a huge straight then stock should be fine
more time is gained in the turns than in the straight part
id rather be fast in the infield
iamjeff6 is offline   Reply With Quote
Old 02-13-2006, 07:42 PM   #9
Michael Barch's Avatar
Send a message via AIM to Michael Barch
Assuming your running on Ozite carpet I would go with the TRC foams, Plaids and Purples. DO NOT run the Jaco or Parmas, there crap...there rims are cheap made.
Michael Barch is offline   Reply With Quote
Old 02-13-2006, 07:51 PM   #10
Send a message via AIM to R/C Anonymous
double pink, double pink/orange Jacos/BSR...etc.
cyan,magenta TRC/Parma...etc.
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 03-15-2006, 01:57 PM   #11
tbeardmore's Avatar
BMI DB10R, Corally RDX PHi, BMI 12R..!!
Need a "real" car... contact me at:
www.beardmorechevy.com -or- www.beardmoresubaru.com
tbeardmore is offline   Reply With Quote
i was looking for warp4 2 turn motor. instead i bought a ALIGN 430L motor rasserie Singapore R/C Racers 8 10-24-2008 11:14 PM
3 checkpoint 19 turn motor lo (money motor) $30 shipped for all johnny boy R/C Items: For Sale/Trade 3 06-17-2008 07:46 AM
WTB 19 Turn Motor jabroni racing R/C Items: Wanted to Buy 8 07-17-2007 12:37 PM
Whats the fastest 19 turn and 27 turn stock motor? adr3naline fix Electric On-Road 104 08-26-2005 11:03 PM
best 19 turn motor farls3589 Electric On-Road 3 08-04-2005 05:53 AM
