Old 02-28-2006, 11:35 AM   #91
teamgp's Avatar
Originally Posted by Marcos.J
wow those are real good #'s are all thoses at 7.00 volts?
Yep. With a fresh slave motor and the baseline motor numbers in good order as well. The numbers I posted are also the second run of each motor. The initial runs had slightly higher numbers. But I always choose to go with the second more conservative run which also helps to make sure that the brushes are broken in.
Guy Hood
Sponsored by: Team XRAY / Team RC America / RB Products USA
/ Twister Tires USA / Maxy's Mods & Fuel / Parma PSE / Zubaks
Un-sponsored Shoutout: NexusRacing.com
*** 301 Raceway is my home away from Home ***
teamgp is offline   Reply With Quote
Old 02-28-2006, 11:37 AM   #92
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
awesome , Im working on a few CO27 and they are looking really good!! but I still like my P2K and the Monster a little better
Old 02-28-2006, 02:49 PM   #93
bvoltz's Avatar
Trader Rating: 44 (100%+)
Sorry the question, but how does one read this numbers? What should a newbie like me be looking for?
bvoltz is offline   Reply With Quote
Old 02-28-2006, 02:53 PM   #94
James35's Avatar
The most important number is Watts. 746 Watts = 1 electric horsepower.
Watts is determined by the combination of torque and RPM. HP (Watts) = RPM x Torque. So essentially, you can just look at watts only.
Many people value RPM and Torque differently. And that would be inaccurate. Truth is: speed is a matter of gearing.
Efficiency really isn't as much of a concern because today's batteries have plenty of mAH to spare. Although I've heard that high efficiency can cause the motor to run cooler. Can anyone confirm this?
James35 is offline   Reply With Quote
Old 02-28-2006, 02:54 PM   #95
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Yep. With a fresh slave motor and the baseline motor numbers in good order as well. The numbers I posted are also the second run of each motor. The initial runs had slightly higher numbers. But I always choose to go with the second more conservative run which also helps to make sure that the brushes are broken.
Hey Guy thanks for taking the time to post those results. Seems you are finding the same thing I have when comparing brushes and comparing the C027 to other motors.
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 02-28-2006, 02:54 PM   #96
Super Moderator
Marcos.J's Avatar
for stock you want to look for is watts!!=power
Old 02-28-2006, 02:58 PM   #97
Team EAM
Yes to an extent. RPM is also very important as well. That is where you figure your gearing out when comparing one like motor to another like motor (C027 to C027 etc).
I use wattage first, then RPM, then Torque. If I have 2 motors with the same wattage I'll go to the next factor of RPM and so on. But once you find a motor that dyno's good AND runs good with a given gear you can then dyno another motor with different rpm and get the gear pretty close by looking at the rpm of the first motor.
EA
Contact Us
Old 02-28-2006, 03:07 PM   #98
teamgp's Avatar
EA
I guess you could say I learned a lot by holing up in my room all day Wednesday at the Birds to work on the handout motors and finally figure out my CE dyno. Still learning more though.
bvoltz,
For power comparisons of stock motors pay more attention to the watt readings at 20A (top end down the straights) and 28A (low end out of the corners). Anyone correct me if I'm wrong, but I believe good numbers are somewhere around [email protected] and [email protected], with up to a +/-3W variance between dyno's.
Guy Hood
Old 02-28-2006, 03:11 PM   #99
Super Moderator
Marcos.J's Avatar
bvoltz,
I think that it was according to "Big Jim" was at least 100 watts at 20 amps and at least 120 watts at 28amps
Old 02-28-2006, 03:11 PM   #100
told u guys this motor is the real deal
Team Associated, Reedy, Tekin, Futaba, Putnam, Protoform, BSR, SXT, Reflex Racing, McPappy Racing, TQ Wire, Swifty Designs
Jeff Cuffs is offline   Reply With Quote
Old 02-28-2006, 03:14 PM   #101
James35's Avatar
And to add to those thoughts further... Big Jim's best stock motor he ever had (P2K2) produced 139 watts @ 28amps.
Old 02-28-2006, 03:27 PM   #102
Super Moderator
Marcos.J's Avatar
from Bid Jim's website
Originally Posted by Big Jim
My Best P2K2 @ 7.0V:
20366rpm 6.8TQ 103W 74EF @20A
17270rpm 10.1TQ 129W 66EF @28A
Old 02-28-2006, 03:29 PM   #103
Team EAM
bvoltz,
Yeap sometimes the best way to learn is to just sit down and do it!! I tend to remember stuff more if I actually do it than I do if someone tells me about it!! LOL
But one thing I have found is that with todays current crop of cells and the current motors we have that you are better off using the 22-25 amp load for the straight away (and to be honost I dont pay much attention to the wattage here) and use the 30 amp number for the corners. If you actually use a data tree recording device (or the new spectrum system) you will see that stock motors acutally pull more than 30 out of the corners on some tracks.
he varriance comes from how good the car is, how smooth the line is and how high the traction is on the track. If you just touch a flapper the amp draw can spike up to 70-90 amps on a stock and over 100 amps on a 19 turn. Its actually pretty impressive if you install one of those and look at the data.
EA
Contact Us
Old 02-28-2006, 03:51 PM   #104
James35's Avatar
Hmm, I could have swore he said 139W at 28amps. I can't find that post now. However, I did find this post from Big Jim that says it was 131W:
And Harry, how many times have you heard me say this. Horsepower is horsepower! Speed then is just a matter of gearing. HP (Watts) = RPM x Torque. If the RPM-ish Monster produced 131W @ 28A on my dyno the way that P2K2 did then it would be "King" but it didn't so it's not.
Nonetheless, the new Monster CO27 is quiet impressive.
Old 02-28-2006, 04:23 PM   #105
Super Moderator
Marcos.J's Avatar
i seen that one but for P2K it was 129
monster stock and monster hand out $20 yeaklet4 R/C Items: For Sale/Trade 0 04-15-2007 06:51 PM
Ofna monster Pitrate 1/8th Monster truck Boostd2valve R/C Items: For Sale/Trade 4 02-25-2005 09:31 AM
Paradigm monster VS Fukuyama Monster FUK_WRX Electric On-Road 127 06-02-2004 04:48 PM
Monster stock / Revenge of the monster Klaus Electric Off-Road 1 03-08-2004 07:34 AM
Trinity Monster vs Fantom monster xray racer Australian Racing 15 06-24-2003 04:13 AM
