Stock and 19t Brushes for 4-cell Roadcourse which Brush? >
Old 02-12-2006, 06:19 PM
noline's Avatar
Default Stock and 19t Brushes for 4-cell Roadcourse which Brush?
Im currently running 4-cell stock and 19t roadcourse which brush and springs should I use with IB 3800 Batteries and the motors Im using are the Trinity Monster stock and the Trinity C2 19 wich Brush would provide the most power for these two motors any help would be greatly appreciated.
noline is offline
Old 02-13-2006, 02:49 AM
noline's Avatar
Dag... can anyone help me
noline is offline
Old 02-13-2006, 08:11 AM
Noline,
I use the Reedy 767's for my monsters in 1/12 scale with red+ and green - springs. For less maintenance I have run a 767+ and 766 on the negative. With that combo you can go quite a few rounds without having to cut the comm. Between heats just run the motor at 1.2-1.5 volts for a minute and spray the comm a couple times.
For 19 turn if you have standup hoods Reedy 729's are good, if they are laydown then I would use 767's. For srings you may have to go with a purple/ red combo.
Finishline F brushes are also good for both cases.
Greg
Greg45231 is offline
Old 02-13-2006, 10:31 AM
Fuzzy's Avatar
noline,
I'll second Greg's opinion on the F brush from Finishline. However, my setup is slightly different for a Monster. I file about .010" off the trailing edge of both brushes and use green/green springs. Filling the trailing edge of the brushes will drop the amp pull slightly and increase the torque with a minimal drop in rpm that won't be missed on the track. This will make for a more overall powerful motor.
Fuzzy is offline
Old 02-13-2006, 11:22 AM
dgullickson's Avatar
Trader Rating: 45 (96%+)
767's are usually the ticket... I also like the XXX if you dont mind the extra $$....
dgullickson is offline
Old 02-23-2006, 08:35 PM
TTT
THEBIGBULL is offline
Old 02-23-2006, 09:12 PM
Ok I change my mind.. After doing some testing I decided on the Fbrush with our comm drops.
Old 02-23-2006, 09:32 PM
Team EAM
Trader Rating: 79 (100%+)
Good choice.
EA
EAMotorsports is offline
Old 02-23-2006, 10:06 PM
Tempest2000's Avatar
Trader Rating: 21 (100%+)
I used the F-brush at the Halloween Classic and at Vegas and made both A's with it.
It's a very good brush. I run green/green springs.
One other option you might look at is 4503's they dyno about the same as f-brushes with a tad more rpm, but the amp draw is less. Usually I find 4503's fall off a little less at the end of the race.
$.02
Michael
Tempest2000 is offline
Old 02-23-2006, 10:07 PM
TeamButter's Avatar
F-Brush is the way to go....hands down!
TeamButter is offline
Old 02-23-2006, 10:08 PM
Butter we will see at the roar nats LOL
See you there man.
Michael
Old 02-23-2006, 10:14 PM
Korey Harbke's Avatar
F brushes are dialed.... end of story
Korey Harbke is offline
Old 02-23-2006, 10:21 PM
Lightbulb
OK F line brushes it is, How much do comm drops help?? Now what do you suggest for a starting point for rollout with an Atlas stock motor 4 cell 1/12 scale rugrat???. Thanks.... What about F lines for 1/12 4 cell Mod????
TJ
Old 02-23-2006, 10:39 PM
davepull's Avatar
I would also look into Putnam Brushes. the green on + blue - they make killer power. check the results from the last few big races Putnam brushes have been taking down many TQ's and wins
the f brush is also a good one
then you can always fall back on the trinity e brush or reedy 767.
davepull is offline
