Turn Lefts But Makes Noise When Turning Right >
Like Tree1Likes
  • 1 Post By KE4PJO
Old 04-17-2018, 06:14 PM
Default Turn Lefts But Makes Noise When Turning Right
When I turn car to the right, it turns as normal. When I turn the car to the left, I hear an abnormal noise.
Looking to see what needs to be repaired. I don't think I can attach a short video.
Owen is offline
Old 04-17-2018, 06:40 PM
RC Passion's Avatar
What car are u having issues with? You may have drive shaft issues, differential issues, or your end points are just not set right.
RC Passion is offline
Old 04-17-2018, 09:54 PM
Servo end points maybe not set correctly meaning the servo is whining when full lock on left? Is this happening through the whole range of left vs right? Or just at the maximum amount of turning?
WagwanBumba is offline
Old 04-17-2018, 11:02 PM
Tim Neja's Avatar
Simply not enough information!
Tim Neja is offline
Old 04-18-2018, 12:12 PM
Lone Drifter's Avatar
Could be lots of things ,
Check for binding, Cvds, Bearings all the hinge pins in the front end, shocks
Check end point ajustments servo itself
Check Diff or spool for boken parts. Bearing and cams(for belt tension ajustment) for being in the same poistion
Check wheels and tires too they may be out of balance - bent
Lone Drifter is offline
Old 04-18-2018, 07:09 PM
Traxxes Skully
Once we found the expert setting (goes much faster), my boy has been breaking things.
When i just begin to run right, I hear the noise.
Owen is offline
Old 04-19-2018, 12:26 PM
KE4PJO's Avatar
Must be an oval car...
davidl likes this.
KE4PJO is offline
Old 04-19-2018, 02:13 PM
Pop turn buckle off the servo horn then work the servo if still have the noise itís ur servo if no u will have to start taking parts off the front steering suspension one at a time till u find it
tcboy1983 is offline
