Tamiya TB 05 Pro
#286
Why is 54903 not blue?
#289
This should hold up because front.
On the older TB04 aluminium front pilots held up pretty good too. Only the rear aluminium pilots were worse.
The fact, the new part is not anodized, irritates me too. Should be a golden hard coating.
#290
#292
Dogbone of driveaxles eats eventually up the slots. But i think, it doesn't, because it connects front dogbone only. Rear would be much worse. TB04 had that problem with light weight propeller shafts.
#293
Plus I think it will depend also, what motor you run it with
#294
#295
I am using allready blades and the lightweight outdrives for front axles and also rear. But thanxs Tom🙂
#297
I like the blue, but the change off bending it, is a bit off a. No no for me, it looks a bit tiny
#298
Hello to all-
Last Saturday between heats I had to replace the 40 tooth ring gear and the 16 tooth bevel gear on my front spool. There was a slight clicking noise up front.
The gears were the option carbon graphite and they only lasted two weekends.
Any tips to prevent this?
Do I need to shim the spool differently than what the instructions say?
Thanks in advance!
Thanks in advance!
#299
Hello to all-
Thanks in advance!
Thanks in advance!
Car runsgreat when it works,only the gear thing is a bit off an let down.
The manual shimming is too tight for my taste,it will cause binding,with the bearing
#300
Hello to all-
Thanks in advance!
Thanks in advance!
