Tamiya TB 05 Pro >
Tamiya TB 05 Pro
Like Tree272Likes
Tamiya TB 05 Pro
Old 04-10-2018, 11:15 PM
  #16
Is the springs on this vechile a new part of they change the coating on yellow spring?
BTW finally all hex screw on the chassis .
zxcvb1t is offline
Old 04-10-2018, 11:37 PM
  #17
fyrstormer's Avatar
Is it just me or does this chassis have options for longitudinal *or* transverse motor-mounting positions? That would certainly be a unique trick.
I'm very happy with my TB-04R. I might be persuaded to replace one of my XV-01s with this, though, since it looks to be a mid-front-motor design, which is similar-to-but-different-than the full-front-motor design of the XV-01.
fyrstormer is offline
Old 04-10-2018, 11:48 PM
  #18
Location: El Pueblo de Nuestra Señora La Reina de Los Ángeles del Río de Porciúncula, California, Unites States of America
Trader Rating: 39 (100%+)
So it's fully sealed, therefore good possible choice for rallying?
lagcisco is offline
Old 04-11-2018, 03:27 AM
  #19
Tom1977's Avatar
Nice! It has more of a M07 than a TA07...
Hope, this aluminium driveschafts are compatible with Evo 7...
Plastic gearbox seems to be the old TB04/Evo6 ones.
Steering is a little bit Strange.
Tom1977 is offline
Old 04-11-2018, 03:35 AM
  #20
Tom1977's Avatar
I think, this is the new springs series, introduced with TA07R. I heard rumours, that this spring set will be available as hop up later for all chassis.
walrusjon likes this.
Tom1977 is offline
Old 04-11-2018, 08:49 AM
  #21
JatoTheRipper's Avatar
Want! I had my eye on a TA07, but TB (shaft drive) is more ideal for parking lot bashing.
JatoTheRipper is offline
Old 04-11-2018, 11:04 PM
  #22
nubs's Avatar
Why is that? I actually very much disagree with this but I want your perspective.
nubs is offline
Old 04-12-2018, 01:13 AM
  #23
gigaplex's Avatar
Sealed drivetrain, useful for tracks with lots of debris.
JatoTheRipper and fyrstormer like this.
gigaplex is offline
Old 04-12-2018, 05:17 AM
  #24
Despite what some people want you to believe, belts do not like pebbles. I've personally had a belt nicked by a pebble.
Old 04-12-2018, 07:21 PM
  #25
nubs's Avatar
Ah interesting. I had very bad experiences with the tb04 and running it in parking lots. I actually had to create a custom shroud to protect the gears from pebbles. But my TA07 has done quite well in the same parking lots. Though I may be getting lucky.
JatoTheRipper likes this.
nubs is offline
  #26
fyrstormer's Avatar
The XV-01 has a belt-drive, but it's up on top of the chassis and it's shrouded except for a small gap where the belt can sweep debris out of the shroud. It's a highly-effective setup. I'd honestly consider it before any TA or TB car for driving on dirty pavement. I own several and they're all great -- though I do own a TA car and a TB car for variety.
Old 04-12-2018, 07:22 PM
  #27
I really hope Tamiya would come up with steel versions of the gearbox crown and pinion gears. I have so many TB04 54593 in case I can't find them again.
Tom1977 likes this.
WagwanBumba is offline
Old 04-12-2018, 10:42 PM
  #28
I have TB03 with custom chassis, without spur gear cover. Reversing shaft rotation is enough to keep dirt from getting into spur.
Papi is offline
Old 04-13-2018, 02:18 AM
  #29
fyrstormer's Avatar
Unlikely. That would add rotating mass, and racers hate rotating mass.
Have you actually broken the ring and pinion gears on your TB-04 diffs, or are you just being cautious?
Old 04-13-2018, 02:42 AM
  #30
less rotating mass vs stripping the plastic gears because I'm running 13.5T boosted - I don't mind running slightly extra mass.
I can't see alum gears weighing that much more that the plastic ones
I've broken many crown and pinion gears in those gearboxes.
