Tamiya TB 05 Pro >
Tamiya TB 05 Pro
Like Tree299Likes
Tamiya TB 05 Pro
Old 09-21-2018, 08:41 AM
  #181
Wrong
MatsNorway is offline
Old 09-21-2018, 12:03 PM
  #182
Tom1977's Avatar
Originally Posted by MatsNorway View Post
About that servo.. the horn should be on the other side (Towards the front). You get less angle that way. Swapping it around as suggested by Fyrstormer makes it worse.
Can you post a photo?
Tom1977 is offline
Old 09-22-2018, 08:54 AM
  #183
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Scionara05 View Post
Looked on the rules for chassis classes and only see up to tb04 for legal chassis is this legal for gt2style classes
Legal yes, there were a few at Nats last month.
MikeR is offline
Old 09-26-2018, 05:14 AM
  #184
JatoTheRipper's Avatar
I'm a parking lot basher that just races with friends. I was leaning towards a TA-07 PRO, but this looks better for me. Wouldn't you guys agree?
Also, are there any big issues with this kit?
michaels tc likes this.
JatoTheRipper is offline
Old 09-26-2018, 10:07 AM
  #185
CL
CL's Avatar
Trader Rating: 34 (100%+)
CL is offline
Old 09-28-2018, 04:23 AM
  #186
No.. because i was wrong.
gigaplex likes this.
Old 10-03-2018, 12:12 AM
  #187
Looks like, Tamiya is bringing a new batch of aluminium lower bulkheads.
The new Tamiya part No. indicates, that it could be a new design.
Tamiya# 47391. No photos yet. Watch it!
This is an amazing good news: the new design has ball bearing mounted stabilizer and it is compatible with my TB EVO 6!
Taken from Tamiya USA website (I cannot post links yet):
Boost your TB-05 PRO chassis efficiency and toughness with this aluminum component, which doubles as the lower half of the gearbox. It replaces a kit standard A3 part (front or rear) of the car.
• Aluminum Lower Bulkhead x1
• Stabilizer Stoppers x2
• 730 Ball Bearing x2
• This aluminum part mounts the differential gear with precision, for greater efficiency.
• Design allows attachment of stabilizer bars with ball bearings for smooth operation.
• Improves rigidity of chassis, damper stay and upper arm mount.
• Lower bulkhead part has a cool black finish.
• Compatible with TB-03 (including VDS), TB-04, TB-05 and TB Evo.6 chassis.
Ale
JatoTheRipper and Tom1977 like this.
Fiorla is offline
Old 10-07-2018, 09:30 AM
  #188
walrusjon's Avatar
walrusjon is offline
Old 10-07-2018, 09:55 AM
  #189
Tom1977's Avatar
Default Also coming...
Damper stay for SSBB shocks:
Tamiya #54846
Tamiya #54847
JatoTheRipper and walrusjon like this.
Tom1977 is offline
Old 10-09-2018, 03:10 PM
  #190
hello, first post!
I got a tb04 nib that I am thinking of selling to get a tb05 pro for the sealed gearbox. I have a question does the tb05 need a lot of shims and have the same problems as tb04?
michaels tc is offline
Old 10-10-2018, 01:35 AM
  #191
Tom1977's Avatar
Originally Posted by michaels tc View Post
hello, first post!
The main gearboxes need the same attention with shims as TB04. But due to the cancellation of the center gear box in the TB05 the biggest problem is gone.
Tom1977 is offline
Old 10-23-2018, 12:16 AM
  #192
NumptyRacing's Avatar
Thought I would take a pic as it will probably be a while till I see it again!
DaSilva3525 and Tom1977 like this.
NumptyRacing is offline
Old 10-30-2018, 04:33 PM
  #193
foampervert's Avatar
Default Noise
Hiya folks,
I have a tb04, and am considering dropping it for a tb05. Although I went through mad times shimming it, j just can't seem to make it any more quieter then my ta07. But that shouldn't be because the gearboxes are sealed... The noise should be well contained within the gearboxes, or did I get it all wrong?
All my mates who drive the tb04, have noisy cars. Almost sounds like a grinder. On the other hand, my old tb Evo iii, sounded a lot quieter.
Alexander
foampervert is offline
Old 10-30-2018, 10:05 PM
  #194
Tom1977's Avatar
Originally Posted by foampervert View Post
Hiya folks,
Alexander
TB05 is much quieter than the 04. The most noises of the 04 come from the center gear box.
Tom1977 is offline
Old 10-31-2018, 12:47 AM
  #195
gigaplex's Avatar
Hiya folks,
Alexander
Even if you do get it shimmed properly I'd still expect a belt car to be quieter.
gigaplex is offline
