Old 02-20-2007, 11:23 PM   #91
Smile avid
Just received mine today.Ground shipping sure seems slow. Any body have any assembly tips?Thanks Lance
lance is offline   Reply With Quote
Old 02-22-2007, 09:01 PM   #92
Send a message via AIM to R/C Anonymous
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 02-23-2007, 08:03 PM   #93
Built mine today. Get to mess around with it on Monday or Tuesday.
I hope its performance makes up for its design. That is all.
Geoff C.
Old 02-23-2007, 11:13 PM   #94
Customworksking's Avatar
Trader Rating: 73 (100%+)
Arrow car
what u running on ? I put my 13.5 in the other day and wow it was sweet with the box stock setting...LMK how u do I will be running it this sunday on med to high bite @ STL with Drew Ellis so we will see how well it works vers Xray car is killer so far
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 02-24-2007, 12:27 PM   #95
Smile robitronic avid touring car
Just finished assembly.As rc anonymous stated design for quick and easy setup changing spur gears (camber hole inner changes)and maintanance diff spool oneway is a pain.drive train could be freer (new option belts).Very little flex.Foam tires seem fine fine.Super smooth diff.Hope it runs as good as it looks.Will try it Tues. Lance
Old 02-24-2007, 06:47 PM   #96
did you have to sand some material away on your rear arms where the hub carriers go? Both of mine were very snug. A couple minutes with a small file and it was good to go. Everything else went together perfectly for me.
Geoff C.
Old 02-24-2007, 08:09 PM   #97
I did as well......1 thing I did c with the car is u can't run the bocks flat not that U need to
Old 02-25-2007, 01:14 PM   #98
Sweet. I like how they give you alot of extra red shims with the kit for the camber links. Also comes with sway bars which some people like to use.
Lance I don't think adjusting the camber links will be very difficult. There is a hole in the bottom of the chassis to get at the screws easily enough.
Geoff C.
Old 02-25-2007, 01:50 PM   #99
Smile
Thanks for pointing that out rc.Foam tires 28mm will work but should shim wheels they could rub under load.Wish it had 64pitch spur gear with 1.77 drive ratio.Craftmanship is flawless.Waiting to try it out!
Old 02-25-2007, 03:46 PM   #100
carkillaii's Avatar
Anyone know when the Foam kit will be coming out?
carkillaii is offline   Reply With Quote
Old 02-25-2007, 05:56 PM   #101
This car is surprisingly stiffer then i thought it would be.
Geoff C.
Old 02-25-2007, 06:40 PM   #102
RandyB's Avatar
this really looks like a quality ride. Definatly eye candy at least. One thing I am leary on is the axels. ala Xray fk04 I really liked these on the xray only down side is the edges would mushroom out and it became a real chore to take them out of the steering knukles to replace bearings etc
RandyB is offline   Reply With Quote
Old 02-25-2007, 06:43 PM   #103
RandyB's Avatar
so let me know what happens guys
Old 02-25-2007, 06:43 PM   #104
ChadRacing's Avatar
xray has updated axles that get rid of that problem
ReVtech / Trinity / EAMotorsports
HotShot RC / Nexus Racing
Xray T2 '009 w/Exotek Chassis, BMI DB12rr, Tamiya F104X1
Team Durango DEX210
ChadRacing is offline   Reply With Quote
Old 02-25-2007, 06:54 PM   #105
RandyB's Avatar
uh yeah I know they came out with spring steel ones, they they went away from them. I was just curious if they are going to hold up on the avid car
ROBITRONIC AVID TOURING CAR VERY NICE! rifleman5000 R/C Items: For Sale/Trade 7 09-22-2008 02:27 PM
WTB Robitronic Avid Touring Car kmeyer R/C Items: Wanted to Buy 0 03-13-2008 06:55 AM
Robitronic Avid Touring car Mc dog Australian Racing 14 03-30-2007 03:03 AM
Robitronic AVID Touring Car........ Customworksking Electric On-Road 7 02-02-2007 11:09 AM
Robitronic AVID rc-car-net Electric On-Road 2 02-05-2006 08:37 AM
