Old 09-15-2010, 04:50 AM   #811
Potoczak's Avatar
Trader Rating: 112 (100%+)
Are you guys running the avid thrust bearing or another brand???
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 09-15-2010, 09:13 AM   #812
jeff jenkins's Avatar
Trader Rating: 77 (100%+)
i am running the kit thrust bearings but using associated black grease on it.
Maclan Racing Products-Bellgate Distributions-PR Racing- Prospeed
jeff jenkins is offline   Reply With Quote
Old 09-15-2010, 02:28 PM   #813
corallyman's Avatar
Trader Rating: 99 (100%+)
Potoczak,
That's what I am running in my rear diff too, Ceramic balls by Hot Bodies, purchased from Skmotion.net using Assoc diff lube, then running the stock Avid thrust balls with AE black grease. My diff has lasted quite a long time, I am very pleased with the performance of it.
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 09-15-2010, 05:15 PM   #814
Potoczak's Avatar
Thanks guys for the feed back
Pete Potoczak
Old 09-15-2010, 05:30 PM   #815
BLUE 2's Avatar
Trader Rating: 23 (100%+)
BLUE 2 is offline   Reply With Quote
Old 09-15-2010, 09:37 PM   #816
Potoczak's Avatar
They look really good, keep us posted on how they hold up in the car!!!
Pete Potoczak
Old 09-16-2010, 03:55 AM   #817
Potoczak
Iam running avid thrust bearing and find it quite good. But i have had a problem with the thrust rings (cup springs) the problem has been the tension or the lose of tension so to over come the problem i found an old Tamiya 415 ball diff out drive (which they fit perfectly into)and a hex bit out of my drill set and you place the cup spring into the inside of out drive and the hex bit follows and give it a few hits with a hammer to the desired tension (be careful not to use to much force)to much tension and they will not fit back in. so fare the tension has been excellent very smooth and just use cheap 3mm balls which are between 3-6 cents per ball.
I have packed the thrust bearing with Castrol high temp grease as well as on the diff balls and plates and all of my bearings(wheel and out drive)
hope this helps.
will be testing the out drives at the end of the month at the Queensland Titles. will keep you all updated.
Steven
Robitronic Avid / Avid V2
Tekin RS pro / Viper 10.5/MMP/6900
AE B44- MMP/Hacker 10.5/6900 Castle
IP 5000/50 SMC 5200/40/50
Casino Kid is offline   Reply With Quote
Old 09-18-2010, 04:00 PM   #818
Bench test went ok maybe a tad tight for the blades but should wear in.
Steven.
Old 09-20-2010, 05:25 PM   #819
Potoczak's Avatar
Hey guys, does anybody have any carpet setups posted. the carpet season starts here in a couple of weeks.
Pete Potoczak
Old 09-20-2010, 09:52 PM   #820
hpisims's Avatar
I will be doing some more carpet testing Wed. I did TQ on carpet with my asphalt setup sunday before last. I will have a setup that should be very good I will be at the track all day working on it. I will post it wed night.
J.SIMS
Team Associated TC6-Viper R/C Solutions-Sweep Racing-Fullthrottle Motorsports-APH
www.speedybillsrc.com
www.ovrccc.com
hpisims is offline   Reply With Quote
Old 09-20-2010, 09:57 PM   #821
Potoczak's Avatar
Thanks for the update J. Sims
Pete Potoczak
Old 09-21-2010, 01:36 AM   #822
i need to work on a set-up for carpet as well because sunday was the opening carpet race and i used the set-up canto54 gave me and my car was not very driveable with the tires used . i could not keep it from traction rolling and it just didnt feel right im sure the set-up would work at another track and different tires than sweep qts 32's that i was using.
Old 09-22-2010, 09:24 PM   #823
hpisims's Avatar
Ok guys I have a pretty good setup for Carpet with rubber tires. I tried about 10 different setups and this had the best lap times. Was very easy to drive.
I can not fill in my setup sheet and save it so here it is sorry if not easy to follow hopefully Arno can help out.
John Sims
9/21/10
carpet
mixed
medium traction
FRONT REAR
Camber 2 2
Caster 4*
Toe +0.5 3
Ride Hieght 5.5mm 5.5mm
Suspension mount FF 2 FR 2 RF 0 RR 3
Roll center plate FF 1.5mm FF 1.5mm
Roll center plate FR 1.5mm FR 1.5mm
Wheel Base 0 0
Droop 3 3
Transmission Spool
Anti roll bar none none
Springs HPI Silver HPI Blue
preload 50% 50%
oil 500CST sweep racing 450CST sweep racing
pistons 3 hole 3 hole
shock position
Arm 2 3
Tower 4 3
upper suspension
washer inboard 2mm 2mm
hole suspension pl B B
washer rear hub 2mm
Hole rear hub G
Steering
Ballend steering pl 3
knuckle 2
washer knuckle 0
Tires Sweep Racing EXP30
Additive Jack the Gripper 1/2 front inside Full rear 15min
Chassis
low 2.5mm
Top 2.0mm
comments
#56 hole drilled in shock caps 4 screws in front on top deck 2 at steering linkage not fully tightend other 2 all the way at front. 2 at very back and 2 in front of spur gear.
J.SIMS
www.ovrccc.com
Old 09-22-2010, 09:26 PM   #824
hpisims's Avatar
Wow sorry about all that not looking to good it did not post the way it looked when I was typing it but just remember first number is Front second number is Rear.
J.SIMS
www.ovrccc.com
Old 09-22-2010, 09:31 PM   #825
Potoczak's Avatar
Thanks John for the carpet setup, will have to give that one a try when my carpet season starts here in a couple of weeks.
Pete Potoczak
ROBITRONIC AVID TOURING CAR VERY NICE! rifleman5000 R/C Items: For Sale/Trade 7 09-22-2008 02:27 PM
WTB Robitronic Avid Touring Car kmeyer R/C Items: Wanted to Buy 0 03-13-2008 06:55 AM
Robitronic Avid Touring car Mc dog Australian Racing 14 03-30-2007 03:03 AM
Robitronic AVID Touring Car........ Customworksking Electric On-Road 7 02-02-2007 11:09 AM
Robitronic AVID rc-car-net Electric On-Road 2 02-05-2006 08:37 AM
