Old 08-22-2010, 12:51 PM   #751
file:///C:/Users/robertoyvictor/Desktop/fotos%20de%20victor%20024.jpg
conejero is offline   Reply With Quote
Old 08-22-2010, 12:56 PM   #752
foto
Old 08-22-2010, 01:04 PM   #753
foto
Robitronic Avid Touring Car-fotos-de-victor-014.jpg   Robitronic Avid Touring Car-fotos-de-victor-015.jpg   Robitronic Avid Touring Car-fotos-de-victor-016.jpg   Robitronic Avid Touring Car-fotos-de-victor-017.jpg
Old 08-23-2010, 01:26 AM   #754
fotos
Robitronic Avid Touring Car-fotos-de-victor-018.jpg   Robitronic Avid Touring Car-fotos-de-victor-019.jpg   Robitronic Avid Touring Car-fotos-de-victor-022.jpg
Old 08-23-2010, 01:34 AM   #755
fotos.5400 mount better balanced chassis.
no screws in the direction, up carbon reinforcement.Do not use RA0093 (3,2 x6x1), modify, use (3,2 x6x0,8)
Change washer bearing the crown 0'8mm , subchassis cut in two ,change position servo.
Shock oil 35w ,front shock spring (silver) , rear 35w spring silver
Robitronic Avid Touring Car-fotos-de-victor-023.jpg   Robitronic Avid Touring Car-fotos-de-victor-024.jpg
Old 08-26-2010, 02:38 AM   #756
Originally Posted by Potoczak View Post
Sounds good keep us posted on how it goes!!!
Update on alloy out drives
run in stock on the weekend and lowered my times from 23sec to 20.12 not because of the out drives but just some tuning (speedy MMP and Ballistic 17.5)
but jeffs mod setting are great.
The out drives worked quite well, the alloy may be a bit soft with impact (which is a good thing) may have to take a few mil of the length to make it easier to put the drives in but so far so good.
Setting for MMP are
Start RPM 7500
End RPM 15900
timing 50 deg
Motor timing 0
Spur 85
Pinion 26
RO /FDR 34.78/5.78
Temp 180 F
Steven
Robitronic Avid / Avid V2
Tekin RS pro / Viper 10.5/MMP/6900
AE B44- MMP/Hacker 10.5/6900 Castle
IP 5000/50 SMC 5200/40/50
Casino Kid is offline   Reply With Quote
Old 08-26-2010, 02:48 AM   #757
Trader Rating: 15 (100%+)
Setting for MMP are
Start RPM 7500
End RPM 15900
timing 50 deg
Motor timing 0
Spur 85
Pinion 26
RO /FDR 34.78/5.78
Temp 180 F
Steven
steve your rear diff would have made a big differance to your lap times squared diff balls not as good as round ones. your diff was very smoth on the weekend
jay m is offline   Reply With Quote
Old 08-26-2010, 01:30 PM   #758
Jay m
to be honest jay the diff was not the problem it was speed or lack off and yes the diff was not at its best on that particular weekend.
But after the new diff rebuild and retention of the diff tension disks it is the best that its been.
Steven
Old 08-26-2010, 02:36 PM   #759
foto subchasis
Robitronic Avid Touring Car-coche2-186.jpg   Robitronic Avid Touring Car-coche2-187.jpg   Robitronic Avid Touring Car-coche2-188.jpg   Robitronic Avid Touring Car-coche2-189.jpg
Old 08-27-2010, 02:11 PM   #760
jeff jenkins's Avatar
Trader Rating: 77 (100%+)
Setting for MMP are
Start RPM 7500
End RPM 15900
timing 50 deg
Motor timing 0
Spur 85
Pinion 26
RO /FDR 34.78/5.78
Temp 180 F
Steven
sounds good glad the set-up works for you . juat out of curiousity which set-up did you end up using was it my most recent one on petit rc?
Maclan Racing Products-Bellgate Distributions-PR Racing- Prospeed
jeff jenkins is offline   Reply With Quote
Old 08-27-2010, 03:42 PM   #761
jeff
i think it was the first one that you put on petit rc.
Only took the roll centre shims out and laid the shocks right over, should be able to get away with this setup for most tracks that i run maybe just a few shock adjustments? In saying that i still have a bit (not much)of push in the sweepers under acceleration but apart form that GREAT.
Steven
Old 08-27-2010, 09:10 PM   #762
Post ur current setup including everything so we can all look at it then let's see why you r pushing in the sweepers.
Old 08-28-2010, 02:40 PM   #763
Jeff
setup.
Camber
F-2 R-2
C-Hub
F-4deg R-0
Toe
F-0 R- -3deg
Ride Hight
F-5mm R-5.5mm
Suspension Mounts
FF-3 FR-2
RF-0 RR-3
Roll center
No roll center shims all round.
Wheel base Long front and rear
Droop
F-4mm R-4mm
Transmission
Spool
Roll bar
None Front or Rear
Springs
F-Grey R-Blue Avid springs (not Avid v2)
Oil
AE-35
Pistons
3 hole
Shock position Arm-
F-2 R-2
Tower
F-1 R-1
Upper suspension
Washer in board
F -0mm R-2mm
Suspension plate whole
F-A R-A
Steering
Ball end 3
Knuckle 2
Washer under ball end knuckle 2mm
tires were Muchmore 36v
Standard bottom deck and refined top deck
Options were proto type alloy out drives (maybe they are a tad to long)
Steven.
Old 08-30-2010, 12:32 PM   #764
Couple of questions regarding your set-up it says roll centers all the way around does this mean no roll center shims under arm mounts? and roll bars says nill does that mean none? your shocks springs, what brand are they? and on your droop what is your method for measuring the droop did you use a droop guage and 10mm blocks or are you measuring the uptravel from ride hieght ?
my suggestions would be run the front shocks in the #3 position and the rear shocks in the #4 position and the rear shocks in the #3 position on the arm and put the front wheelbase to standard position. that is what i am running at the moment and i have no problems with push in the sweepers. and the upper links on the tower to the B position this will give more camber change and hopefully allow you to grip more in the corners.
and the droop i always find myself running 3-3.5mm of front uptravel from ride hieght and the rear 2mm of uptravel from ride hieght. so say if my ride hieght is 5.5mm all around and i pull up on the front tower to the point where the tires just about loose contact with the set-up board and my ride hieght gauge will read 8.5mm if i use 3mm of uptravel and do the same with the rear and it should read 7.5mm when using 2mm uptravel.
your best bet for springs would be running a spring rate the same as hpi silvers in the front and a ratethe same as hpi blues in the rear. this so far is the best spring combo for outdoor asphalt i have found at the moment if grip is high i might change the rear springs to silver.
if you are still having issues for any reason with push in the sweepers or highspeed sections try reducing your front droop value keeping more wieght on the front under power . also maybe try running the 5 deg castor blocks.
hope this helps.
-Jeff
Old 08-30-2010, 08:07 PM   #765
Jeff thanks for the info i will try the settings this weekend.
Yes N0 roll center shims and No Roll Bars.
will let you know how it goes
Steven.
ROBITRONIC AVID TOURING CAR VERY NICE! rifleman5000 R/C Items: For Sale/Trade 7 09-22-2008 02:27 PM
WTB Robitronic Avid Touring Car kmeyer R/C Items: Wanted to Buy 0 03-13-2008 06:55 AM
Robitronic Avid Touring car Mc dog Australian Racing 14 03-30-2007 03:03 AM
Robitronic AVID Touring Car........ Customworksking Electric On-Road 7 02-02-2007 11:09 AM
Robitronic AVID rc-car-net Electric On-Road 2 02-05-2006 08:37 AM
