Old 08-05-2010, 08:02 PM   #706
hpisims's Avatar
Originally Posted by Potoczak View Post
Will a 111tooth 64p spur fit on the avid 2?
Yes Potczak I am currently using a 120 and still have room.
J.SIMS
Team Associated TC6-Viper R/C Solutions-Sweep Racing-Fullthrottle Motorsports-APH
www.speedybillsrc.com
www.ovrccc.com
hpisims is offline   Reply With Quote
Old 08-05-2010, 09:07 PM   #707
Potoczak's Avatar
Trader Rating: 112 (100%+)
Thanks Hpisims for the answer!!!
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 08-06-2010, 11:49 AM   #708
jeff jenkins's Avatar
Trader Rating: 77 (100%+)
here is the link to my most recent set-up it has the changes i described earlier from my last set-up.
http://www.petitrc.com/reglages/robi...ic20100731.pdf
Maclan Racing Products-Bellgate Distributions-PR Racing- Prospeed
jeff jenkins is offline   Reply With Quote
Old 08-08-2010, 12:50 PM   #709
Potoczak's Avatar
Hey guys, what kind of servo's are you guys running in your avid's, also is there a trick to tightening the inner 2 servo screws??
Pete Potoczak
Old 08-08-2010, 04:03 PM   #710
Send a message via AIM to canto54
Hi guys,
some pics of my car at the European Championship this weekend! Car was very good on this tight technical track.
I will post my setup very soon
More infos about eh european championship here HERE
Robitronic Avid V2
Robitronic - Graupner - GM racing
JP Products
www.mrclongwy.fr
www.petitrc.com
canto54 is offline   Reply With Quote
Old 08-08-2010, 09:08 PM   #711
i use the futaba s9551 low profile servo in my avid and to get to the 2 inner screws you have to take the servo out of the car or use a ball driver.
Old 08-09-2010, 04:52 AM   #712
Potoczak's Avatar
Jeff thanks, Do you have to run a low profile servo or is that just your preference?
Pete Potoczak
Old 08-09-2010, 12:31 PM   #713
you can run any servo you like this is just what i had and what i prefer as it gives more space for the other electronics on the car.
Old 08-10-2010, 03:27 AM   #714
hey CANTO54:
What ballstuds and ball cups are you running ? what turn buckles did you use? im also wondering what ballstuds you used for the kingpins on the c-hubs.
also post your set-up.
Old 08-10-2010, 03:57 AM   #715
Originally Posted by jeff jenkins View Post
hey CANTO54:
Hi,
As for ballstuds and ballcups, I am using yokomo ones because I was owning a BD5 before so I was having them
For the ballstuds I uses for the kingpins on C-hubs, it is a yokomo also, the same as the BD5. I just had to reduce the size of the shim to use it on the Avid 2.
The turnbuckles I use are some old aluminium tamiya ones that a friends was having and give to me.
I think the TOP Photon's one should fit as well.
Now I am working to find a gear diff I can fit in the car, because in mod it is really helpfull, maybe the TOP Photon gear diff can fit, I have to check for it
I will post my setup as soon as I can, I am not at home right now
Robitronic Avid V2
JP Products
www.mrclongwy.fr
www.petitrc.com
Old 08-10-2010, 04:09 AM   #716
i am hoping that the hot bodies tcx gear diff will fit once that is available .
Old 08-11-2010, 03:24 PM   #717
Dusttt's Avatar
Trader Rating: 123 (100%+)
Originally Posted by canto54 View Post
Hi guys,
I see you dont have the stock ball cups installed. Where they an issue? Also the grinding on the steering posts doe that help a bunch. Oh and lastly are thosetamiya shocks on it?
Dusttt is offline   Reply With Quote
Old 08-11-2010, 03:24 PM   #718
Dusttt's Avatar
Hi guys,
I see you dont have the stock ball cups installed. Were they an issue? Also the grinding on the steering posts doe that help a bunch. Oh and lastly are those tamiya shocks on it?
Old 08-11-2010, 03:36 PM   #719
the ball cups were probably just his own preferance and the grinding is for clearance i am assuming to get full throw. and theshocks are tamiyas.
Old 08-11-2010, 11:45 PM   #720
Yes as Jeff said, ballcups are there by preference. At the beginning I put them on the car for better looking and less slop. But I was a little worried about changing a bit the rollcenters of the car and having some troubles with the handling. But surprisingly, the car was just much better this way.
As for the steering, I made this modification to have more lock. Normally, with the ackerman in position 5 the most angled wheel i could have was 20 degrees (inside wheel), now i can have like 24 degrees as in most of the cars. It is not usefull on all track, but if grip is very high you will have better steering.
As for the shocks, they are tamiya yes. The original shocks are not bad if you correct somme issue like the bladder or the o-ring, but the biggest trouble i had with them was the collar that didn't fit the shock bodies and my ride height was always changing during each run. I tried with another set of collar and bodies and problem was still the same, so i decided to switch to tamiya to be sure my shocks are not an issue anymore
Robitronic Avid V2
JP Products
www.mrclongwy.fr
www.petitrc.com
ROBITRONIC AVID TOURING CAR VERY NICE! rifleman5000 R/C Items: For Sale/Trade 7 09-22-2008 02:27 PM
WTB Robitronic Avid Touring Car kmeyer R/C Items: Wanted to Buy 0 03-13-2008 06:55 AM
Robitronic Avid Touring car Mc dog Australian Racing 14 03-30-2007 03:03 AM
Robitronic AVID Touring Car........ Customworksking Electric On-Road 7 02-02-2007 11:09 AM
Robitronic AVID rc-car-net Electric On-Road 2 02-05-2006 08:37 AM
