Old 08-01-2010, 07:45 PM   #691
jeff jenkins's Avatar
Trader Rating: 77 (100%+)
good weekend for the avid v2 . had a 2 day event at a local parking lot track and ended up TQing and taking the overall win in the a-main and the car felt awesome. corally man ( Steve) finished 2nd at the event in the same class it was a really good weekend for steve in prep for the nats next week and we both have completely different set-ups and both worked very well and steve tried something a little new on his car which i will be going to as well but i will let him explain it when he gets on here.
summary: good weekend
Maclan Racing Products-Bellgate Distributions-PR Racing- Prospeed
jeff jenkins is offline   Reply With Quote
Old 08-01-2010, 08:34 PM   #692
Originally Posted by jeff jenkins View Post
here is a link to my set-up that is now on petitrc.com.
http://www.petitrc.com/reglages/robi...oe20100724.pdf
pay attention to the roll center and arm mounts i used when looking at the set-up.
Jeff
The set up works realy great thanks very much for the info
Steven
Robitronic Avid / Avid V2
Tekin RS pro / Viper 10.5/MMP/6900
AE B44- MMP/Hacker 10.5/6900 Castle
IP 5000/50 SMC 5200/40/50
Casino Kid is offline   Reply With Quote
Old 08-02-2010, 06:34 AM   #693
sorry.... I was wrong....
minizmudejar is offline   Reply With Quote
Old 08-02-2010, 08:34 AM   #694
Old 08-02-2010, 08:35 AM   #695
Originally Posted by Casino Kid View Post
Jeff
Steven
good to here you like the set-up i improved it over the weekend i will post my new set-up soon.
Old 08-02-2010, 09:57 PM   #696
Potoczak's Avatar
Trader Rating: 112 (100%+)
What are most of you guys running for servo horns????
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 08-03-2010, 01:26 AM   #697
i currently use the kimbrough large servo saver but you have to file the topdeck a little for clearance so the steering link doesnt hit.and i think others are using a kimbrough medium sized servo saver.
Old 08-03-2010, 03:39 AM   #698
in addition to your setup i took the dremil to the topdeck and the front cross member is gone and half of the rear is gone as well to get a bit more flex.
Steven
Old 08-03-2010, 10:32 AM   #699
Steven
are you using the 2mm topdeck or the 2.5mm topdeck for this? i just ran the car with the 2mm topdeck and was thinking of doing this same thing you just did to it as well.
so the changes i made this last weekend to my most recent set-up on petitrc is the following:
front:
5.5mm ride hieght
3mm droop
0 angle driveshafts
hpi pink springs
used 1.5mm rollcenter shim under the 2.0 arm block on front end to give 1.5 degrees of anti-dive
rear:
2mm droop
5.5mm ride hieght
hpi blue springs
40wt oil ae
shock position #4 on tower(4th hole from inside)
this setup also used the 2mm topdeck and only had a total of 8 screws in it 4 front ones and 2 in front of layshaft and 2 at the very back.
Old 08-03-2010, 12:28 PM   #700
just out of curiousity has anyone tried to run a gear diff in there car and found one to fit? i am waiting for the hotbodies tcx spec r diff to be released as it has the same pulley count as the avid v2 and i have a feeling it will work but i thought i would ask others if they have found another one to work.
Old 08-03-2010, 04:06 PM   #701
front:
5.5mm ride hieght
3mm droop
0 angle driveshafts
hpi pink springs
rear:
2mm droop
5.5mm ride hieght
hpi blue springs
40wt oil ae
Jeff
i was using the standard top deck. 1 screws at the very front and 1 in the middle at the back . All of the front stay dremiled out and the back half at the back.
Front Shocks /Rear Shocks
Robitronic Grey springs/Blue
35 Associated oil (no rebound)
Position
A-Arm 2 /2
Shock Stay 1/1
Upper suspension arm
Front inboard washer 0 Position 1
Rear inboard washer 2mm position 1
Rear hub H 2mm washer
steering inner plate 3 knuckle 2 washer 2mm
no sway bars
spool
Tyre Much more 36V pre assembled
as for the droop/ride hight and pre load the mate done all that as i was busy with paper work.
As for the gear diff Xray ,xray ball diff will not fit and i am sure the s400 is to wide as well.
Steven
Old 08-03-2010, 07:39 PM   #702
Potoczak's Avatar
Hey guys how is avid in the balancing department?? Do you have to add a ton of weight on the battery side to balance it out???
Pete Potoczak
Old 08-04-2010, 01:26 AM   #703
Jeff
Position
A-Arm 2 /2
Shock Stay 1/1
no sway bars
spool
Steven
how did the car feel with the shocks leaned all the way in on the front of the car?
Old 08-04-2010, 02:03 AM   #704
jeff
it seemed to handle the direction changes quite good , although i had the steering turned down to about 50% which was enough for the track.
A lot of tyre wear on the right hand front and next to nothing on the left hand rear, the left front and right rear are about the same.
Steven
Old 08-05-2010, 05:21 PM   #705
Potoczak's Avatar
Will a 111tooth 64p spur fit on the avid 2?
Pete Potoczak
ROBITRONIC AVID TOURING CAR VERY NICE! rifleman5000 R/C Items: For Sale/Trade 7 09-22-2008 02:27 PM
WTB Robitronic Avid Touring Car kmeyer R/C Items: Wanted to Buy 0 03-13-2008 06:55 AM
Robitronic Avid Touring car Mc dog Australian Racing 14 03-30-2007 03:03 AM
Robitronic AVID Touring Car........ Customworksking Electric On-Road 7 02-02-2007 11:09 AM
Robitronic AVID rc-car-net Electric On-Road 2 02-05-2006 08:37 AM
