Old 09-01-2009, 10:11 PM   #361
Slideaway's Avatar
Hey there,
So far, the only answer I hear about the release date is: "Soon !"
This is where RC business is weak compare to other big stuff. Things are always scheduled and you can expect things to arrive on the market according to release date they planed... It's way different for RC...
I don't know if October is a confirmed thing. Maybe Soon=October... who knows?!
Keep your cool and be patient !
Slide
Ludo
Thai Ride Tech Support.
Slideaway is offline   Reply With Quote
Old 09-02-2009, 09:23 AM   #362
HarryN's Avatar
Send a message via AIM to HarryN
Originally Posted by Slideaway View Post
Hey there,
Slide
Heh, I am doing my best.
But who is this Thomas Nagel guy? I saw he was mentioned with one of the designers of this car but I know nothing of him. Is he a legend over there in Euroland?
Car(s): Team Losi 22 1/10 Buggy, Team Losi 22 1/10 Stadium Truck
Motors/Engines: SP 13.5 v1.0, SP 17.5 v3.0 x2, RevTech 7.5
Radio: Spektrum DX3R, DX3S
Cars For Sale: FG 08-530 EVO w/ Sport Brakes!
Track(s): http://www.rctrack.com
HarryN is offline   Reply With Quote
Old 09-02-2009, 09:51 AM   #363
HarryN's Avatar
And one more thing, I do not know if you have the AVID spool for the car, but check out these pictures:
I will let you guess what happened. The Aluminum sleeves were used. As you can see in one of the pictures, the entire outdrive snapped and broke! Taking the sleeve with it. On the other side, you can see that the dogbone from the CVD spun inside the cup. The aluminum sleeve slid right off.
Know what may have caused this from your perspective? I am thinking defective plastic.
Old 09-02-2009, 10:30 AM   #364
This is not an industry where you can make a million dollars over night. Its still a niche industry. If you can sell thousands of units in a month, then they would make sure the product is delivered on time. All r/c companies are the same, even the bigger ones. Like Slideaways says, PATIENCE!
More Juice is offline   Reply With Quote
Old 09-02-2009, 11:06 AM   #365
marcel p's Avatar
Send a message via MSN to marcel p
these outdrive are mayby a bit to smal by production.
its normaly a press fitting so the sleeve should not come off.
the avid spool i have used is neerly unbreakeble.
greeting marcel
PR racing
Powerstar/futaba 4px
Absima /vr racing
marcel p is offline   Reply With Quote
Old 09-02-2009, 02:03 PM   #366
HarryN's Avatar
Well then I do not know what happened with this outdrive. It may have been defective plastic for the outdrive cups.
The new cups should be in today. I will install them and the sleeves and see what happens. And by the way, this was after I was T-boned by another racer that day. But the cups should NOT have broke with the sleeves on, in my opinion. I am hoping Robitronic USA and Robitronic HQ will figure out what is wrong.
Old 09-02-2009, 03:26 PM   #367
Slideaway's Avatar
Yes just like Marcel said, the red sleeves should be press installed on the outdrives. It was like that with all the spools I had so far and even if the plastic get used inside, i've never experienced a break like this...
This break looks like you ran without the sleeves. And of course, it makes the spool quite weak and more exposed to damage in case of crash.
If you want a bulletproof spool, take a oneway set, make a deep degreasing of every parts and glue the outdrive inside the each oneway bearing after you first installed the 15x10 bearings.
This will "eat" more dogbone blades (with a bit heavier rotation parts, i agree) but you will never break it !
Slide
Ludo
Old 09-04-2009, 07:43 AM   #368
Send a message via AIM to muzza233
Default my avid touring
hey guys i just brought a avid touring mint as
have a look at pics
Robitronic Avid Touring Car-04092009302.jpg   Robitronic Avid Touring Car-04092009309.jpg   Robitronic Avid Touring Car-04092009308.jpg   Robitronic Avid Touring Car-04092009303.jpg
muzza233 is offline   Reply With Quote
Old 09-04-2009, 11:09 AM   #369
RC TTwins's Avatar
Trader Rating: 43 (100%+)
nice pics
ok im too impactient to wait for the new avid to come what would i ned to convert it over to run good on carpet?
RC TTwins is offline   Reply With Quote
Old 09-04-2009, 05:14 PM   #370
303slowdown's Avatar
Trader Rating: 24 (100%+)
foam or rubber tire on carpet and how high of traction is the carpet
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 09-07-2009, 12:02 PM   #371
RC TTwins's Avatar
foam tires with high traction.
so who is all ready for the indoor session to start?
i have to get out the soldering iron and get it all wired up and im ready.
Old 09-07-2009, 12:59 PM   #372
pinggoy's Avatar
Trader Rating: 24 (96%+)
Send a message via Yahoo to pinggoy
pinggoy is offline   Reply With Quote
Old 09-07-2009, 02:35 PM   #373
This is what has worked for me with foams
jaco double pinks front and rear (or double pink/orange in front if to much steering with double pinks on front)
camber 1.5 front and rear
diff in front
ride height of 5mm front 5.5mm rear (our track has a few bumps)
front droop 1.5mm over ride height
rear droop 1 mm over ride height
0mm roll center (blocks mounted directly to chassis no roll center spacers)
3 degree toe in rear, 0degree toe in front
hpi pro4 red front springs
hpi pro4 pink rear springs
70 oil in front shocks
45 oil in rear shocks
1 mm washer under front and rear inner camber link
camber link mounted inner hole front and rear on chassis
outer rear camber link mounted middle hole on hub w/ 1mm washer
this set up works well for me and our track is very high traction carpet,
hope this helps and works for you.
Ryan Borgheiinck
Old 09-08-2009, 09:22 AM   #374
HarryN's Avatar
diff in front
Wow, that is very LITTLE roll!! Do you have pictures? Also, why not just have your roll center camber links level front and rear to allow the car SOME give so to avoid traction rolling on hard sudden turns?
Old 09-15-2009, 12:01 PM   #375
HarryN's Avatar
Hey Bud,
What servo saver and bumper are you using on your car??
by the way, I like the pic and car. But any pics of LiPo on your car? I should take some pictures of my car and post em up.
ROBITRONIC AVID TOURING CAR VERY NICE! rifleman5000 R/C Items: For Sale/Trade 7 09-22-2008 02:27 PM
WTB Robitronic Avid Touring Car kmeyer R/C Items: Wanted to Buy 0 03-13-2008 06:55 AM
Robitronic Avid Touring car Mc dog Australian Racing 14 03-30-2007 03:03 AM
Robitronic AVID Touring Car........ Customworksking Electric On-Road 7 02-02-2007 11:09 AM
Robitronic AVID rc-car-net Electric On-Road 2 02-05-2006 08:37 AM
