Old 05-05-2009, 11:19 AM   #301
Trader Rating: 17 (100%+)
Send a message via AIM to DJGonzo69
I encountered this problem also only on the front wheel/bearing assembly.
The wheel hex assemble is a soft metal & it tends to spread open at the area where you put the retaining clip. There are 2 ways you can take it apart. Remove the steering hub from the arms & remove the retraining ring. If you have 2 wooden blocks or a vise have the steering hub face downward & have the universals face up towards you. Have another person hold the steering assembly or clamp it on a vise. Now comes the ugly part. Hold the universal as straight as possible & hammer down untill the hex assembly comes out the other side. You can use some Tri-Flow lubricant to help. Sometimes it comes out easily & sometimes it's stubborn as hell! The other way is to dremel the part that has spread open litle by little. I tried both ways & I find it easier to do the first way. If the hex assemble was made out of steel instead of aluminum this will not happen. Hope this helps.
-John
|XRAY|RCAmerica|Hobbywing|KO PROPO|Team Scream Motors|Gonzo PaintWorX|
DJGonzo69 is offline   Reply With Quote
Old 05-06-2009, 11:06 PM   #302
303slowdown's Avatar
Trader Rating: 24 (100%+)
Thanks gonzo the wood trick worked fine axle came right out thanks for your help.
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 05-07-2009, 12:40 PM   #303
Glad it all worked out.
Old 05-14-2009, 07:20 AM   #304
RC TTwins's Avatar
Trader Rating: 43 (100%+)
I plan on racing the avid on carpet any one have a good setup sheet, also would it be easier to convert it over for carpet or just wait till the carpet car comes out?
RC TTwins is offline   Reply With Quote
Old 05-14-2009, 09:48 AM   #305
Slideaway's Avatar
Don't hesitate to
- Make the front suspension harder (higher oil grade, at least 70 or 80) and harder springs) than out of the box.
- Get the maximum rear camber intake
- Make the steering operation to be as smooth as possible, not too sensitive by any meaning necessary.
- Front width at least 2mm wider than the rear.
- Maximum wheelbase available.
- Harder front sway bar 1.6 or 1.8mm.
- Use all your radio functions to make it easier to drive, steering servo speed, not too much D/R, steering Expo, etc).
Avid is difficult to master on carpet. If someone else already had some good results on this surface, please let us how to deal with !
Hope you will do well. Anyway, please tell us how things did.
Cheers.
Slide
Ludo
Thai Ride Tech Support.
Slideaway is offline   Reply With Quote
Old 05-14-2009, 10:27 AM   #306
niznai's Avatar
I have run the Avid for a few times on carpet.
My setup was box stock, just used a front diff instead of the one way because we have rather low traction. I raced in 540 class and the rear was a bit loose, but OK. The car was quite quick and with a bit of getting used to I was back to my usual performance in my other cars (Yok SD-SSG, TA05R, Kawada Sigma2). Next season will get back to it and fine tune it.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 05-14-2009, 01:22 PM   #307
Slideaway,
thanks for the info on my problem with the front end, just added tamiya super heavy springs left the same oil (35w) fixed the problem just some more fine tuning and should be a rocket.
Has any one had problems with the front drive shafts bending? they seem to be very soft.
Steven.
Casino Kid is offline   Reply With Quote
Old 05-14-2009, 01:56 PM   #308
Do you have the silver bones or the black bones? If you have the silver ones you can change to the black hardened bones.
Old 05-17-2009, 09:38 PM   #309
Big Midget's Avatar
Trader Rating: 100 (100%+)
Does anyone have any issues with chassis tweak on there Avids....
UltralineHobbies.com
Ultraline Raceway Topeka Ks
Dee & Mee Hobbies RickyRacer Lidz,Absolute Tattoo,Fuzzy Dice Decals
Big Midget is offline   Reply With Quote
Old 05-18-2009, 12:33 AM   #310
Silver
Do you have a part number for the black hardened ones.
Thanks Steven
Old 05-18-2009, 09:13 AM   #311
Casino- try contacting SK Motion www.skmotion.com
I don't have the part#.
Old 05-20-2009, 06:54 AM   #312
Big Midget's Avatar
Does anyone know when the new Avid will be released?
Are they keeping the red anodized aluminum?
Old 05-20-2009, 11:59 AM   #313
RobiUSA-James's Avatar
A carpet chassis and top deck is now available. The factory chassis has too much flex for carpet.
Robitronic USA
www.skmotion.com
www.skmotion.blogspot.com
www.facebook.com/robitronicusa
www.myspace.com/robitronic_usa
RobiUSA-James is offline   Reply With Quote
Old 05-20-2009, 07:43 PM   #314
Slideaway's Avatar
Hi there,
If you have the sliver dogbones, yes, they are not hard enough.
Robitronic released the black ones, same part number.
At that time (at least, it was like this in France), Robitronic replaced them free of charge. Check out with your usual dealer.
The red anodisation will be kept for the Avid'09. Release date would arrived in the very middle of the year. Patience, it will not be long ;-)
Cheers
Slide
Ludo
Old 05-20-2009, 08:11 PM   #315
Big Midget's Avatar
Thanks Slideaway, is the new car going to be strictly a carpet car?
Also I'm assuming that chassis flex is an issue with the current car.
If this is correct, is this something I need to be concerned about racing asphalt?
Should I have a problem racing asphalt with the new car? Thanks again...
ROBITRONIC AVID TOURING CAR VERY NICE! rifleman5000 R/C Items: For Sale/Trade 7 09-22-2008 02:27 PM
WTB Robitronic Avid Touring Car kmeyer R/C Items: Wanted to Buy 0 03-13-2008 06:55 AM
Robitronic Avid Touring car Mc dog Australian Racing 14 03-30-2007 03:03 AM
Robitronic AVID Touring Car........ Customworksking Electric On-Road 7 02-02-2007 11:09 AM
Robitronic AVID rc-car-net Electric On-Road 2 02-05-2006 08:37 AM
